in imx6 solo manual,in register USBNC_USB_OTG_CTRL in USB phy module, there is a field that enable OTG Wake-up Interrupt, in register USBNC_USB_OTG_CTRL in USB controller,there is also a field that enable OTG Wake-up Interrupt, which one should be set or both need to be set to enable wakeup interrupt?
Hi hailiu
both need to be set to enable wakeup interrupt.
