updating time to GPS time on IMXQXP
1,292 次查看
sistlajr6
Hi ,
I am running demo linux images from NXP on the iMX8QXP. I am able to connect a GPS receiver and get the nmea data by accessing /dev/ttyACM3 ( since its a usb based GPS reciever) . Now i am trying to get the date and time updated to the GPS time. How can I achieve this on the imx demo image.
Sistla.
标记 (1)
1,244 次查看
sistlajr6
Hi Sanket,
I am trying to use a USB based GPS module, on Ubuntu i am able to the opensource libraries to read the time and data , lat and long and all the data.
On iMX i am able to use /dev/ttyACM* to read the NMEA data. But i am looking at the yacto build if there is any publicly available libraries that i can use to nmea data from this port  just like gpsmon or some
1,236 次查看
Sanket_Parekh
I hope you are doing well
To read NMEA data one can use 'gpsd' related packages in meta-openembedded layer.
One can add the below packages in conf/local.conf and check the recipe build using bitbake.
" gpsd gps-utils libgps gpsd-gpsctl"
bitbake gpsd
Thanks & Regards
Sanket Parekh
1,253 次查看
Sanket_Parekh
Hi @sistlajr6
I hope you are doing well.
Kindly mention the part number of the GPS device you are using.
Thanks & Regards
Sanket Parekh
