silicon revision and status of IMX8QXP PIMX8QX6AVLFZAB
rameshasp
Hello Team,
Can you please provide me the silicon revision and status of IMX8QXP PIMX8QX6AVLFZAB.
Thanks & Regards,
Ramesha S P
rameshasp
ok as you said i have created one more thread for the DDR stress test related.
rameshasp
Thanks for your feedback Igor,
Currently we have Si B0 part processor IMX8QXP-CPU EVK board but In EVK we are able to do DDR stress test and we are getting log also. Why we are not able to do DDR stress test in our custom board having Si B0 IMX8QXP processor.
Attached logs from EVK and Custom board. Kindly check and provide the steps further.
For Production we will use Si C0 revision processor part. Now we have to prove the working of this proto boards with Si B0. Please suggest to proceed further.
Hi Ramesha
please create new thread for this new problem.
Hi Ramesha
this is old rev.B0 part, recommended to use latest C0 revision, part
numbers can be found in Table 2. i.MX 8QuadXPlus Orderable part numbers
i.MX 8QuadXPlus and 8DualXPlus Industrial Applications Processors - Data Sheet
i.MX 8X C0 Migration Guide Migrating from i.MX 8X B0 to i.MX 8X C0
