I would like to use ustreamer with imx8 hardware encoder/decoder functionality.
it is possible to use for imx8 ? can you provide any suggetion on this?
https://github.com/pikvm/ustreamer, source that is used for raspberry pi board for streaming purpose.
Any help will be appreciable.
Thanks & Regards
Hi @Bio_TICFSL ,
Any pointer on the above would be helpful.
Hi @Bio_TICFSL ,
Can you help ?
Hello r_trivedi123
If this ustreamer is µStreamer (ustreamer) is a lightweight and very quick server to stream MJPG video from any V4L2 device to the network, yes it can support by every i.MX8.
Thank you for your reply.
Did test with µStreamer for iMX8MM board, and it works fine with the camera input.
I have taken the dmesg logs for VPU logs entry to check its usage and found that µStreamer is not using the VPU for encoding.
I found that µStreamer uses the omx for encoding.
It is possible to get VPU(H/W) encoding with µStreamer? Any pointers in this ?
Any help will be appreciated.
