u-boot.bin offset zero of pNOR in iMX6
1,124 次查看
victordamptey
I have noticed a 4 byte data at offset zero of u-boot.bin intended for loading in pNOR.  iMX6 IVT makes no mention of any data being at below offset 0x1000. Can anyone tell me what it's used for?
sample:
  0: C6 04 00 EA 00 00 ....
10: 00 00 00 00 00 .....
1000: D1 00 20 40 ......
标记 (4)
1 回复
1,006 次查看
alejandrolozan1
The data found at that offset should not affect the BootROM code. The image should be at 0x1000 offset just like you mentioned.
Alejandro
