We use IMX6D6AVT10AD . I want to know the highest temperature that we can Safe to use.
Hi haitao
max. temperature is defined parameters given in Table 6. Operating Ranges
for junction temperature
http://www.nxp.com/docs/en/data-sheet/IMX6DQCEC.pdf
also please check AN4579 i.MX6 Series Thermal Management Guidelines
http://www.nxp.com/docs/en/application-note/AN4579.pdf
hello
I have a problem. I saw that the ODT settings (MPODTCTRL). So i want to know if set it to 0x00007 or set it to 0x11117. Will there be any hidden trouble?
