question about use MFGtools
29,466 次查看
eddyliu
hi all,
I am working on PCIMX6S6AVM08AB and use Mfgtools-Rel-4.1.0_130816_MX6DL_UPDATER to down load u-boot uImage and fs to eMMC.
in my ucl2.xml:
Header 1
<LIST name="i.MX6SOLO-SABRESD-SD" desc="Choose SD as media">
    <CMD state="BootStrap" type="boot" body="BootStrap" file ="u-boot-mx6solo-sabresd.bin" >Loading U-boot</CMD>
    <CMD state="BootStrap" type="load" file="uImage" address="0x10800000"
        loadSection="OTH" setSection="OTH" HasFlashHeader="FALSE" >Loading Kernel.</CMD>
    <CMD state="BootStrap" type="load" file="initramfs.cpio.gz.uboot" address="0x10C00000"
        loadSection="OTH" setSection="OTH" HasFlashHeader="FALSE" >Loading Initramfs.</CMD>
    <CMD state="BootStrap" type="jump" > Jumping to OS image. </CMD>
    <CMD state="Updater" type="push" body="$ ls /dev/">ls -l /dev/</CMD>
on terminal:
Header 1
U-Boot 2009.08 (Aug 16 2013 - 15:02:51)
CPU: Freescale i.MX6 family TO1.1 at 792 MHz
Thermal sensor with ratio = 188
Temperature:   40 C, calibration data 0x5a34e87d
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
ipg clock     : 66000000Hz
ipg per clock : 66000000Hz
uart clock    : 80000000Hz
cspi clock    : 60000000Hz
ahb clock     : 132000000Hz
axi clock   : 198000000Hz
emi_slow clock: 99000000Hz
ddr clock     : 396000000Hz
usdhc1 clock  : 198000000Hz
usdhc2 clock  : 198000000Hz
usdhc3 clock  : 198000000Hz
usdhc4 clock  : 198000000Hz
nfc clock     : 24000000Hz
Board: i.MX6DL/Solo-SABRESD: unknown-board Board: 0x61011 [POR ]
Boot Device: MMC
I2C:   ready
DRAM:  512 MB
MMC:   FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3
Using default environment
In:    serial
Out:   serial
Err:   serial
Net:   got MAC address from IIM: 00:00:00:00:00:00
FEC0 [PRIME]
Hit any key to stop autoboot:  0
## Booting kernel from Legacy Image at 10800000 ...
   Image Name:   Linux-3.0.35-2666-gbdde708
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3165516 Bytes =  3 MB
   Load Address: 10008000
   Entry Point:  10008000
   Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at 10c00000 ...
   Image Name:   uboot initramfs rootfs
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    4545326 Bytes =  4.3 MB
   Load Address: 00000000
   Entry Point:  00000000
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 3.0.35-2666-gbdde708 (r65388@shlinux3) (gcc version 4.6.2 20110630 (prerelease) (Freescale MAD -- Linaro 2011.07 -- Built at 2011/08/10 09
:20) ) #1 SMP PREEMPT Fri Aug 16 14:34:30 CST 2013
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Freescale i.MX 6Quad/DualLite/Solo Sabre-SD Board
Memory policy: ECC disabled, Data cache writealloc
CPU identified as i.MX6DL/SOLO, silicon rev 1.1
PERCPU: Embedded 7 pages/cpu @8bc06000 s5184 r8192 d15296 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 97280
Kernel command line: console=ttymxc0,115200 rdinit=/linuxrc enable_wait_mode=off nosmp
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 384MB = 384MB total
Memory: 377924k/377924k available, 146364k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xf4600000 - 0xffe00000   ( 184 MB)
    vmalloc : 0xa0800000 - 0xf2000000   (1304 MB)
    lowmem  : 0x80000000 - 0xa0000000   ( 512 MB)
    pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
    modules : 0x7f000000 - 0x7fe00000   (  14 MB)
      .init : 0x80008000 - 0x8003a000   ( 200 kB)
      .text : 0x8003a000 - 0x805ada70   (5583 kB)
      .data : 0x805ae000 - 0x805fc880   ( 315 kB)
       .bss : 0x805fc8a4 - 0x806277f4   ( 172 kB)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Preemptible hierarchical RCU implementation.
NR_IRQS:624
MXC GPIO hardware
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
Set periph_clk's parent to pll2_pfd_400M!
arm_max_freq=800MHz
MXC_Early serial console at MMIO 0x2020000 (options '115200')
bootconsole [ttymxc0] enabled
Console: colour dummy device 80x30
Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
Brought up 1 CPUs
SMP: Total of 1 processors activated (1581.05 BogoMIPS).
print_constraints: dummy:
NET: Registered protocol family 16
print_constraints: vddpu: 725 <--> 1300 mV at 700 mV fast normal
print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast normal
print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast normal
print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast normal
print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast normal
print_constraints: vdd3p0: 2625 <--> 3400 mV at 3000 mV fast normal
hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step.
hw-breakpoint: maximum watchpoint size is 4 bytes.
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x02050000, Cache size: 524288 B
bio: create slab <bio-0> at 0
mxs-dma mxs-dma-apbh: initialized
print_constraints: SPKVDD: 4200 mV
print_constraints: vmmc: 3300 mV
SCSI subsystem initialized
spi_imx imx6q-ecspi.0: probed
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
mc_pfuze 1-0008: recv failed!:-5,80
mc_pfuze: probe of 1-0008 failed with error -1
imx-ipuv3 imx-ipuv3.0: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
Advanced Linux Sound Architecture Driver Version 1.0.24.
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
max17135 2-0048: PMIC MAX17135 for eInk display
i2c-core: driver [max17135] using legacy suspend method
i2c-core: driver [max17135] using legacy resume method
Switching to clocksource mxc_timer1
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 16384 (order: 5, 196608 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Unpacking initramfs...
Freeing initrd memory: 4436K
PMU: registered new PMU device of type 0
Static Power Management for Freescale i.MX6
wait mode is disabled for i.MX6
cpaddr = a0820000 suspend_iram_base=a08b4000
PM driver module loaded
IMX usb wakeup probe
cpu regulator mode:ldo_enable
i.MXC CPU frequency driver
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 746
cryptodev: driver loaded.
