remove element dynamic pipelines
2,050 次查看
neohong
Hi all,
     I use tee element for dual video output and my pipeline like this :
                        / [ queue1 | v4l2sink1]   branch 1
                tee
                        \ [ queue2 | v4l2sink2]    branch 2
Now I want to remove v4l2sink1 and add it to pipeline again. First,
blockpad = gst_element_get_static_pad(queue1,NULL);
gst_pad_add_probe (blockpad , (GstPadProbeType)GST_PAD_PROBE_TYPE_BLOCK_DOWNSTREAM , pad_probe_cb, user_data, NULL);
gst_pad_remove_probe (blockpad , GST_PAD_PROBE_INFO_ID (info));
And then, in the callback pad_probe_cb() ,
sinkpad = gst_element_get_static_pad (v4l2sink1, "sink");
gst_pad_send_event (sinkpad, gst_event_new_eos ());
gst_pad_remove_probe (sinkpad, GST_PAD_PROBE_INFO_ID (info));
gst_element_set_state (v4l2sink1, GST_STATE_NULL);
gst_bin_remove (GST_BIN (pipeline),v4l2sink1);
Problems has occured that neither branch1 nor branch2  has no videos on screen with the pipeline is playing and the audio output is ok.
It seems that the videostreams was block by adding a probe .    At the same time , the branch2 seems receive block message too.
Pls tell me how to fix this problem .Any reply is appreciated .
标签 (4)
1,782 次查看
joanxie
maybe your pipeline go to PAUSE state, I send the document for dynamic pipelines, hope helpful for you
Dynamically changing the pipeline
1,783 次查看
joanxie
1,782 次查看
neohong
Thanks for your reply .I have removed/added elements frome a pipeline successfully.
