server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none
15,475 次查看
shamiullah
Hello everyone,
I am trying to compile the I.MX6UL yocto source. I Have previously compiled the source, at that time it compiled without any issues. When I am compiling the same source I am getting the issues regarding certificates
ERROR:
fatal: unable to access 'https://source.codeaurora.org/external/imx/wayland-protocols-imx.git/': server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none
The whole error is attached as a document. Can you please know the solution on how to resolve
Thanks in Advance
标签 (2)
15,400 次查看
nxf63675
Hi shamiullah,
After a quick check I see that this happens because the repository get lost, and needs to be updated, so please I recommend you update all your programs and drivers, this depends on your machine for Ubuntu is sudo apt update, sudo apt upgrade.
After you update and upgrade all your programs update your repository, on your build directory do the repo sync, to update to the latest code.
Israel.
4 回复数
15,446 次查看
nxf63675
Hi shamiullah,
Which BSP version are you using?
Israel.
15,442 次查看
shamiullah
Hi Israel,
We are using 5.4 zeus version yocto and kernel 5.4. We use to download previously with the same link and can be able to compile. But At present we are facing issues with the same link.Can you please look into it?
Thanks & Regards,
Shamiullah
15,401 次查看
nxf63675
Hi shamiullah,
Israel.
15,352 次查看
shamiullah
Hi Israel,
Thank you for the suggestion, it worked for me by running the below commands
$ sudo apt update
$ sudo apt upgrade
Thanks & Regards,
Shamiullah