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver ldb
_regulator_get: get() with no identifier
imx-ipuv3 imx-ipuv3.0: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
Console: switching to colour frame buffer device 128x48
mxc_sdc_fb mxc_sdc_fb.1: register mxc display driver ldb
imx-sdma imx-sdma: loaded firmware 1.1
imx-sdma imx-sdma: initialized
Serial: IMX driver
imx-uart.2: ttymxc2 at MMIO 0x21ec000 (irq = 60) is a IMX
imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX
console [ttymxc0] enabled, bootconsole disabled
loop: module loaded
m25p80 spi0.0: unrecognized JEDEC id ffffff
GPMI NAND driver registered. (IMX)
vcan: Virtual CAN interface driver
FEC Ethernet Driver
fec_enet_mii_bus: probed
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
ARC USBOTG Device Controller driver (1 August 2005)
add wake up source irq 75
g_file_storage gadget: controller 'fsl-usb2-udc' not recognized
check_parameters:UTP settings are in place now, overriding defaults
g_file_storage gadget: No serial-number string provided!
g_file_storage gadget: File-backed Storage Gadget, version: 1 September 2010
g_file_storage gadget: Number of LUNs=1
fsl-usb2-udc: bind to driver g_file_storage
mousedev: PS/2 mouse device common for all mice
egalax_ts 1-0004: egalax_ts: failed to read firmware version
egalax_ts: probe of 1-0004 failed with error -5
egalax_ts 2-0004: egalax_ts: failed to read firmware version
egalax_ts: probe of 2-0004 failed with error -5
snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0
i2c /dev entries driver
Linux video capture interface: v2.00
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17
mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video18
imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1)
Bluetooth: Virtual HCI driver ver 1.3
Bluetooth: Generic Bluetooth USB driver ver 0.6
usbcore: registered new interface driver btusb
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
mmc0: SDHCI controller on platform [sdhci-esdhc-imx.3] using ADMA
mmc1: SDHCI controller on platform [sdhci-esdhc-imx.1] using ADMA
mmc2: SDHCI controller on platform [sdhci-esdhc-imx.2] using ADMA
mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
VPU initialized
mxc_asrc registered
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
Cirrus Logic CS42888 ALSA SoC Codec Driver
i2c-core: driver [cs42888] using legacy suspend method
i2c-core: driver [cs42888] using legacy resume method
imx-hdmi-soc-dai imx-hdmi-soc-dai.0: Failed: Load HDMI-video first.
imx_3stack asoc driver
ALSA device list:
  No soundcards found.
TCP cubic registered
NET: Registered protocol family 17
can: controller area network core (rev 20090105 abi 8)
NET: Registered protocol family 29
can: raw protocol (rev 20090105)
can: broadcast manager protocol (rev 20090105 t)
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
Bus freq driver module loaded
Bus freq driver Enabled
mxc_dvfs_core_probe
DVFS driver module loaded
regulator_init_complete: SPKVDD: incomplete constraints, leaving on
snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:00:00 UTC (0)
Freeing init memory: 200K
Starting UTP
ln: /etc/mtab: File exists
disable turn off display
Starting the hotplug events dispatcher udevd
Synthesizing initial hotplug events
udevd (2079): /proc/2079/oom_adj is deprecated, please use /proc/2079/oom_score_adj instead.
g_file_storage gadget: high speed config #1
uuc 0.4 [built Aug 16 2013 01:24:08]
UTP: Waiting for device to appear
UTP: file/device node /dev/utp already exists
cpu_id is 0
UTP: received command '$ ls /dev/'
UTP: executing "ls /dev/"
XOR                 ptyra               tty25               ttyr0
apm_bios            ptyrb               tty26               ttyr1
console             ptyrc               tty27               ttyr2
cpu_dma_latency     ptyrd               tty28               ttyr3
crypto              ptyre               tty29               ttyr4
fb                  ptyrf               tty3                ttyr5
fb0                 ptys0               tty30               ttyr6
fb1                 ptys1               tty31               ttyr7
fb2                 ptys2               tty32               ttyr8
full                ptys3               tty33               ttyr9
i2c-0               ptys4               tty34               ttyra
i2c-1               ptys5               tty35               ttyrb
i2c-2               ptys6               tty36               ttyrc
i2c-3               ptys7               tty37               ttyrd
input               ptys8               tty38               ttyre
kmem                ptys9               tty39               ttyrf
kmsg                ptysa               tty4                ttys0
loop0               ptysb               tty40               ttys1
loop1               ptysc               tty41               ttys2
loop2               ptysd               tty42               ttys3
loop3               ptyse               tty43               ttys4
loop4               ptysf               tty44               ttys5
loop5               ptyt0               tty45               ttys6
loop6               ptyt1               tty46               ttys7
loop7               ptyt2               tty47               ttys8
mem                 ptyt3               tty48               ttys9
mxc_asrc            ptyt4               tty49               ttysa
mxc_hdmi            ptyt5               tty5                ttysb
mxc_ipu             ptyt6               tty50               ttysc
mxc_mem             ptyt7               tty51               ttysd
mxc_vpu             ptyt8               tty52               ttyse
mxs_viim            ptyt9               tty53               ttysf
network_latency     ptyta               tty54               ttyt0
network_throughput  ptytb               tty55               ttyt1
null                ptytc               tty56               ttyt2
psaux               ptytd               tty57               ttyt3
ptmx                ptyte               tty58               ttyt4
pts                 ptytf               tty59               ttyt5
ptya0               ptyu0               tty6                ttyt6
ptya1               ptyu1               tty60               ttyt7
ptya2               ptyu2               tty61               ttyt8
ptya3               ptyu3               tty62               ttyt9
ptya4               ptyu4               tty63               ttyta
ptya5               ptyu5               tty7                ttytb
ptya6               ptyu6               tty8                ttytc
ptya7               ptyu7               tty9                ttytd
ptya8               ptyu8               ttya0               ttyte
ptya9               ptyu9               ttya1               ttytf
ptyaa               ptyua               ttya2               ttyu0
ptyab               ptyub               ttya3               ttyu1
ptyac               ptyuc               ttya4               ttyu2
ptyad               ptyud               ttya5               ttyu3
ptyae               ptyue               ttya6               ttyu4
ptyaf               ptyuf               ttya7               ttyu5
ptyb0               ptyv0               ttya8               ttyu6
ptyb1               ptyv1               ttya9               ttyu7
ptyb2               ptyv2               ttyaa               ttyu8
ptyb3               ptyv3               ttyab               ttyu9
ptyb4               ptyv4               ttyac               ttyua
ptyb5               ptyv5               ttyad               ttyub
ptyb6               ptyv6               ttyae               ttyuc
ptyb7               ptyv7               ttyaf               ttyud
ptyb8               ptyv8               ttyb0               ttyue
ptyb9               ptyv9               ttyb1               ttyuf
ptyba               ptyva               ttyb2               ttyv0
ptybb               ptyvb               ttyb3               ttyv1
ptybc               ptyvc               ttyb4               ttyv2
ptybd               ptyvd               ttyb5               ttyv3
ptybe               ptyve               ttyb6               ttyv4
ptybf               ptyvf               ttyb7               ttyv5
ptyc0               ptyw0               ttyb8               ttyv6
ptyc1               ptyw1               ttyb9               ttyv7
