Hi all,
my custom board use pice port and connected wake# pin to W21 , while i.MX6Q SD boards using P3 , i didn't find any configure about this pin in device tree, i search driver/pic folder with keywork "gpio" , "wake" , no found, could anyone point me where to change this pin?
best regards!
toot
Solved! Go to Solution.
Hi huang
as noted in attached Release Notes Table 13 Known Issues and Workarounds
PCIe doesn't support Hot Plug and Power Management.
Hi huang
Hi igor,
thanks for your quick reply, so this pin dosn't work now, i just ignore it , thank you!
toot
