read cpu teperature at usespace in Windows 10 IOT Core on IMX8mq evk
1,506 次查看
tom_shen
Hello Experts,
    I want to read cpu teperature at usespace in Windows 10 IOT Core on IMX8mq evk. For example, in Windows 10 IOT Core on IMX8mq evk I can type readcputemp in coammnd line to get to CPU temperature. I known how to get CPU temperature at kernel space. A simple sample like below:
+#define TMU_BASE    0x30260000
+    vaddr_t tmu_base = core_mmu_get_va(TMU_BASE, MEM_AREA_IO_SEC);
+    DMSG("======== is valid: 0x%08x, cpu temperatue: %d =====", read32(tmu_base + 0x100),  read32(tmu_base + 0x100) & 0xff );
But I hope can use  command line of windows IoT core in userspace to get this CPU temperature in kernel space.
Have any simplest example that I can do that
1,389 次查看
jimmychan
Please contact Microsoft for the BSP's code support.
