srktool - number of fuses per word
1,532 次查看
antonio_santagi
I am using imX8M mini.
when launching srktool  , what setting should I choose for the number of fuses per word ? 8 fuses per word or 32 fuses per word ?
-f, --fuse_format <format>:
Optional, Data format of the SRK efuse binary file. The
format may be selected by setting <format> to either:
- 0: 8 fuses per word, ex: 00 00 00 0a 00 00 00 01 ...
- 1 (default): 32 fuses per word, ex: 0a 01 ff 8e
thank you
标记 (3)
2 回复数
1,448 次查看
Yuri
   default  value for -f parameter  - 1 (default): 32 fuses per word  is usually used.
       $ ../linux64/bin/srktool -h 4 -t SRK_1_2_3_4_table.bin -e SRK_1_2_3_4_fuse.bin -d
       sha256 -c SRK1_sha256_2048_65537_v3_ca_crt.pem,
       SRK2_sha256_2048_65537_v3_ca_crt.pem,
       SRK3_sha256_2048_65537_v 3_ca_crt.pem,
       SRK4_sha256_2048_65537_v3_ca_crt.pem
Yuri.
1,448 次查看
antonio_santagi
Ok, I will use 32 fuses per word then, thank you.
