Hello everyone,
When i am trying to build compiler by using Yocto DISTRO ?= 'fsl-imx-fb' but there is error as i mentioned on the question keeps popping in while the progress is still going on. Compilation can not be finished. how can i fix this issue? Configuration files and error message can be reach by the link below.
thank you in advance.
http://textuploader.com/d1j6c local config
http://textuploader.com/d1jja error message
