we can't build valgrind-3.3.1 for i.mx28 on ltib platform, because have no the patchs.
Search instead for
luoqiaofa
we downloaded  valgrind-3.3.1, but we cant get the pathchs as follows
Patch1          :valgrind-3.3.1-8xx.patch
Patch2          : valgrind-3.3.1-softfloat-02.patch
the valgrind-3.3.1  we downloaded is not from the official web,   maybe can't match with the patchs above.
can you give it too?
FernandoGinezd1
Hi!
In spite of seeing that this questions was made at long time ago, i'd like to register the solution i've found for log purposes.
After spending some hours trying to build LTIB's valgrind specified version, I've found this post (How to build Valgrind 3.6.0 for Beagleboard-xM on Ubuntu | Embedded HOWTOs) which helped me to build valgrind's latest version (3.10.1).
You just have to follow the instructions which consists on the right './configure' parameters for your platform. In my environment I've used (iMX53-QSB):
./configure -prefix=/opt/valgrind -host=armv7-none-linux-gnueabi -target=arm-none-linux-gnueabi -build=i386-ubuntu-linux
And then:
make
And finally:
make install
After this last step, all necessary files were copied to $prefix directory on my build system.
A very important information is that you must copy and run valgrind from $prefix directory into your board, because the path is hardcoded into valgrind's binaries.
I wish you all success.
Fernando Ginez da Silva
