ubuntu-i.mx8m.pdf error
2,986 次查看
csoon-park
3. Download ubuntu rootfs
$ mkdir ~/rootfs && cd ~/rootfs
pdf: $ wget http://cdimage.ubuntu.com/ubuntu-base/releases/19.10/release/ubuntu-base-19.10-base-arm64.tar.gz
$ wget https://cdimage.ubuntu.com/ubuntu-base/releases/18.04/release/ubuntu-base-18.04.5-base-arm64.tar.gz
Change it and move on
$ mkdir ubuntu-rootfs
pdf: $ tar -xvf ubuntu-base-19.10-base-arm64.tar.gz -C ubuntu-rootfs
$ tar -xvf ubuntu-base-18.04.5-base-arm64.tar.gz -C ubuntu-rootfs
$ cd ubuntu-rootfs
$ ls
4. Install qemu-user-static on PC to simulate arm64 environment
$ apt-get install qemu-user-static
$ cp /usr/bin/qemu-aarch64-static usr/bin
$ cp -b /etc/resolv.conf etc/
5. Simulate arm64 environment
$ cd ../ (rootfs$)
$ ./ch-mount.sh -m ubuntu-rootfs
Refusing permission
There's no command
Can you help me with this error when an error occurs?
2,973 次查看
jimmychan
We have support Ubuntu rootfs build in the Linux Yocto BSP.
Please try to follow the steps below to build it.
 https://source.codeaurora.org/external/imx/meta-nxp-desktop/tree/README.md?h=imx-5.10.52-hardknott
For the Yocto BSP, please refer to this link.
https://www.nxp.com/design/software/embedded-software/i-mx-software/embedded-linux-for-i-mx-applicat...
5 回复数
2,974 次查看
jimmychan
2,962 次查看
csoon-park
Thank you, teacher.
However, Ethernet connection and Internet connection are not available.
it is "imx8mpevk". Also, does this os install apt-get?
KakaoTalk_20211110_091325988.jpgKakaoTalk_20211110_091325988_01.jpgKakaoTalk_20211110_091325988_02.jpg
2,950 次查看
jimmychan
So, have you try to use ifconfig to set the IP address?
2,922 次查看
csoon-park
Doesn't this os run the "qt5" program?
I installed "pyqt5" with "sudo apt-get install python3-pyqt5".
https://community.nxp.com/t5/i-MX-Processors/imx8mpevk-meta-nxp-desktop-pyqt5-run-error/m-p/1369857/...
KakaoTalk_20211111_145421044_01.jpgKakaoTalk_20211111_145421044_03.jpgKakaoTalk_20211111_145421044_04.jpg
2,938 次查看
csoon-park
Thank you. It's been resolved.
