udc_irq() function not called in imx8m mini?
已解决
跳至解决方案
1,036 次查看
Hariharan1
Hi all,
I am currently working on usb gadget related stuff in cortex a53 processor. In sdp_init function frequently calling usb_gadget_interrupt() function but udc_irq() not called frequently. it is called only once but even udc status has been enabled by itself after that board has been restarting but it should call udc_irq() function. what is the issue?
Thanks.
标签 (1)
1 解答
997 次查看
Hariharan1
It was resolved
Thank you.
在原帖中查看解决方案
2 回复数
1,009 次查看
Zhiming_Liu
Hi @Hariharan1
Can you share your bsp verison, in uboot or linux?
998 次查看
Hariharan1
It was resolved
Thank you.