ptyc2               ptyw2               ttyba               ttyv8
ptyc3               ptyw3               ttybb               ttyv9
ptyc4               ptyw4               ttybc               ttyva
ptyc5               ptyw5               ttybd               ttyvb
ptyc6               ptyw6               ttybe               ttyvc
ptyc7               ptyw7               ttybf               ttyvd
ptyc8               ptyw8               ttyc0               ttyve
ptyc9               ptyw9               ttyc1               ttyvf
ptyca               ptywa               ttyc2               ttyw0
ptycb               ptywb               ttyc3               ttyw1
ptycc               ptywc               ttyc4               ttyw2
ptycd               ptywd               ttyc5               ttyw3
ptyce               ptywe               ttyc6               ttyw4
ptycf               ptywf               ttyc7               ttyw5
ptyd0               ptyx0               ttyc8               ttyw6
ptyd1               ptyx1               ttyc9               ttyw7
ptyd2               ptyx2               ttyca               ttyw8
ptyd3               ptyx3               ttycb               ttyw9
ptyd4               ptyx4               ttycc               ttywa
ptyd5               ptyx5               ttycd               ttywb
ptyd6               ptyx6               ttyce               ttywc
ptyd7               ptyx7               ttycf               ttywd
ptyd8               ptyx8               ttyd0               ttywe
ptyd9               ptyx9               ttyd1               ttywf
ptyda               ptyxa               ttyd2               ttyx0
ptydb               ptyxb               ttyd3               ttyx1
ptydc               ptyxc               ttyd4               ttyx2
ptydd               ptyxd               ttyd5               ttyx3
ptyde               ptyxe               ttyd6               ttyx4
ptydf               ptyxf               ttyd7               ttyx5
ptye0               ptyy0               ttyd8               ttyx6
ptye1               ptyy1               ttyd9               ttyx7
ptye2               ptyy2               ttyda               ttyx8
ptye3               ptyy3               ttydb               ttyx9
ptye4               ptyy4               ttydc               ttyxa
ptye5               ptyy5               ttydd               ttyxb
ptye6               ptyy6               ttyde               ttyxc
ptye7               ptyy7               ttydf               ttyxd
ptye8               ptyy8               ttye0               ttyxe
ptye9               ptyy9               ttye1               ttyxf
ptyea               ptyya               ttye2               ttyy0
ptyeb               ptyyb               ttye3               ttyy1
ptyec               ptyyc               ttye4               ttyy2
ptyed               ptyyd               ttye5               ttyy3
ptyee               ptyye               ttye6               ttyy4
ptyef               ptyyf               ttye7               ttyy5
ptyp0               ptyz0               ttye8               ttyy6
ptyp1               ptyz1               ttye9               ttyy7
ptyp2               ptyz2               ttyea               ttyy8
ptyp3               ptyz3               ttyeb               ttyy9
ptyp4               ptyz4               ttyec               ttyya
ptyp5               ptyz5               ttyed               ttyyb
ptyp6               ptyz6               ttyee               ttyyc
ptyp7               ptyz7               ttyef               ttyyd
ptyp8               ptyz8               ttymxc0             ttyye
ptyputp_poll: pass returned.
9               ptyz9               ttymxc2             ttyyf
ptypa               ptyza               ttyp0               ttyz0
ptypb               ptyzb               ttyp1               ttyz1
ptypc               ptyzc               ttyp2               ttyz2
ptypd               ptyzd               ttyp3               ttyz3
ptype               ptyze               ttyp4               ttyz4
ptypf               ptyzf               ttyp5               ttyz5
ptyq0               random              ttyp6               ttyz6
ptyq1               rfkill              ttyp7               ttyz7
ptyq2               rtc                 ttyp8               ttyz8
ptyq3               rtc0                ttyp9               ttyz9
ptyq4               shm                 ttypa               ttyza
ptyq5               snd                 ttypb               ttyzb
ptyq6               tracebuf            ttypc               ttyzc
ptyq7               tty                 ttypd               ttyzd
ptyq8               tty0                ttype               ttyze
ptyq9               tty1                ttypf               ttyzf
ptyqa               tty10               ttyq0               ubi_ctrl
ptyqb               tty11               ttyq1               urandom
ptyqc               tty12               ttyq2               utp
ptyqd               tty13               ttyq3               vcs
ptyqe               tty14               ttyq4               vcs1
ptyqf               tty15               ttyq5               vcsa
ptyr0               tty16               ttyq6               vcsa1
ptyr1               tty17               ttyq7               vhci
ptyr2               tty18               ttyq8               video16
ptyr3               tty19               ttyq9               video17
ptyr4               tty2                ttyqa               video18
ptyr5               tty20               ttyqb               watchdog
ptyr6               tty21               ttyqc               zero
ptyr7               tty22               ttyqd
ptyr8               tty23               ttyqe
ptyr9               tty24               ttyqf
UTP: sending Success to kernel for command $ ls /dev/.
No eMMC relative device node is found in /dev/. now I want to use eMMC as  boot device, can you tell me what I can do for that?
thanks sincerely.
Message was edited by: Eddy Liu
标记 (1)
26,791 次查看
GraceH
Senior Contributor II
Hi Eddy,
You need set boot parameters.  Please reference 9.2 Running the Image from MMC/SD of i.MX_6Solo6DualLite_SABRE-AI_Linux_User's_Guide.pdf to set your boot command.
Grace
17 回复数
26,791 次查看
GraceH
Your log shows your board has no eMMC device. During kernel boot, you should see eMMC device is scanned.
regulator_init_complete: PFUZE100_VGEN6: incomplete constraints, leaving on
mmc0: new high speed DDR MMC card at address 0001
mmcblk0: mmc0:0001 SEM08G 7.39 GiB
mmcblk0boot0: mmc0:0001 SEM08G partition 1 2.00 MiB
regulator_init_complete: PFUZE100_VGEN3: incomplete constraints, leaving on
mmcblk0boot1: mmc0:0001 SEM08G partition 2 2.00 MiB
mmcblk0: p1 p2 p3 < p5 p6 p7 p8 p9 > p4
Grace
26,791 次查看
eddyliu
Hi Grace Si,
Thanks for your response. In my Log. No eMMC device is found. But I am wondering why eMMC device can not be found on my hardware board. On my hardware board eMMC device layout is same as SABRE-AI_DualLite_CPUcard which is EV kit of freescale:
On my hardware board:
On SABRE-AI_DualLite_CPUcard:
I can make sure eMMC device is working on my hardware board because QNX system can run my hardware board which use eMMC device as boot program storage space.
26,791 次查看
GraceH
Hi Eddy,
Except pin CLK, CMD, DAT0-7, you need also check whether SD3_CD and SD3_WP are correctly muxed.
static iomux_v3_cfg_t mx6dl_sabreauto_pads[] = {
/* SD3 */
MX6DL_PAD_SD3_CLK__USDHC3_CLK_50MHZ,
MX6DL_PAD_SD3_CMD__USDHC3_CMD_50MHZ,
MX6DL_PAD_SD3_DAT0__USDHC3_DAT0_50MHZ,
MX6DL_PAD_SD3_DAT1__USDHC3_DAT1_50MHZ,
MX6DL_PAD_SD3_DAT2__USDHC3_DAT2_50MHZ,
MX6DL_PAD_SD3_DAT3__USDHC3_DAT3_50MHZ,
MX6DL_PAD_SD3_DAT4__USDHC3_DAT4_50MHZ,
MX6DL_PAD_SD3_DAT5__USDHC3_DAT5_50MHZ,
MX6DL_PAD_SD3_DAT6__USDHC3_DAT6_50MHZ,
MX6DL_PAD_SD3_DAT7__USDHC3_DAT7_50MHZ,
/* SD3 VSelect */
MX6DL_PAD_GPIO_18__USDHC3_VSELECT,
/* SD3_CD and SD3_WP */
MX6DL_PAD_NANDF_CS2__GPIO_6_15,
MX6DL_PAD_SD2_DAT2__GPIO_1_13,
Grace
26,791 次查看
eddyliu
Hi Grace Si,
Under your reminding. I checked pins between my hardware board and freescale board except pins CLK, CMD and DAT0-7. I am notified SD3_CD and SD3_WP is not existed on my hardware board, while RST pin is on my hardware board which is not existed on freescale board. What does this two pins do? Is it necessary for eMMC or eMMC has many different hardware interface?
