what should I modify for change emmc from 8g to 16g?
1,666 次查看
mingmingyuan
5 回复数
1,515 次查看
Rita_Wang
By the way, which board and BSP are you using?
Dan
1,515 次查看
mingmingyuan
first, thank you for your help!
we hardware engineer draw Schematic according to imx6q sd board.  I think I should change partition tabel ( for example data partition )for emmc chage from 8g to 16g,can you tell how to change partition table ?
1,515 次查看
Rita_Wang
Hi mingming yuan,
Which version of BSP are you using?
Have a great day
Dan
1,515 次查看
mingmingyuan
dear sir:
we hardware engineer draw Schematic according to imx6q sd board. we run Android 4.4 system  \
1,515 次查看
Rita_Wang
You have to modify nothing when you change emmc from 8g to 16g. The 16g operation mode is the same to 8g.
Hope this can help you.
Have a great day
Dan
