spi to ethernet
spi to ethernet
2,690 次查看
sandeep_c
hi everyone i need to communicate from spi (rt1170) to (tcp/ip (lwip stack)) to ethernet (KSZ8081RNB)
I am new to this can any one suggest me how to do that or any reference material
Thank you
5 回复数
2,659 次查看
sandeep_c
SPI TO ENET i havent found in mcuxpresso IDE if you k now please share the link
thank you
2,663 次查看
sandeep_c
iam sending and recieving data packets through spi only my slave automatically converts to ethernet which is recieved in the form spi slave is IC is jsz885snl
could you send any resources to understand lwip protocol how data will send and which order data will send so that i can understand how the lwip stack willl work
2,648 次查看
Omar_Anguiano
These resources can be helpful to become familiar with lwip:
Brief Introduction to LwIP stack in MCUXpresso SDK - NXP Community
lwIP Wiki | Fandom
Regarding SPI to ENET, there is no specific example of both protocols combined, however, you can merge the two protocols in your application by referring to the separate examples of the protocols.
Omar
2,673 次查看
Omar_Anguiano
Hello
I hope you are well.
I suggest you take as reference the SPI and ENET examples from the SDK.
What are you trying to implement? Are you trying to receive data from the SPI interface and send the received data through ethernet?
Omar
2,630 次查看
sandeep_c
i am sending and receiving data packets through spi interface only, my slave (KSZ8851snl) automatically converts to ethernet