I check eMMC hardware interface on line which is same as my hardware board
26,791 次查看
GraceH
Hi Eddy,
If your board is not same as FSL board, you need modify mx6q_sabreauto_sd3_data in
/arch/arm/mach-mx6/board-mx6q_sabreauto.c
original:
static const struct esdhc_platform_data mx6q_sabreauto_sd3_data __initconst = {
  .cd_gpio = SABREAUTO_SD3_CD,
  .wp_gpio = SABREAUTO_SD3_WP,
  .keep_power_at_suspend = 1,
  .support_18v = 1,
  .support_8bit = 1,
  .delay_line = 0,
  .platform_pad_change = plt_sd_pad_change,
change to ->
  .always_present = 1,
  .support_8bit = 1,
  .delay_line = 0,
  .cd_type = ESDHC_CD_PERMANENT,
Grace
26,791 次查看
eddyliu
Hi Grace,
Maybe you are right, I need to modify my code for porting linux on my board. But first I do not understand the hardware design of FSL board. The only difference between my hardware board and FSL board is the RST pin and CD pin WP pin. Why does FSL board use CD pin and WP pin instead of RST pin. Can you tell me the function of CD pin and WP pin on FSL board? I do not think it is necessary for eMMC device.
26,791 次查看
GraceH
Hi Eddy,
CD( card detect) pin and WP (write protect) pin are needed for removable SD card, but NOT needed for non-removable eMMC.
Grace
26,791 次查看
eddyliu
Hi Grace,
As you say, CD pin and WP pin is not needed for non-removable eMMC. So no difference in hardware between my hardware board and FSL board. Why eMMC device can not be found on my hardware board which can be found on FSL board? Does FSL board not support non-removable eMMC?
26,791 次查看
GraceH
In FSL board, SD3 is configured for removable card, so CD pin and WP pin are defined in mx6q_sabreauto_sd3. If you use SD3 as non-removable, you must modify the structure of mx6q_sabreauto_sd3.
Grace
26,791 次查看
eddyliu
Hi Grace,
Thanks for your patient help. I have realized it is necessary to modify code to adapt for my hardware board. I modified structure of mx6q_sabreauto_sd3 and compiled linux code:
Header 1
#make ARCH=arm CROSS_COMPILE=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-none-linux-gnueabi- distclean
#make ARCH=arm CROSS_COMPILE=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-none-linux-gnueabi- imx6s_defconfig
#make ARCH=arm CROSS_COMPILE=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-none-linux-gnueabi- uImage
I copied uImage to "Mfgtools-Rel-4.1.0_130816_MX6DL_UPDATER\Profiles\MX6DL Linux Update\OS Firmware\" and replaced the old uImage. ucl2.xml configration is as blow:
Header 1
When I downloaded uboot and uImage using MFGtools, error appeared:
Header 1
Temperature:   37 C, calibration data 0x5a34e87d
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
Boot Device: MMC
I2C:   ready
DRAM:  512 MB
In:    serial
Out:   serial
Err:   serial
FEC0 [PRIME]
   Image Name:   Linux-3.0.35-2508-g54750ff
   Data Size:    3584948 Bytes =  3.4 MB
OK
Starting kernel ...
Linux version 3.0.35-2508-g54750ff (eddy@eddy-virtual-machine) (gcc version 4.6.2 20110630 (prerelease) (Freescale MAD -- Linaro 2011.07 -- Built at 201
1/08/10 09:20) ) #1 PREEMPT Wed Apr 2 04:38:35 EDT 2014
Memory policy: ECC disabled, Data cache writeback
Memory: 373308k/373308k available, 150980k reserved, 0K highmem
      .init : 0x80008000 - 0x80036000   ( 184 kB)
      .text : 0x80036000 - 0x80a30cb8   (10220 kB)
      .data : 0x80a32000 - 0x80a86480   ( 338 kB)
       .bss : 0x80a864a4 - 0x80aab438   ( 148 kB)
NR_IRQS:624
MXC GPIO hardware
arm_max_freq=800MHz
Freescale USB OTG Driver loaded, $Revision: 1.55 $
mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 driver probed
mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 dphy version is 0x3130302a
MIPI CSI2 driver module loaded
cfg80211: Calling CRDA to update world regulatory domain
TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Initramfs unpacking failed: junk in compressed archive
cpaddr = a0820000 suspend_iram_base=a087c000
JFFS2 version 2.2. (NAND) ?? 2001-2006 Red Hat, Inc.
