uSDHCx_VEND_SPEC changing CD_POL bit in uboot or device tree
已解决
跳至解决方案
1,630 次查看
deljo_davis
I have a customised Imx6ull board. Imx6ull default uSDHC1 card detect is active low deafult but in our case SD card connector have active high card detect signal. So in my case till uboot only load after that error message will come. I have to make the CD_POL bit at uSDHCx_VEND_SPEC to 1 so that CD will become active high But i dont know where this change need to done. I think changing either in device tree or uboot will work. Anybody know where to change this bit?
标签 (1)
1 解答
1,592 次查看
deljo_davis
Resolved this thing. in device tree under uSDHC1 section CD pin gave as ACTIVE HIGH.
在原帖中查看解决方案
2 回复数
1,593 次查看
deljo_davis
1,592 次查看
gusarambula
Hello Deljo Davis,
Thank you for sharing your findings. I'm sure they will help other community users.
