I do it as up following,but always fault,
i wander why.
 iris_wen
			iris_wen
Executeing this instruction which is fault
so the back instructon still fault.
 iris_wen
			iris_wen
		Do you really follow the steps I provided?
The first step is to save the attachment in ~/bin. Then the repo is already in your computer. You don't need to download again.
Remember to unzip the attachment...ONLY copy the file repo in ~/bin...
first ,what is attachment?
where is the attachment?
and can you give me specfications ?
 joanxie
			joanxie
		maybe you can refer to the link as below, get the repo from tsinghua
"https://mirrors.tuna.tsinghua.edu.cn/help/git-rep"
I suggest that you can update to the latest version, some packages in the git.freescale.com are removed, if you build the 3.14.28, maybe you will get the connection error even if you can repo sync successfully, I have built 4.14.52 successfully before, but I don't know if you can get 3.14.28 source package or not
 joanxie
			joanxie
i download L4.1.15 still fault
 joanxie
			joanxie
		as I mentioned before, the source code was removed from git.freescale.com, maybe you can refer to my another document
still fault
 joanxie
			joanxie
		do you mind reading my document again? as I mentioned, you couldn't use git.freescale.com, try to use the new command as my document mentions
still fault
 joanxie
			joanxie
		I don't find any error according to the pic you attached
 iris_wen
			iris_wen
		Hi Baobing,
Did you reboot or source the .bashrc file by the following command?
$ source ~/.bashrc
 iris_wen
			iris_wen
		If the instruction in user guide is not detailed enough, please follow this link.
hi ,that is still false
 iris_wen
			iris_wen
		Could you please share the log?