msgmni has been set to 737
i2c-core: driver [sii902x] using legacy suspend method
i2c-core: driver [sii902x] using legacy resume method
Serial: IMX driver
loop: module loaded
CAN device driver interface
flexcan netdevice driver
FEC Ethernet Driver
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
fsl-ehci fsl-ehci.0: irq 75, io base 0x02184000
fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
add wake up source irq 72
fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller
fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200
fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
input: gpio-keys as /devices/platform/gpio-keys/input/input0
elan - Read Hello Packet Failed
elan-touch: probe of 2-0010 failed with error -22
i2c-core: driver [isl29023] using legacy suspend method
i2c-core: driver [isl29023] using legacy resume method
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = 80004000
[00000000] *pgd=00000000
Internal error: Oops: 5 [#1] PREEMPT
Modules linked in:
CPU: 0    Not tainted  (3.0.35-2508-g54750ff #1)
PC is at csi_mclk_enable+0x18/0x28
LR is at clk_enable+0x60/0xa0
pc : [<80344a88>]    lr : [<8005caec>]    psr: 60000013
sp : 94031ea8  ip : 00000000  fp : 00000000
r10: 9427d000  r9 : 8034758c  r8 : 9427d020
r7 : 00000000  r6 : 9427d000  r5 : 00000001  r4 : 80aa2fbc
r3 : 00000000  r2 : 00000000  r1 : 00000001  r0 : 00000000
Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
Control: 10c53c7d  Table: 10004059  DAC: 00000015
Process swapper (pid: 1, stack limit = 0x940302e8)
Stack: (0x94031ea8 to 0x94032000)
1ea0:                   00000001 80344ac8 8005a85c 80aa3028 80a48e34 80347714
1ec0: 00000000 00000000 9427d020 804f2778 804f2760 804f2778 9427d004 8031fbd0
1ee0: 9427d020 80aa0b88 9427d054 00000000 80a71d0c 00000000 80022f2c 80277f34
1f00: 9427d020 80a71d0c 9427d054 00000000 00000000 802780cc 80a71d0c 00000000
1f20: 80278040 80277154 940bcc38 94111c90 80a71d0c 80a6e6c0 9430e420 80277908
1f40: 809c58e0 80a71d0c 94030000 80a71d0c 94030000 8003c670 00000000 00000000
1f60: 80022f2c 802785ac 80a71ce4 94030000 8003c670 00000000 00000000 80321830
1f80: 00000000 80a864c0 94030000 80022f3c 80a864c0 8003635c 00000000 940564e0
1fa0: 8009e878 80022f2c 80a58078 8009e8a8 000001df 8003c670 00000013 37340000
1fc0: 00000039 8002b6f0 8002b84c 8003c670 00000013 00000000 00000000 00000000
1fe0: 00000000 800089b4 00000000 00000000 80008930 8003c670 6ebdf65b f33fd9dd
[<80344a88>] (csi_mclk_enable+0x18/0x28) from [<80344ac8>] (csi_enable_mclk+0x14/0x54)
[<80344ac8>] (csi_enable_mclk+0x14/0x54) from [<80347714>] (ov5640_probe+0x188/0x2f0)
[<80347714>] (ov5640_probe+0x188/0x2f0) from [<8031fbd0>] (i2c_device_probe+0xc0/0xfc)
[<8031fbd0>] (i2c_device_probe+0xc0/0xfc) from [<80277f34>] (driver_probe_device+0x90/0x19c)
[<80277f34>] (driver_probe_device+0x90/0x19c) from [<802780cc>] (__driver_attach+0x8c/0x90)
[<802780cc>] (__driver_attach+0x8c/0x90) from [<80277154>] (bus_for_each_dev+0x5c/0x88)
[<80277154>] (bus_for_each_dev+0x5c/0x88) from [<80277908>] (bus_add_driver+0x17c/0x244)
[<80277908>] (bus_add_driver+0x17c/0x244) from [<802785ac>] (driver_register+0x78/0x13c)
[<802785ac>] (driver_register+0x78/0x13c) from [<80321830>] (i2c_register_driver+0x2c/0xb4)
[<80321830>] (i2c_register_driver+0x2c/0xb4) from [<80022f3c>] (ov5640_init+0x10/0x40)
[<80022f3c>] (ov5640_init+0x10/0x40) from [<8003635c>] (do_one_initcall+0x34/0x174)
[<8003635c>] (do_one_initcall+0x34/0x174) from [<800089b4>] (kernel_init+0x84/0x124)
[<800089b4>] (kernel_init+0x84/0x124) from [<8003c670>] (kernel_thread_exit+0x0/0x8)
Code: e34840aa e2840008 ebf46001 e5943000 (e5932000)
---[ end trace c0aaf267c1d7dce3 ]---
Kernel panic - not syncing: Attempted to kill init!
[<80041518>] (unwind_backtrace+0x0/0xf8) from [<804c1f04>] (panic+0x74/0x188)
[<804c1f04>] (panic+0x74/0x188) from [<8006bca0>] (do_exit+0x668/0x6ec)
[<8006bca0>] (do_exit+0x668/0x6ec) from [<8003f1ec>] (die+0x234/0x2a8)
[<8003f1ec>] (die+0x234/0x2a8) from [<804c1e14>] (__do_kernel_fault.part.5+0x54/0x74)
[<804c1e14>] (__do_kernel_fault.part.5+0x54/0x74) from [<80044f70>] (do_page_fault+0x2b4/0x31c)
[<80044f70>] (do_page_fault+0x2b4/0x31c) from [<800361a0>] (do_DataAbort+0x34/0x9c)
[<800361a0>] (do_DataAbort+0x34/0x9c) from [<8003b790>] (__dabt_svc+0x70/0xa0)
Exception stack(0x94031e60 to 0x94031ea8)
1e60: 00000000 00000001 00000000 00000000 80aa2fbc 00000001 9427d000 00000000
1e80: 9427d020 8034758c 9427d000 00000000 00000000 94031ea8 8005caec 80344a88
1ea0: 60000013 ffffffff
[<8003b790>] (__dabt_svc+0x70/0xa0) from [<80344a88>] (csi_mclk_enable+0x18/0x28)
26,791 次查看
GraceH
imx6s_defconfig is for i.MX 6SoloLite.
export ARCH=arm
export CROSS_COMPILE=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-none-linux-gnueabi-
make imx6_updater_defconfig  // this is for MFG tool.
Grace
26,791 次查看
eddyliu
Hi Grace,
I have modified data struct mx6q_sabreauto_sd3_data in /arch/arm/mach-mx6/board-mx6q_sabreauto.c:
and compiled linux kernel using command below:
Header 1
#make ARCH=arm CROSS_COMPILE=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-none-linux-gnueabi- imx6_updater_defconfig
but still no eMMC device is found after uboot and uImage is downloaded by MFGtools:
Header 1
Temperature:   35 C, calibration data 0x5a34e87d
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
Boot Device: MMC
I2C:   ready
DRAM:  512 MB
In:    serial
Out:   serial
Err:   serial
FEC0 [PRIME]
   Data Size:    3161456 Bytes =  3 MB
OK
Starting kernel ...
1/08/10 09:20) ) #1 SMP PREEMPT Thu Apr 3 01:56:31 EDT 2014
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 130048
Memory: 512MB = 512MB total
Memory: 508996k/508996k available, 15292k reserved, 0K highmem
      .text : 0x8003a000 - 0x805ac9f8   (5579 kB)
      .data : 0x805ae000 - 0x805fc520   ( 314 kB)
       .bss : 0x805fc544 - 0x80627494   ( 172 kB)
NR_IRQS:624
MXC GPIO hardware
arm_max_freq=800MHz
Brought up 1 CPUs
TCP reno registered
msgmni has been set to 1002
Serial: IMX driver
loop: module loaded
FEC Ethernet Driver
VPU initialized
mxc_asrc registered
ALSA device list:
mxc_dvfs_core_probe
Starting UTP
udevd (2072): /proc/2072/oom_adj is deprecated, please use /proc/2072/oom_score_adj instead.
