surroundview based on qnx bsp
2,507 次查看
yafengge126
Hi, li-sir
Do you have surroundview driver which runs on nxp chips based on qnx system? if you have can you please tell me how to get it? thanks a lot!
以下中文
請問貴公司是否有基於qnx bsp的surroundview driver驅動程序?如果有在哪裏能拿到這些資料,謝謝!
标记 (1)
2,333 次查看
yafengge126
Hello, Joan
请问,下面NXP S32V234 (TreeRunner)这个平台上基于qnx的4路视频输入驱动,是nxp的资产还是黑莓的资产?
详情请看下面连接:
http://www.qnx.com/developers/docs/7.0.0/index.html#com.qnx.doc.adas.getting_started.overview/topic/...
谢谢!!
2,333 次查看
joanxie
如果你说reference image的话,那应该是黑莓的,硬件板子应该是nxp的,如果你感兴趣这款芯片,建议你去对应的论坛提问,有相应支持的工程师会给你更详细的解答,因为这里是IMX的论坛,所以可能回答未必正确
2,333 次查看
joanxie
unforuntately, we don't have surroundview demo code on the qnx system
