uboot - Device tree binding and dm_gpio_lookup_name("x",&desc)
751件の閲覧回数
DavidFlir
For an imx91 based project I am stuck with defining my first GPIO as output.
I have read several posts where examples towards the device trees are explained but I am still getting the `-22` return value.
Defined in device tree:
	gpio_reset: gpio-reset {
		compatible = "gpio-reset";
		pinctrl-names = "default";
		reset-gpios = <&gpio1 8 GPIO_ACTIVE_LOW>;
		status = "okay";
		label = "RSTO";
		gpio-name = "RSTO";
		line-name = "RSTO";
Here I tried adding label,gpio-name and line-name. Not sure which one is needed.
Then in function
static void board_gpio_init(void){
	struct gpio_desc desc;
	int ret;
	/* De-assert RSTO */
	ret = dm_gpio_lookup_name("RSTO", &desc);
	if (ret) {
		printf("%s lookup 'RSTO' failed ret = %d\n", __func__, ret);
		return;
This always returns -22 and it's the first pin to look up.
Then I thought let's try a proven example code based on leds,
	gpio-leds {
		compatible = "gpio-leds";
		pinctrl-0 = <&pinctrl_gpio_led>;
		led-0 {
			gpios = <&gpio3 26 GPIO_ACTIVE_HIGH>;
			default-state = "on";
		led-1 {
			gpios = <&gpio3 27 GPIO_ACTIVE_HIGH>;
Then
	ret = dm_gpio_lookup_name("led-1", &desc);
also returns -22
タグ(2)
707件の閲覧回数
danielchen
HI @DavidFlir
I would suggest you refer to the function in gpio-uclass.c
5 返答(返信)
737件の閲覧回数
DavidFlir
I did find a missing _defconfig setting called
CONFIG_IMX_RGPIO2P=y
with this setting I am able to do a succesful
ret = dm_gpio_lookup_name("gpio1_8", &desc);
But I still did not figure out how I can use the names defined in the .dts file instead of this gpio1_8.
716件の閲覧回数
danielchen
Hi David:
The dm_gpio_lookup_name() function does not parse gpio-name, or line-name from the device tree. It only understands the format "gpioX_Y" where
X is the GPIO controller
Y is the pin number.
If you are working in the Linux Kernel (not U-BOOT), you can use
struct gpio_desc *rst_gpio;
rst_gpio = devm_gpiod_get(&pdev->dev, "reset", GPIOD_OUT_LOW);
And define in DTS
gpio-names = "reset";
710件の閲覧回数
DavidFlir
Thanks for reply!
I did notice this example:
https://github.com/nxp-imx/uboot-imx/blob/9383f8387dc76524524da69992db96c22195a57c/board/freescale/i...
ret = dm_gpio_lookup_name("adp5585-gpio4", &exp_sel_desc);
this seems to be another allowed format besides "gpioX_Y"
It's defined as
	adp5585: io-expander@34 {
		compatible = "adi,adp5585-00", "adi,adp5585";
		reg = <0x34>;
		#gpio-cells = <2>;
		gpio-controller;
		#pwm-cells = <3>;
		gpio-reserved-ranges = <5 1>;
		exp-sel-hog {
			gpio-hog;
			gpios = <4 GPIO_ACTIVE_HIGH>;
			output-low;
So how can I check how the syntax should be? for instance: is it connecting with a ''_" or "-"... ?
708件の閲覧回数
danielchen
HI @DavidFlir
705件の閲覧回数
DavidFlir
Ok so finding out which ports are actual available just requires a print like,
		len = uc_priv->bank_name ? strlen(uc_priv->bank_name) : 0;
		printf("%s: lookup %s\n", __func__,uc_priv->bank_name);
		if (!strncasecmp(name, uc_priv->bank_name, len)) {
And then I get to see the available&correct names on my console!
