what is the device file of driver cdc-ncm?
richardyang
My kernel is 3.0.35,I insert cdc-ncm driver for usb network by menuconfig, but I can't find the driver device file in /dev folder.
where is it?
Labels (4)
jamesbone
gusarambula, can you please check this?
richardyang
Dear jamesbone:
       I have been check it, but no found device file in there.
       ifconfig command then found usb0 port and i can set ip address.
gusarambula
Are you adding the driver as mountable or fixed in LTIB?
Are you not seeing anything under /dev/net?
