We failed to build SDK(imx-fsl-4.14.98-2.0.0_ga). Please help to give me some advice.
/home/lmy/imx-fsl/imx-fsl-4.14.98-2.0.0_ga/build-imx6dl-fb/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/glibc/2.27-r0/recipe-sysroot-native/usr/bin/arm-poky-linux-gnueabi.gcc-cross-initial-arm/../../libexec/arm-poky-linux-gnueabi.gcc-cross-initial-arm/gcc/arm-poky-linux-gnueabi/7.3.0/ld:/home/lmy/imx-fsl/imx-fsl-4.14.98-2.0.0_ga/build-imx6dl-fb/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/glibc/2.27-r0/build-arm-poky-linux-gnueabi/shlib.lds:155: syntax error
collect2: error: ld returned 1 exit status
make[2]: *** [/home/lmy/imx-fsl/imx-fsl-4.14.98-2.0.0_ga/build-imx6dl-fb/tmp/work/cortexa9hf-neon-poky-linux-gnueabi/glibc/2.27-r0/build-arm-poky-linux-gnueabi/libc.so] Error 1
Host version: ubuntu18.04LTS 64bit。
build option:DISTRO=fsl-imx-fb MACHINE=imx6dlsabresd source fsl-setup-release.sh -b build-imx6dl-fb
We modified build-imx6dl-fb/conf/local.conf and adding qtwebengine to support :IMAGE_INSTALL_append = "packagegroup-qt5-webengine"
build command:bitbake fsl-image-qt5-validation-imx