file location is `uboot/drivers/gpio/gpio-uclass.c`
%3CLINGO-SUB%20id%3D%22lingo-sub-2146091%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Euboot%20-%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%83%90%E3%82%A4%E3%83%B3%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%A8dm_gpio_lookup_name(%22x%22%2C%26amp%3Bdesc)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2146091%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eimx91%20%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AE%20GPIO%20%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%A8%E3%81%97%E3%81%A6%E5%AE%9A%E7%BE%A9%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AB%E8%A1%8C%E3%81%8D%E8%A9%B0%E3%81%BE%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%E3%81%AE%E4%BE%8B%E3%81%8C%E8%AA%AC%E6%98%8E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%8A%95%E7%A8%BF%E3%82%92%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E8%AA%AD%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%BE%E3%81%A0%20%60-22%60%20%E3%81%AE%E6%88%BB%E3%82%8A%E5%80%A4%E3%81%8C%E8%BF%94%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%83%84%E3%83%AA%E3%83%BC%E3%81%A7%E5%AE%9A%E7%BE%A9%3A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-css%22%3E%3CCODE%20translate%3D%22no%22%3E%09gpio_reset%3A%20gpio-reset%20%7B%0A%09%09compatible%20%3D%20%22gpio-reset%22%3B%0A%09%09pinctrl-names%20%3D%20%22default%22%3B%0A%09%09reset-gpios%20%3D%20%26lt%3B%26amp%3Bgpio1%208%20GPIO_ACTIVE_LOW%26gt%3B%3B%0A%09%09status%20%3D%20%22okay%22%3B%0A%09%09label%20%3D%20%22RSTO%22%3B%0A%09%09gpio-name%20%3D%20%22RSTO%22%3B%0A%09%09line-name%20%3D%20%22RSTO%22%3B%0A%20%20%20%20%20%20%20%20%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E3%80%81%E3%83%A9%E3%83%99%E3%83%AA%E3%83%B3%E3%82%B0%E3%80%81gpio-name%E3%80%81line-name%20%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%A9%E3%82%8C%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%8B%E3%81%AF%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E3%81%9D%E3%81%97%E3%81%A6%E6%A9%9F%E8%83%BD%E7%9A%84%E3%81%AB%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-cpp%22%3E%3CCODE%20translate%3D%22no%22%3Estatic%20void%20board_gpio_init(void)%7B%0A%09struct%20gpio_desc%20desc%3B%0A%09int%20ret%3B%0A%0A%09%2F*%20De-assert%20RSTO%20*%2F%0A%09ret%20%3D%20dm_gpio_lookup_name(%22RSTO%22%2C%20%26amp%3Bdesc)%3B%0A%09if%20(ret)%20%7B%0A%09%09printf(%22%25s%20lookup%20'RSTO'%20failed%20ret%20%3D%20%25d%5Cn%22%2C%20__func__%2C%20ret)%3B%0A%09%09return%3B%0A%09%7D%0A...%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E5%B8%B8%E3%81%AB%20-22%20%E3%82%92%E8%BF%94%E3%81%97%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AB%E6%A4%9C%E7%B4%A2%E3%81%99%E3%82%8B%E3%83%94%E3%83%B3%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%93%E3%81%A7%E3%80%81LED%E3%82%92%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AB%E3%81%97%E3%81%9F%E5%AE%9F%E8%A8%BC%E6%B8%88%E3%81%BF%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%82%88%E3%81%86%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-css%22%3E%3CCODE%20translate%3D%22no%22%3E%09gpio-leds%20%7B%0A%09%09compatible%20%3D%20%22gpio-leds%22%3B%0A%09%09pinctrl-names%20%3D%20%22default%22%3B%0A%09%09pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_gpio_led%26gt%3B%3B%0A%0A%09%09led-0%20%7B%0A%09%09%09gpios%20%3D%20%26lt%3B%26amp%3Bgpio3%2026%20GPIO_ACTIVE_HIGH%26gt%3B%3B%0A%09%09%09default-state%20%3D%20%22on%22%3B%0A%09%09%7D%3B%0A%09%09led-1%20%7B%0A%09%09%09gpios%20%3D%20%26lt%3B%26amp%3Bgpio3%2027%20GPIO_ACTIVE_HIGH%26gt%3B%3B%0A%09%09%09default-state%20%3D%20%22on%22%3B%0A%09%09%7D%3B%0A%0A%09%7D%3B%0A%0AThen%0A%09ret%20%3D%20dm_gpio_lookup_name(%22led-1%22%2C%20%26amp%3Bdesc)%3B%0A%0Aalso%20returns%20-22%3C%2FCODE%3E%3C%2FPRE%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2147466%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20uboot%20-%20Device%20tree%20binding%20and%20dm_gpio_lookup_name(%22x%22%2C%26amp%3Bdesc)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2147466%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EOK%E3%80%82%E5%AE%9F%E9%9A%9B%E3%81%AB%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%8D%B0%E5%88%B7%E3%81%99%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E%09%09len%20%3D%20uc_priv-%26gt%3Bbank_name%20%3F%20strlen(uc_priv-%26gt%3Bbank_name)%20%3A%200%3B%0A%09%09printf(%22%25s%3A%20lookup%20%25