uboot transition between imx6q to imx6d
balasubramanian
My custom is same as the sabresd board. We are using  imx6d processor in our custom board. Can we use sabresd uboot 2013-04 for my custom board? If not means what are the files and contents  should i have to change in uboot.!!!
Labels (3)
igorpadykov
Hi Bala
imx6q uboot will run on imx6d fine, for loading linux
one needs to use maxcpus=2 parameter.
Regarding usage of several cores one can look below
UBootStandalone < DULG < DENX
