where can download SDK which support 64bit boot code, and is not for M4F kernel
Search instead for
LeonGu
where can download SDK which support 64bit boot code, and is not for M4F kernel ?
LeonGu
admin@662cd820c86f:~/nfs_share/NXP/Yocto$ repo init -u https://source.codeaurora.org/external/imx/imx-manifest -b imx-linux-hardknott -m imx_5.10.35_2.0.0.xml
gpg: keybox '/home/admin/.repoconfig/gnupg/pubring.kbx' created
gpg: /home/admin/.repoconfig/gnupg/trustdb.gpg: trustdb created
gpg: key 16530D5E920F5C65: public key "Repo Maintainer <repo@android.kernel.org>" imported
gpg: key 67B7E448692B382C: public key "Conley Owens <cco3@android.com>" imported
gpg: Total number processed: 2
gpg: imported: 2
Get https://mirrors.tuna.tsinghua.edu.cn/git/git-repo
fatal: unable to access 'https://mirrors.tuna.tsinghua.edu.cn/git/git-repo/': server certificate verification failed. CAfile: none CRLfile: none
LeonGu
admin@662cd820c86f:~/nfs_share/imx8mm/Yocto$ repo init -u https://source.codeaurora.org/external/imx/imx-manifest -b imx-linux-hardknott -m imx_5.10.35_2.0.0.xml
Downloading Repo source from https://mirrors.tuna.tsinghua.edu.cn/git/git-repo
repo: error: "git" failed with exit status 128
cwd: /home/admin/nfs_share/imx8mm/Yocto/.repo/repo
cmd: ['git', 'fetch', '--quiet', '--progress', 'origin', '+refs/heads/*:refs/remotes/origin/*', '+refs/tags/*:refs/tags/*']
fatal: cloning the git-repo repository failed, will remove '.repo/repo'
缺少安全证书, 无法下载
LeonGu
admin@662cd820c86f:~/nfs_share/imx8mm$ repo init -u https://source.codeaurora.org/external/imx/imx-manifest -b imx-linux-hardknott -m imx_5.10.35_2.0.0.xml
cwd: /home/admin/nfs_share/imx8mm/.repo/repo
仍然连不上  我的电话 15221850734, 请联系我
b45499
it seems that your network issue, in china, we suggest customer change as below:
Open ~/bin/repo file with 'gedit' and Change google address
From
REPO_URL = 'https://gerrit.googlesource.com/git-repo'
To
REPO_URL = ' https://mirrors.tuna.tsinghua.edu.cn/git/git-repo/ '
Or :
curl https://mirrors.tuna.tsinghua.edu.cn/git/git-repo -o repo
LeonGu
admin@662cd820c86f:~/nfs_share/imx8mm/imx-yocto-bsp$ repo init -u https://source.codeaurora.org/external/imx/imx-manifest -b imx-linux-sumo -m imx-4.14.98-2.0.0_ga.xml --repo-url=https://mirrors.tuna.tsinghua.edu.cn/git/git-repo
cwd: /home/admin/nfs_share/imx8mm/imx-yocto-bsp/.repo/repo
无法连接
LeonGu
repo init -u https://source.codeaurora.org/external/imx/imx-manifest -b <branch name> [ -m <release manifest>]
请问 要下载 i.mx8m evk 的最新的 linux BSP, branch name, release manifest, 如何 设定?
b45499
LeonGu
贵司的sdk, 国内无法下载, 请问有gitee, 或者国内的下载地址吗?
b45499
If you cannot download the repo from google, please try this one:
Git Repo | 镜像站使用帮助 | 清华大学开源软件镜像站 | Tsinghua Open Source Mirror
LeonGu
imx8m mini  board
b45499