s%5Cn%22%2C%20__func__%2Cuc_priv-%26gt%3Bbank_name)%3B%0A%09%09if%20(!strncasecmp(name%2C%20uc_priv-%26gt%3Bbank_name%2C%20len))%20%7B%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E3%82%B3%E3%83%B3%E3%82%BD%E3%83%BC%E3%83%AB%E4%B8%8A%E3%81%A7%E4%BD%BF%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%8B%E3%81%A4%E6%AD%A3%E3%81%97%E3%81%84%E5%90%8D%E5%89%8D%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AF%20%60uboot%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2Fgpio%2Fgpio-uclass.c%60%20%E3%81%A7%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2147459%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20uboot%20-%20Device%20tree%20binding%20and%20dm_gpio_lookup_name(%22x%22%2C%26amp%3Bdesc)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2147459%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F251255%22%20target%3D%22_blank%22%3E%40DavidFlir%3C%2FA%3E%3C%2FP%3E%0A%3CP%3Egpio-uclass.c%E3%81%AE%E9%96%A2%E6%95%B0%E3%82%92%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22danielchen_0-1754466845499.png%22%20style%3D%22width%3A%20508px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22danielchen_0-1754466845499.png%22%20style%3D%22width%3A%20508px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F351147i085969AFCEEE1C56%2Fimage-dimensions%2F508x512%3Fv%3Dv2%22%20width%3D%22508%22%20height%3D%22512%22%20role%3D%22button%22%20title%3D%22danielchen_0-1754466845499.png%22%20alt%3D%22danielchen_0-1754466845499.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%80%E3%83%8B%E3%82%A8%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2147455%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20uboot%20-%20Device%20tree%20binding%20and%20dm_gpio_lookup_name(%22x%22%2C%26amp%3Bdesc)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2147455%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%A7%81%E3%81%AF%E6%AC%A1%E3%81%AE%E4%BE%8B%E3%81%AB%E6%B0%97%E3%81%A5%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%3A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fnxp-imx%2Fuboot-imx%2Fblob%2F9383f8387dc76524524da69992db96c22195a57c%2Fboard%2Ffreescale%2Fimx91_evk%2Fimx91_evk.c%23L305%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3Ehttps%3A%2F%2Fgithub.com%2Fnxp-imx%2Fuboot-imx%2Fblob%2F9383f8387dc76524524da69992db96c22195a57c%2Fboard%2Ffreescale%2Fimx91_evk%2Fimx91_evk.c%23L305%3C%2FA%3E%3C%2FP%3E%3CDIV%3E%3CBLOCKQUOTE%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3Eret%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3Edm_gpio_lookup_name%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E%22adp5585-gpio4%22%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Eexp_sel_desc%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FBLOCKQUOTE%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%8CgpioX_Y%E3%80%8D%E3%81%AE%E4%BB%96%E3%81%AB%E8%A8%B1%E5%8F%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%BD%A2%E5%BC%8F%E3%81%AE%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%81%9D%E3%82%8C%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%09adp5585%3A%20io-expander%4034%20%7B%0A%09%09compatible%20%3D%20%22adi%2Cadp5585-00%22%2C%20%22adi%2Cadp5585%22%3B%0A%09%09reg%20%3D%20%26lt%3B0x34%26gt%3B%3B%0A%09%09%23gpio-cells%20%3D%20%26lt%3B2%26gt%3B%3B%0A%09%09gpio-controller%3B%0A%09%09%23pwm-cells%20%3D%20%26lt%3B3%26gt%3B%3B%0A%09%09gpio-reserved-ranges%20%3D%20%26lt%3B5%201%26gt%3B%3B%0A%0A%09%09exp-sel-hog%20%7B%0A%09%09%09gpio-hog%3B%0A%09%09%09gpios%20%3D%20%26lt%3B4%20GPIO_ACTIVE_HIGH%26gt%3B%3B%0A%09%09%09output-low%3B%0A%09%09%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E3%81%A7%E3%81%AF%E3%80%81%E6%A7%8B%E6%96%87%E3%81%8C%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81%E3%80%8C_%E3%80%8D%E3%81%BE%E3%81%9F%E3%81%AF%E3%80%8C-%E3%80%8D%E3%81%A7%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B...