"repo sync" failed to synchronize local Git repository
2,875 次查看
llr
       I want to use repo sync to synchronize my local git repository, but it seems that the prompt says I have no permissions, so it is normal for me to use git clone.
How can I solve this problem?
3 回复数
2,872 次查看
joanxie
did you do the "repo init"? fsl-community-bsp-release isn't official version, why don't you use the nxp official version?
2,869 次查看
llr
I've already run repo init -u https://source.codeaurora.org/external/imx/imx-manifest -b imx-linux-zeus -m imx-5.4.70-2.3.0.xml.
I want to upload the modified things to local git for maintenance.
Can you help me solve this problem?
2,834 次查看
joanxie
it seems the gitlab access permission issue, I think you need to find the solution from the gitlab forum, I find some links, hope helpful for you
https://gitlab.com/gitlab-org/gitlab-foss/-/issues/26710
https://gitlab.com/gitlab-org/gitlab-foss/-/issues/26194#workaround