cpu_id is 0
XOR                 ptyrb               tty25               ttyqf
apm_bios            ptyrc               tty26               ttyr0
console             ptyrd               tty27               ttyr1
cpu_dma_latency     ptyre               tty28               ttyr2
crypto              ptyrf               tty29               ttyr3
fb                  ptys0               tty3                ttyr4
fb0                 ptys1               tty30               ttyr5
fb1                 ptys2               tty31               ttyr6
fb2                 ptys3               tty32               ttyr7
full                ptys4               tty33               ttyr8
i2c-0               ptys5               tty34               ttyr9
i2c-1               ptys6               tty35               ttyra
i2c-2               ptys7               tty36               ttyrb
input               ptys8               tty37               ttyrc
kmem                ptys9               tty38               ttyrd
kmsg                ptysa               tty39               ttyre
loop0               ptysb               tty4                ttyrf
loop1               ptysc               tty40               ttys0
loop2               ptysd               tty41               ttys1
loop3               ptyse               tty42               ttys2
loop4               ptysf               tty43               ttys3
loop5               ptyt0               tty44               ttys4
loop6               ptyt1               tty45               ttys5
loop7               ptyt2               tty46               ttys6
mem                 ptyt3               tty47               ttys7
mxc_asrc            ptyt4               tty48               ttys8
mxc_ipu             ptyt5               tty49               ttys9
mxc_mem             ptyt6               tty5                ttysa
mxc_vpu             ptyt7               tty50               ttysb
mxs_viim            ptyt8               tty51               ttysc
network_latency     ptyt9               tty52               ttysd
network_throughput  ptyta               tty53               ttyse
null                ptytb               tty54               ttysf
psaux               ptytc               tty55               ttyt0
ptmx                ptytd               tty56               ttyt1
pts                 ptyte               tty57               ttyt2
ptya0               ptytf               tty58               ttyt3
ptya1               ptyu0               tty59               ttyt4
ptya2               ptyu1               tty6                ttyt5
ptya3               ptyu2               tty60               ttyt6
ptya4               ptyu3               tty61               ttyt7
ptya5               ptyu4               tty62               ttyt8
ptya6               ptyu5               tty63               ttyt9
ptya7               ptyu6               tty7                ttyta
ptya8               ptyu7               tty8                ttytb
ptya9               ptyu8               tty9                ttytc
ptyaa               ptyu9               ttya0               ttytd
ptyab               ptyua               ttya1               ttyte
ptyac               ptyub               ttya2               ttytf
ptyad               ptyuc               ttya3               ttyu0
ptyae               ptyud               ttya4               ttyu1
ptyaf               ptyue               ttya5               ttyu2
ptyb0               ptyuf               ttya6               ttyu3
ptyb1               ptyv0               ttya7               ttyu4
ptyb2               ptyv1               ttya8               ttyu5
ptyb3               ptyv2               ttya9               ttyu6
ptyb4               ptyv3               ttyaa               ttyu7
ptyb5               ptyv4               ttyab               ttyu8
ptyb6               ptyv5               ttyac               ttyu9
ptyb7               ptyv6               ttyad               ttyua
ptyb8               ptyv7               ttyae               ttyub
ptyb9               ptyv8               ttyaf               ttyuc
ptyba               ptyv9               ttyb0               ttyud
ptybb               ptyva               ttyb1               ttyue
ptybc               ptyvb               ttyb2               ttyuf
ptybd               ptyvc               ttyb3               ttyv0
ptybe               ptyvd               ttyb4               ttyv1
ptybf               ptyve               ttyb5               ttyv2
ptyc0               ptyvf               ttyb6               ttyv3
ptyc1               ptyw0               ttyb7               ttyv4
ptyc2               ptyw1               ttyb8               ttyv5
ptyc3               ptyw2               ttyb9               ttyv6
ptyc4               ptyw3               ttyba               ttyv7
ptyc5               ptyw4               ttybb               ttyv8
ptyc6               ptyw5               ttybc               ttyv9
ptyc7               ptyw6               ttybd               ttyva
ptyc8               ptyw7               ttybe               ttyvb
ptyc9               ptyw8               ttybf               ttyvc
ptyca               ptyw9               ttyc0               ttyvd
ptycb               ptywa               ttyc1               ttyve
ptycc               ptywb               ttyc2               ttyvf
ptycd               ptywc               ttyc3               ttyw0
ptyce               ptywd               ttyc4               ttyw1
ptycf               ptywe               ttyc5               ttyw2
ptyd0               ptywf               ttyc6               ttyw3
ptyd1               ptyx0               ttyc7               ttyw4
ptyd2               ptyx1               ttyc8               ttyw5
ptyd3               ptyx2               ttyc9               ttyw6
ptyd4               ptyx3               ttyca               ttyw7
ptyd5               ptyx4               ttycb               ttyw8
ptyd6               ptyx5               ttycc               ttyw9
ptyd7               ptyx6               ttycd               ttywa
ptyd8               ptyx7               ttyce               ttywb
ptyd9               ptyx8               ttycf               ttywc
ptyda               ptyx9               ttyd0               ttywd
ptydb               ptyxa               ttyd1               ttywe
ptydc               ptyxb               ttyd2               ttywf
ptydd               ptyxc               ttyd3               ttyx0
ptyde               ptyxd               ttyd4               ttyx1
ptydf               ptyxe               ttyd5               ttyx2
ptye0               ptyxf               ttyd6               ttyx3
ptye1               ptyy0               ttyd7               ttyx4
ptye2               ptyy1               ttyd8               ttyx5
ptye3               ptyy2               ttyd9               ttyx6
ptye4               ptyy3               ttyda               ttyx7
ptye5               ptyy4               ttydb               ttyx8
ptye6               ptyy5               ttydc               ttyx9
ptye7               ptyy6               ttydd               ttyxa
ptye8               ptyy7               ttyde               ttyxb
ptye9               ptyy8               ttydf               ttyxc
ptyea               ptyy9               ttye0               ttyxd
ptyeb               ptyya               ttye1               ttyxe
ptyec               ptyyb               ttye2               ttyxf
ptyed               ptyyc               ttye3               ttyy0
ptyee               ptyyd               ttye4               ttyy1
ptyef               ptyye               ttye5               ttyy2
ptyp0               ptyyf               ttye6               ttyy3
ptyp1               ptyz0               ttye7               ttyy4
ptyp2               ptyz1               ttye8               ttyy5
ptyp3               ptyz2               ttye9               ttyy6
ptyp4               ptyz3               ttyea               ttyy7
ptyp5               ptyz4               ttyeb               ttyy8
ptyp6               ptyz5               ttyec               ttyy9
ptyp7               ptyz6               ttyed               ttyya
ptyp8               ptyz7               ttyee               ttyyb
ptyp9               ptyz8               ttyef               ttyyc
ptypa               ptyz9               ttymxc0             ttyyd
ptypb               ptyza               ttymxc2             ttyye
ptypc               ptyzb               ttyp0               ttyyf
ptypd               ptyzc               ttyp1               ttyz0
ptype               ptyzd               ttyp2               ttyz1
ptypf               ptyze               ttyp3               ttyz2
ptyq0               ptyzf               ttyp4               ttyz3
ptyq1               random              ttyp5               ttyz4
ptyq2               rfkill              ttyp6               ttyz5
ptyq3               rtc                 ttyp7               ttyz6
ptyq4               rtc0                ttyp8               ttyz7
ptyq5               shm                 ttyp9               ttyz8
ptyq6               snd                 ttypa               ttyz9
ptyq7               tracebuf            ttypb               ttyza
ptyq8               tty                 ttypc               ttyzb
ptyq9               tty0                ttypd               ttyzc
ptyqa               tty1                ttype               ttyzd
ptyqb               tty10               ttypf               ttyze
ptyqc               tty11               ttyq0               ttyzf
ptyqd               tty12               ttyq1               ubi_ctrl
ptyqe               tty13               ttyq2               urandom
ptyqf               tty14               ttyq3               utp
ptyr0               tty15               ttyq4               vcs
ptyr1               tty16               ttyq5               vcs1
ptyr2               tty17               ttyq6               vcsa
ptyr3               tty18               ttyq7               vcsa1
ptyr4               tty19               ttyq8               vhci
ptyr5               tty2                ttyq9               video16
ptyr6               tty20               ttyqa               video17
ptyr7               tty21               ttyqb               video18
ptyr8               tty22               ttyqc               watchdog
ptyr9               tty23               ttyqd               zero
ptyra               tty24               ttyqe
26,791 次查看
GraceH
If you use 6DL SarbeSD, you should modify /arch/arm/mach-mx6/board-mx6q_sabresd.c. In your post, you said you compared SABRE-AI_DualLite_CPUcard,  If you use SarbeSD config, you should compare SarbeSD reference design.