%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2147232%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20uboot%20-%20Device%20tree%20binding%20and%20dm_gpio_lookup_name(%22x%22%2C%26amp%3Bdesc)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2147232%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%83%87%E3%83%93%E3%83%83%E3%83%89%3A%3C%2FP%3E%0A%3CP%3Edm_gpio_lookup_name()%20%E9%96%A2%E6%95%B0%E3%81%AF%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20%E3%83%84%E3%83%AA%E3%83%BC%E3%81%8B%E3%82%89%20gpio%20%E5%90%8D%E3%81%BE%E3%81%9F%E3%81%AF%E8%A1%8C%E5%90%8D%E3%82%92%E8%A7%A3%E6%9E%90%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%80%8CgpioX_Y%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E5%BD%A2%E5%BC%8F%E3%81%AE%E3%81%BF%E7%90%86%E8%A7%A3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EX%E3%81%AFGPIO%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%A7%E3%81%99%3C%2FP%3E%0A%3CP%3EY%E3%81%AF%E3%83%94%E3%83%B3%E7%95%AA%E5%8F%B7%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ELinux%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%EF%BC%88U-BOOT%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%EF%BC%89%E3%81%A7%E4%BD%9C%E6%A5%AD%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3C!--ScriptorStartFragment--%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CSPAN%3E%E6%A7%8B%E9%80%A0%E4%BD%93%3C%2FSPAN%3E%3CSPAN%3Egpio_desc%3C%2FSPAN%3E%20%3CSPAN%3E*%3C%2FSPAN%3E%20%3CSPAN%3Erst_gpio%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CSPAN%3Erst_gpio%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3Edevm_gpiod_get%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Epdev%3C%2FSPAN%3E%20%3CSPAN%3E-%26gt%3Bdev%3C%2FSPAN%3E%20%3CSPAN%3E%2C%3C%2FSPAN%3E%20%3CSPAN%3E%22reset%22%3C%2FSPAN%3E%20%3CSPAN%3E%2C%3C%2FSPAN%3E%20%3CSPAN%3EGPIOD_OUT_LOW%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CP%3E%3CLI-WRAPPER%3E%3CSPAN%3E%3C!--ScriptorEndFragment--%3E%3C%2FSPAN%3E%3C%2FLI-WRAPPER%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EDTS%E3%81%A7%E5%AE%9A%E7%BE%A9%E3%81%99%E3%82%8B%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3C!--ScriptorStartFragment--%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CSPAN%3E%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3C%2FSPAN%3E%3CSPAN%3E-%3C%2FSPAN%3E%20%3CSPAN%3Egpios%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E%26lt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Egpio1%3C%2FSPAN%3E%20%3CSPAN%3E8%3C%2FSPAN%3E%20%3CSPAN%3EGPIO_ACTIVE_LOW%3C%2FSPAN%3E%20%3CSPAN%3E%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CDIV%20class%3D%22scriptor-paragraph%22%3E%3CSPAN%3Egpio%3C%2FSPAN%3E%20%3CSPAN%3E-%3C%2FSPAN%3E%3CSPAN%3E%E5%90%8D%E5%89%8D%3C%2FSPAN%3E%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3E%22%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%22%3C%2FSPAN%3E%20%3CSPAN%3E%3B%3C%2FSPAN%3E%3C%2FDIV%3E%0A%3CP%3E%3CLI-WRAPPER%3E%3CSPAN%3E%3C!--ScriptorEndFragment--%3E%3C%2FSPAN%3E%3C%2FLI-WRAPPER%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%80%E3%83%8B%E3%82%A8%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2146268%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20uboot%20-%20Device%20tree%20binding%20and%20dm_gpio_lookup_name(%22x%22%2C%26amp%3Bdesc)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2146268%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3E_defconfig%3C%2FSTRONG%3E%E8%A8%AD%E5%AE%9A%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%89%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E5%88%86%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CDIV%3E%3CBLOCKQUOTE%3E%3CDIV%3E%3CSPAN%3ECONFIG_IMX_RGPIO2P%3Dy%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FBLOCKQUOTE%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%3CSPAN%3E%E3%81%93%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A7%E7%A7%81%E3%81%AF%E6%88%90%E5%8A%9F%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CBLOCKQUOTE%3E%3CDIV%3E%3CSPAN%3Eret%3C%2FSPAN%3E%20%3CSPAN%3E%3D%3C%2FSPAN%3E%20%3CSPAN%3Edm_gpio_lookup_name%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3E%22gpio1_8%22%3C%2FSPAN%3E%20%3CSPAN%3E%E3%80%81%3C%2FSPAN%3E%20%3CSPAN%3E%26amp%3B%3C%2FSPAN%3E%20%3CSPAN%3Edesc%3C%2FSPAN%3E%20%3CSPAN%3E)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FBLOCKQUOTE%3E%3CDIV%3E%3CSPAN%3E%3CBR%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81.dts%E3%81%A7%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%9F%E5%90%8D%E5%89%8D%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%ABCAN%E4%BD%BF%E7%94%A8%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%8B%E3%81%AF%E3%81%BE%E3%81%A0%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%81%AE%3CEM%3Egpio1_8%20%E3%81%AE%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FEM%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CSPAN%3E%60%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
