My question is related to document IMX6DQ6SDLHDG (Hardware Development guide for i.MX6...) On page 4-2 in Table 4-1 in the 'Notes' column it appears that the note for row 1 and row 2 are the same, where instead I would expect the note to refer to VDDARM23_CAP instead of VDDARM23_IN.
If I am using an i.MX6D instead of an i.MX6Q, then according to the note of row 1 I should connect VDDARM23_IN to ground. But the note for row 2 does not tell me what to do with VDDARM23_CAP if I am using an i.MX6D. Please help.
Solved! Go to Solution.
Hi Fred,
Thanks for noticing that. For dual operation, you have to connect VDDARM23_CAP to GND. I'll get that note corrected. Please also see section 4.2 of app note AN4397 located here:
I think it'll clarify all your doubts.
Best regards.
Jorge.
Hi Fred,
Best regards.
Jorge.
