Hi igor
thank you for the tips
i have questions
1) Ok i can program spi-nor with uuu , but i still need u-boot , what i found is "mx6sxsabresd_emmc/qspi2/def_config ...
so i think i need u-boot defconfig i mean mx6sxsabresd_spi_defconfig .someting like that
am i wrong ?
2) a board will have a spi_nor , network ,usb-slave, emmc , so first i boot with nfs and program emmc and dump with dd,
, with that binary file i plan to write emmc by mmc write command ...doesn't it work ?
with imx6sx-evk with emmc , i booted from qspi-nor withn nfs rootfs and will try to do what i said above
if i am wrong please let me know
thank you ..
i just wonder if i dump emmc image and have binary files
you mean that i can't use "mmc wirte " command
