u-boot bootcount functionality
2,128 次查看
AB22
I have made the following modifications to the u-boot configuration (Yocto Scarthgap/i.MX8M Plus):
CONFIG_BOOTCOUNT=y
CONFIG_BOOTCOUNT_LIMIT=y
CONFIG_BOOTCOUNT_BOOTLIMIT=3
Every time I printenv bootcount at the u-boot prompt, the value is 1. I would like for the bootcount functionality to indicate when to fallback to a working partition during dual-copy update (SWUpdate) in the event the boot process repeatedly fails. What conditions cause the bootcount to increment? I can corrupt files and cause a stall at the u-boot prompt but nothing is providing a mechanism to initiate fallback.
2,094 次查看
Manuel_Salas
Hello @AB22
I hope you are doing very well.
You can see the bootcount_env.c file under uboot-imx/drivers/bootcount.
// SPDX-License-Identifier: GPL-2.0+
 * (C) Copyright 2013
 * Heiko Schocher, DENX Software Engineering, hs@denx.de.
#include <common.h>
#include <env.h>
void bootcount_store(ulong a)
	int upgrade_available = env_get_ulong("upgrade_available", 10, 0);
	if (upgrade_available) {
		env_set_ulong("bootcount", a);
		env_save();
ulong bootcount_load(void)
	ulong val = 0;
		val = env_get_ulong("bootcount", 10, 0);
	return val;
You need to set the environment variable called upgrade_available on your U-boot.
u-boot=> setenv upgrade_available 1
After reset:
u-boot=> printenv bootcount
bootcount=2
I hope this can helps to you.
Salas.
4 回复数
2,095 次查看
Manuel_Salas
Hello @AB22
#include <common.h>
#include <env.h>
		env_save();
	ulong val = 0;
	return val;
After reset:
bootcount=2
Salas.
2,091 次查看
AB22
Thank you for pointing me to that file. It is quite helpful.
2,109 次查看
xacov
It should not be a question.
config BOOTCOUNT_ENV
bool "Boot counter in environment"
help
  If no softreset save registers are found on the hardware
  "bootcount" is stored in the environment. To prevent a
  saveenv on all reboots, the environment variable
  "upgrade_available" is used. If "upgrade_available" is
  0, "bootcount" is always 0. If "upgrade_available" is 1,
          "bootcount" is incremented in the environment.
  So the Userspace Application must set the "upgrade_available"
  and "bootcount" variables to 0, if the system booted successfully.
2,090 次查看
AB22
That is quite helpful. I misunderstood the usage of upgrade_available. Thank you.
%3CLINGO-SUB%20id%3D%22lingo-sub-2035853%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eu-boot%20bootcount%E5%8A%9F%E8%83%BD%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2035853%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%AF%B9%20u-boot%20%E9%85%8D%E7%BD%AE%EF%BC%88Yocto%20Scarthgap%2Fi.MX8M%20Plus%EF%BC%89%E5%81%9A%E4%BA%86%E4%BB%A5%E4%B8%8B%E4%BF%AE%E6%94%B9%EF%BC%9A%3C%2FP%3E%3CP%3ECONFIG_BOOTCOUNT%3Dy%3CBR%20%2F%3E%20CONFIG_BOOTCOUNT_LIMIT%3Dy%3CBR%20%2F%3E%20CONFIG_BOOTCOUNT_BOOTLIMIT%3D3%3C%2FP%3E%3CP%3E%E6%AF%8F%E6%AC%A1%E6%88%91%E5%9C%A8%20u-boot%20%E6%8F%90%E7%A4%BA%E7%AC%A6%E4%B8%8B%20printenv%20bootcount%20%E6%97%B6%EF%BC%8C%E5%85%B6%E5%80%BC%E9%83%BD%E6%98%AF%201%E3%80%82%E6%88%91%E5%B8%8C%E6%9C%9B%20bootcount%20%E5%8A%9F%E8%83%BD%E8%83%BD%E5%A4%9F%E6%8C%87%E7%A4%BA%E5%9C%A8%E5%90%AF%E5%8A%A8%E8%BF%87%E7%A8%8B%E5%8F%8D%E5%A4%8D%E5%A4%B1%E8%B4%A5%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E4%BD%95%E6%97%B6%E5%9C%A8%E5%8F%8C%E5%89%AF%E6%9C%AC%E6%9B%B4%E6%96%B0%EF%BC%88SWUpdate%EF%BC%89%E6%9C%9F%E9%97%B4%E5%9B%9E%E9%80%80%E5%88%B0%E5%B7%A5%E4%BD%9C%E5%88%86%E5%8C%BA%E3%80%82%E4%BB%80%E4%B9%88%E6%83%85%E5%86%B5%E4%BC%9A%E5%AF%BC%E8%87%B4%E5%90%AF%E5%8A%A8%E8%AE%A1%E6%95%B0%E5%A2%9E%E5%8A%A0%EF%BC%9F%E6%88%91%E5%8F%AF%E4%BB%A5%E6%8D%9F%E5%9D%8F%E6%96%87%E4%BB%B6%E5%B9%B6%E5%9C%A8%20u-boot%20%E6%8F%90%E7%A4%BA%E7%AC%A6%E4%B8%8B%E5%AF%BC%E8%87%B4%E5%81%9C%E9%A1%BF%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E4%B8%9C%E8%A5%BF%E6%8F%90%E4%BE%9B%E5%90%AF%E5%8A%A8%E5%9B%9E%E9%80%80%E7%9A%84%E6%9C%BA%E5%88%B6%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2035853%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208%20%E7%B3%BB%E5%88%97%20%7C%20i.MX%208QuadMax%20(8QM)%20%7C%208QuadPlus%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2036228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9Au-boot%20bootcount%E5%8A%9F%E8%83%BD%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2036228%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E8%BF%99%E9%9D%9E%E5%B8%B8%E6%9C%89%E5%B8%AE%E5%8A%A9%E3%80%82%E6%88%91%E8%AF%AF%E8%A7%A3%E4%BA%86upgrade_available%E7%9A%84%E7%94%A8%E6%B3%95%E3%80%82%E8%B0%A2%E8%B0%A2%E3%80%82%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2036227%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9Au-boot%20bootcount%E5%8A%9F%E8%83%BD%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2036227%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%90%91%E6%88%91%E6%8C%87%E5%87%BA%E8%AF%A5%E6%96%87%E4%BB%B6%E3%80%82%E8%BF%99%E5%BE%88%E6%9C%89%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FLINGO-BODY%3E
