stty line discipline 0 not supported
fabio_poiatti
Hi, I'm using the uart port /dev/ttymxc1 connected to a modem ... the connection working well till for a misconfigurationd the line parameter of the uart change to 3
when I try to reset the value to 0, the command said
root@console=ttymxc0,115200 root=/dev/mmcblk1p2 rootwait rw:/etc# stty -F /dev/ttymxc1 line 0
stty: number 0 is not in 1..2147483647 range
Any suggestion?
Fabio
karangajjar
Senior Contributor II
Hi fabio mario poiatti,
Can you please let us know the board, yocto and kernel version that you are using?
Also, please let us know the setup and steps you followed to reproduce the issue.
Karan Gajjar
fabio_poiatti
I'm using the EVK IMX6ULL with
Linux version 4.14.78-imx_4.14.78_1.0.0_ga+g94da7bdc489b (oe-user@oe-host) (gcc version 7.3.0 (GCC)) #1 SMP PREEMPT Fri May 10 14:32:15 UTC 2019
I connected the uart with an external modem and configured by stty command
Now I avoided the problem connecting the modem by micro usb
Fabio
