Hello
My requirement -- was to Remove the package alsa from the Yocto Build. So
I just tried to Remove the ALSA Packages from the Yocto Build.
I followed same procedure as you stated
1. MACHINE_FEATURES_remove = "alsa" on your machine.conf
2. poky.conf, used DISTRO_FEATURES_remove = "alsa".
But it removed some of the alsa packages in rootfs looks good, these alsa-lib, alsa-conf still exists in the tmp/deploy/licenses/machine/licence.manifest file
Can any one suggest me the way to Remove that from Yocto Build.
