where do i get imx7d evk bom ?
hyoungkikim
hi  experts
i am designing a custom board based on imx7d evk , from imx7d evk web page, i downloaded imx7d-sabresd_rev_d related files. there is a bom  file, but  some parts does n't have model names, for example  L1,L2 is noted "Power Inductor,Magnetic shielded,2.2uH,IRMS=7A,ISAT.."
where could i get  more detailed bom ?
thank you  sincerely
hyoungkikim
hi Chavira
i have already downloaded these files .  and i found some things are different frm  a evk board ,  to test periperials ,.i  used PERI_3V3 , but on the board , Q29, Q30 aren't assembed, and there is a R646 in a board  but in schematics , no R584 is found,
so i think these are n't the lastest
thank you for help,
Chavira
Hi @hyoungkikim!
I provide the link for revision D like you mentioned before.
What revision do you have?
I can send you the proper documents according the revision f the board that you have.
Best Regards!
Chavira
hyoungkikim
Hi Chavira
the board has a silk "SCH-28590 REV D2 "
thank you for your support
Chavira
Hi @hyoungkikim!
This is the latest schematic for your board.
Best Regards!
Chavira
hyoungkikim
Hi Chavira
thank you , the file is  the one i am looking for
Chavira
Hi @hyoungkikim!
Thank you for contacting NXP Support!
Dou you refer to imx7dsabre board?
If yes, you can download the design files included the bom file in the link below:
https://www.nxp.com/webapp/Download?colCode=iMX7D-SABRE-DESIGNFILES&appType=license
Best regards!
Chavira
hyoungkikim
thank you  it will be of great help
