uuu can't burn the linux images into eMMC on the iMX8qxp-mek
4,080件の閲覧回数
先生孟
Hi Team:
    I want to write the images including Image、dtb、rootfs、bootloader etc files into the eMMC on the iMX8QXP-MEK by uuu mfgtool, therefore I strictly execute following documents:
(1)uuu.pdf (how to operate the uuu tool)
(2)yocto Linux User Guide.pdf (how to boot the linux and use the uuu)
(3)One training document about uuu from FAE
Excepting above documents, I execute following procedure:
(1)downloading the imx-imx8qxp-mek-images-L4.14.78_1.0.0_ga.zip from nxp website
(2)downloading the rececently uuu.exe from github
(3)connecting the PC and MEK usb type C with USB3 cable
(4)connecting the MEK debug miniUSB and PC with miniUSB cable
(5)Open the PC super-terminal
(6)Get the flash.bin、fsl-imx8qxp-mek.dtb、uramdisk-rootfs.uboot、Image etc files by decompressing (1) procedure zip file
(7)Modified the uuu.lst script file according with mfgtool script example file
(8)Power on the IMX8QXP-MEK
(9)Execute the uuu program in the windows Command windows
  $uuu uuu.lst
Then, all files including the flash.bin、dtb、uramdisk rootfs、Image etc are downloaded into the iMX8QXP-MEK ddr memeory,
Wait for Known USB Device Appear
New USB Device Attached at 1:8
1:8>Start Cmd:SDPS: boot -f flash_mfg.bin
100%1:8>Okay
1:8>Start Cmd:FB: ucmd setenv fastboot_dev mmc
1:8>Okay
1:8>Start Cmd:FB: ucmd setenv mmcdev 0
1:8>Okay
1:8>Start Cmd:FB: ucmd mmc dev 0
1:8>Okay
1:8>Start Cmd:FB: ucmd setenv fastboot_buffer ${loadaddr}
1:8>Okay
1:8>Start Cmd:FB: download -f Image
1:8>Okay
1:8>Start Cmd:FB: ucmd setenv fastboot_buffer ${fdt_addr}
1:8>Okay
1:8>Start Cmd:FB: download -f fsl-imx8qxp-mek.dtb
1:8>Okay
1:8>Start Cmd:FB: ucmd setenv fastboot_buffer ${initrd_addr}
1:8>Okay
1:8>Start Cmd:FB: download -f fsl-image-mfgtool-initramfs-imx_mfgtools.cpio.gz.u-boot
1:8>Okay
1:8>Start Cmd:FB: acmd ${kboot} ${loadaddr} ${initrd_addr} ${fdt_addr}
1:8>Okay
the PC supre-terminal shows following scripts:
4.996886: xhci-cdns3: USB bus 1 deregistered
Sh-4.4# Can't support > 32 dma
.5.139795] hub 1-0:1`.0: usb hub found
5.143595] hub 1-0: 1:0: 1 port detected
5.147805] xhci-cdns3: xHCI host controller
5.152195] xhci-cdns3: new USB bus registered, assigned bus
then above scripts always be printed (I take the picture with the attached file)
But uuu can't download the files (include mksdcard.sh.tar、Image、flash.bin、rootfs.tar.bz2、dtb files) into  the eMMC
by FBK command
I don't know what's the reason, all files come from the imx-imx8qxp-mek_L4.14.78_1.0.0_ga.zip,
Could you could give me the solution?
Thank you very much
Meng
2019-04-10
2 返答(返信)
3,253件の閲覧回数
inigovicentewal
Hi 先生孟
Did you get the board started?
Where did you get _flash.bin, _Image, _board.dtb, _rootfs.tar.bz2 ?
Is L4.14.98_2.0.0_ga_images_MX8MMEVK sufficient?
Thanks.
3,253件の閲覧回数
jimmychan
There is example_kernel_emmc.uuu in the demo image.
You can take this for reference.