Grace
26,791 次查看
eddyliu
Hi Grace,
Can you give more feedback about this issue?
26,792 次查看
GraceH
Hi Eddy,
Grace
26,791 次查看
eddyliu
Hi Grace,
Now my hardware board can run uboot uImage and fs from Freescale LTIB. Thanks for your patient help. Best wishes for you.
26,791 次查看
eddyliu
Hi Grace,
With your patiently direction, I modified file board-mx6_sabresd.c. Now eMMC device can be found:
Header 1
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
Boot Device: MMC
I2C:   ready
DRAM:  512 MB
In:    serial
Out:   serial
Err:   serial
FEC0 [PRIME]
   Data Size:    3161712 Bytes =  3 MB
OK
Starting kernel ...
1/08/10 09:20) ) #1 SMP PREEMPT Fri Apr 4 01:20:23 EDT 2014
      .text : 0x8003a000 - 0x805aca0c   (5579 kB)
      .data : 0x805ae000 - 0x805fc700   ( 314 kB)
       .bss : 0x805fc724 - 0x80627674   ( 172 kB)
NR_IRQS:624
MXC GPIO hardware
arm_max_freq=800MHz
Brought up 1 CPUs
TCP reno registered
Serial: IMX driver
loop: module loaded
FEC Ethernet Driver
VPU initialized
mxc_asrc registered
ALSA device list:
mxc_dvfs_core_probe
Starting UTP
mmc2: new high speed DDR MMC card at address 0001
mmcblk0: mmc2:0001 MMC08G 7.32 GiB
mmcblk0boot0: mmc2:0001 MMC08G partition 1 2.00 MiB
mmcblk0boot1: mmc2:0001 MMC08G partition 2 2.00 MiB
mmcblk0: p1 p2
mmcblk0boot1: unknown partition table
mmcblk0boot0: unknown partition table
cpu_id is 0
XOR                 ptyr7               tty23               ttyqf
apm_bios            ptyr8               tty24               ttyr0
console             ptyr9               tty25               ttyr1
cpu_dma_latency     ptyra               tty26               ttyr2
crypto              ptyrb               tty27               ttyr3
disk                ptyrc               tty28               ttyr4
fb                  ptyrd               tty29               ttyr5
fb0                 ptyre               tty3                ttyr6
fb1                 ptyrf               tty30               ttyr7
fb2                 ptys0               tty31               ttyr8
full                ptys1               tty32               ttyr9
i2c-0               ptys2               tty33               ttyra
i2c-1               ptys3               tty34               ttyrb
i2c-2               ptys4               tty35               ttyrc
input               ptys5               tty36               ttyrd
kmem                ptys6               tty37               ttyre
kmsg                ptys7               tty38               ttyrf
loop0               ptys8               tty39               ttys0
loop1               ptys9               tty4                ttys1
loop2               ptysa               tty40               ttys2
loop3               ptysb               tty41               ttys3
loop4               ptysc               tty42               ttys4
loop5               ptysd               tty43               ttys5
loop6               ptyse               tty44               ttys6
loop7               ptysf               tty45               ttys7
mem                 ptyt0               tty46               ttys8
mmcblk0             ptyt1               tty47               ttys9
mmcblk0boot0        ptyt2               tty48               ttysa
mmcblk0boot1        ptyt3               tty49               ttysb
mmcblk0p1           ptyt4               tty5                ttysc
mmcblk0p2           ptyt5               tty50               ttysd
mxc_asrc            ptyt6               tty51               ttyse
mxc_ipu             ptyt7               tty52               ttysf
mxc_mem             ptyt8               tty53               ttyt0
mxc_vpu             ptyt9               tty54               ttyt1
mxs_viim            ptyta               tty55               ttyt2
network_latency     ptytb               tty56               ttyt3
network_throughput  ptytc               tty57               ttyt4
null                ptytd               tty58               ttyt5
psaux               ptyte               tty59               ttyt6
ptmx                ptytf               tty6                ttyt7
pts                 ptyu0               tty60               ttyt8
ptya0               ptyu1               tty61               ttyt9
ptya1               ptyu2               tty62               ttyta
ptya2               ptyu3               tty63               ttytb
ptya3               ptyu4               tty7                ttytc
ptya4               ptyu5               tty8                ttytd
ptya5               ptyu6               tty9                ttyte
ptya6               ptyu7               ttya0               ttytf
ptya7               ptyu8               ttya1               ttyu0
ptya8               ptyu9               ttya2               ttyu1
ptya9               ptyua               ttya3               ttyu2
ptyaa               ptyub               ttya4               ttyu3
ptyab               ptyuc               ttya5               ttyu4
ptyac               ptyud               ttya6               ttyu5
ptyad               ptyue               ttya7               ttyu6
ptyae               ptyuf               ttya8               ttyu7
ptyaf               ptyv0               ttya9               ttyu8
ptyb0               ptyv1               ttyaa               ttyu9
ptyb1               ptyv2               ttyab               ttyua
ptyb2               ptyv3               ttyac               ttyub
ptyb3               ptyv4               ttyad               ttyuc
ptyb4               ptyv5               ttyae               ttyud
ptyb5               ptyv6               ttyaf               ttyue
ptyb6               ptyv7               ttyb0               ttyuf
ptyb7               ptyv8               ttyb1               ttyv0
ptyb8               ptyv9               ttyb2               ttyv1
ptyb9               ptyva               ttyb3               ttyv2
ptyba               ptyvb               ttyb4               ttyv3
ptybb               ptyvc               ttyb5               ttyv4
ptybc               ptyvd               ttyb6               ttyv5
ptybd               ptyve               ttyb7               ttyv6
ptybe               ptyvf               ttyb8               ttyv7
ptybf               ptyw0               ttyb9               ttyv8
ptyc0               ptyw1               ttyba               ttyv9
ptyc1               ptyw2               ttybb               ttyva
ptyc2               ptyw3               ttybc               ttyvb
ptyc3               ptyw4               ttybd               ttyvc
ptyc4               ptyw5               ttybe               ttyvd
ptyc5               ptyw6               ttybf               ttyve
ptyc6               ptyw7               ttyc0               ttyvf
ptyc7               ptyw8               ttyc1               ttyw0
ptyc8               ptyw9               ttyc2               ttyw1
ptyc9               ptywa               ttyc3               ttyw2
ptyca               ptywb               ttyc4               ttyw3
ptycb               ptywc               ttyc5               ttyw4
ptycc               ptywd               ttyc6               ttyw5
ptycd               ptywe               ttyc7               ttyw6
