warp7 imx7s wifi
warp7 imx7s wifi
bheemarao
I am facing issues in bringing up the WIFI functionalities on warp7 board:
i am testing this using fsl-core-image-machine-test image
Followed the procedure as mentioned in user manual 1.3
$ modprobe bcmdhd
$ ifconfig wlan0 up
$ wpa_passphrase <Network Name> <Password> > /etc/wpa_supplicant.conf
$ wpa_supplicant -B -i wlan0 -c /etc/wpa_supplicant.conf -D nl80211 &
$ udhcpc -i wlan0
Bheema Rao
Tags (2)
jerseyyang
the capture is not very clear, so dont kown exactly what the issue is. it seems the driver insmoded unsuccessfully. i have done the same test in imx6ul a few weeks before.
gusarambula
Hello Bheema Rao,
I think the support for Murata’s Wifi module on the Warp7 board is available only on the fls-image-machine-test and fsl-image-multimedia. I would recommend switching to these images to test the Wifi module.
I would also recommend posting your question on Element 14 Forums as they are the designers of the board and there may be more content that may be useful.
