unable to run models via onnx runtime
palaniappank
I'm trying to run model using imx8 with onnx runtime with the help of https://www.nxp.com/docs/en/user-guide/IMX-MACHINE-LEARNING-UG.pdf as per section 5.2.1. But I'm not able to execute and its showing folder not found or command not found error.
I tried another version of onnx runtime also and getting below.
Kindly help on this.
Palaniappan K
Zhiming_Liu
If you are not using imx-image-full, please try it:
root@imx8mpevk:/# find -name onnx_test**
./usr/bin/onnxruntime-1.13.1/onnx_test_runner
