Dear Igor,
Thanks for your reply and suggestion.
Unfortunately, we have no time to modify HW to check the bus performance
of 64bit bus.
And the target cost of this product does NOT allow the increase in DDR
cost.
Besides, another HW (one of our products) of i.MX6S (with 32bit DDR)
performs the similar FullHD stream handling with no problem.
So It's possible that there may still be some errors in our FW.
And, to find out root cause, I want to know the direct cause of the error
message (mentioned before) at first.
If you have any info about the error message, pls kindly let me know.
BR,
N. Sugihara
GOH SHOJI CO., INC.
ELECTRONIC EQUIPMENT DIVISION,
NP Group,
Noboru Sugihara
ZIP: 104-0032
2-11-2, Hatchobori, Chuo-ku, Tokyo, Japan
TEL: +81-3-3552-7721
FAX: +81-3-3555-0378
E-Mail: u0621@goh.co.jp
URL: http://www.gohshoji.com/
送信元: igorpadykov <admin@community.freescale.com>
宛先: "杉原 昇" <u0621@goh.co.jp>,
日付: 2016/09/19 08:40
件名: Re: - Re: v4l2 error on i.MX6 yocto linux
NXP Community
reply from igorpadykov in i.MX Community - View the full discussion
for dependency :
-air cooling the i.MX6 seems to drive down the error frequency.
-Decreasing VPU fps (30fps -> 15fps) drives down the error frequency.
-Cutting off H.264 encoding procedure drives down the error frequency.
may be deduced that this may be caused by processor bus performance
limitation.
One can try to use 64 bit memory configuration or faster procesor grade,
or reduce
bus load using less intensive graphics.
