what is i have to use instead gnome desktop environment to run virtual keyboard on i.mx6 using qt ?
1,422 次查看
V16be1p11
I have used open source code of florence virtual keyboard on qt5. but due to ima not using GNOME desktop environment this key board not receiving any released key of virtual keyboard on lcd connected to I.mx6.
i am using Linux 4.9.88-10183-ge88eca2 #12 SMP PREEMPT Sat Apr 17 01:16:19 CDT 2021 armv7l GNU/Linux os. i am using Debian GNU/Linux 9.13 (stretch) .
I have installed all require package mention on
"http://florence.sourceforge.net/english/install.html"
But i am not receiving released key character on QLine edit.
标签 (1)
2 回复数
1,410 次查看
Bio_TICFSL
Hello V16be1p11,
Make sure that the layout of you keyboard is routed to the MX6 keypad since QT works the layout form QT is Ok. This is app fail and the BSP does not include that app.
1,406 次查看
V16be1p11
Thanks for reply.
when i open this keyboard manually on i.mx6  at that time i am getting below log:
Using configuration file florence.conf
XRecord extension found version=1.13
Your screen does not support alpha channel. Semi-transparency is disabled
WARNING: Service name lost.
I want to explore below thing can you help me ?
How to route this keyboard on mx6 Keypad ?
How to include app on BSP ?
Note : this same qt app work well on gnome based pc.