ptyce               ptywf               ttyc8               ttyw7
ptycf               ptyx0               ttyc9               ttyw8
ptyd0               ptyx1               ttyca               ttyw9
ptyd1               ptyx2               ttycb               ttywa
ptyd2               ptyx3               ttycc               ttywb
ptyd3               ptyx4               ttycd               ttywc
ptyd4               ptyx5               ttyce               ttywd
ptyd5               ptyx6               ttycf               ttywe
ptyd6               ptyx7               ttyd0               ttywf
ptyd7               ptyx8               ttyd1               ttyx0
ptyd8               ptyx9               ttyd2               ttyx1
ptyd9               ptyxa               ttyd3               ttyx2
ptyda               ptyxb               ttyd4               ttyx3
ptydb               ptyxc               ttyd5               ttyx4
ptydc               ptyxd               ttyd6               ttyx5
ptydd               ptyxe               ttyd7               ttyx6
ptyde               ptyxf               ttyd8               ttyx7
ptydf               ptyy0               ttyd9               ttyx8
ptye0               ptyy1               ttyda               ttyx9
ptye1               ptyy2               ttydb               ttyxa
ptye2               ptyy3               ttydc               ttyxb
ptye3               ptyy4               ttydd               ttyxc
ptye4               ptyy5               ttyde               ttyxd
ptye5               ptyy6               ttydf               ttyxe
ptye6               ptyy7               ttye0               ttyxf
ptye7               ptyy8               ttye1               ttyy0
ptye8               ptyy9               ttye2               ttyy1
ptye9               ptyya               ttye3               ttyy2
ptyea               ptyyb               ttye4               ttyy3
ptyeb               ptyyc               ttye5               ttyy4
ptyec               ptyyd               ttye6               ttyy5
ptyed               ptyye               ttye7               ttyy6
ptyee               ptyyf               ttye8               ttyy7
ptyef               ptyz0               ttye9               ttyy8
ptyp0               ptyz1               ttyea               ttyy9
ptyp1               ptyz2               ttyeb               ttyya
ptyp2               ptyz3               ttyec               ttyyb
ptyp3               ptyz4               ttyed               ttyyc
ptyp4               ptyz5               ttyee               ttyyd
ptyp5               ptyz6               ttyef               ttyye
ptyp6               ptyz7               ttymxc0             ttyyf
ptyp7               ptyz8               ttymxc2             ttyz0
ptyp8               ptyz9               ttyp0               ttyz1
ptyp9               ptyza               ttyp1               ttyz2
ptypa               ptyzb               ttyp2               ttyz3
ptypb               ptyzc               ttyp3               ttyz4
ptypc               ptyzd               ttyp4               ttyz5
ptypd               ptyze               ttyp5               ttyz6
ptype               ptyzf               ttyp6               ttyz7
ptypf               random              ttyp7               ttyz8
ptyq0               rfkill              ttyp8               ttyz9
ptyq1               rtc                 ttyp9               ttyza
ptyq2               rtc0                ttypa               ttyzb
ptyq3               shm                 ttypb               ttyzc
ptyq4               snd                 ttypc               ttyzd
ptyq5               tracebuf            ttypd               ttyze
ptyq6               tty                 ttype               ttyzf
ptyq7               tty0                ttypf               ubi_ctrl
ptyq8               tty1                ttyq0               urandom
ptyq9               tty10               ttyq1               utp
ptyqa               tty11               ttyq2               vcs
ptyqb               tty12               ttyq3               vcs1
ptyqc               tty13               ttyq4               vcsa
ptyqd               tty14               ttyq5               vcsa1
ptyqe               tty15               ttyq6               vhci
ptyqf               tty16               ttyq7               video16
ptyr0               tty17               ttyq8               video17
ptyr1               tty18               ttyq9               video18
ptyr2               tty19               ttyqa               watchdog
ptyr3               tty2                ttyqb               zero
ptyr4               tty20               ttyqc
ptyr5               tty21               ttyqd
ptyr6               tty22               ttyqe
Then I rebuilt linux kernel for eMMC with commands below:
Header 1
#make ARCH=arm CROSS_COMPILE=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-none-linux-gnueabi- imx6_defconfig
and copied new generated uImage to directory "Mfgtools-Rel-4.1.0_130816_MX6DL_UPDATER\Profiles\MX6DL Linux Update\OS Firmware\files\" replacing the old uImage.
ucl2.xml configration is as below:
Header 1
    <CMD state="Updater" type="push" body="send" file="mksdcard.sh.tar">Sending partition shell</CMD>
    <CMD state="Updater" type="push" body="$ tar xf $FILE "> Partitioning...</CMD>
    <CMD state="Updater" type="push" body="$ sh mksdcard.sh /dev/mmcblk0"> Partitioning...</CMD>
    <CMD state="Updater" type="push" body="send" file="files/u-boot-mx6solo-sabresd.bin">Sending u-boot.bin</CMD>
    <CMD state="Updater" type="push" body="$ dd if=$FILE of=/dev/mmcblk0 bs=1k seek=1 skip=1 conv=fsync">write u-boot.bin to sd card</CMD>
    <CMD state="Updater" type="push" body="send" file="files/uImage">Sending kernel uImage</CMD>
    <CMD state="Updater" type="push" body="$ dd if=$FILE of=/dev/mmcblk0 bs=1M seek=1 conv=fsync">write kernel image to sd card</CMD>
    <CMD state="Updater" type="push" body="$ mkfs.ext3 -j /dev/mmcblk0p1">Formatting rootfs partition</CMD>
    <CMD state="Updater" type="push" body="$ mkdir -p /mnt/mmcblk0p1"/>
    <CMD state="Updater" type="push" body="$ mount -t ext3 /dev/mmcblk0p1 /mnt/mmcblk0p1"/>
    <CMD state="Updater" type="push" body="pipe tar -jxv -C /mnt/mmcblk0p1" file="files/rootfs.tar.bz2">Sending and writting rootfs</CMD>
    <CMD state="Updater" type="push" body="frf">Finishing rootfs write</CMD>
    <CMD state="Updater" type="push" body="$ umount /mnt/mmcblk0p1">Unmounting rootfs partition</CMD>
    <CMD state="Updater" type="push" body="$ echo Update Complete!">Done</CMD>
    The below commands will trigger reboot
    <CMD type="push" body="!3">Done</CMD>
</LIST>
Downloading uboot and uImage process is as below:
Header 1
Temperature:   43 C, calibration data 0x5a34e87d
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
Boot Device: MMC
I2C:   ready
DRAM:  512 MB
In:    serial
Out:   serial
Err:   serial
FEC0 [PRIME]
OK
Starting kernel ...
Linux version 3.0.35-2508-g54750ff (eddy@eddy-virtual-machine) (gcc version 4.6.2 20110630 (prerelease) (Freescale MAD -- Linaro 2011.07 -- Built at 2011/08/10 09:20) ) #1 SMP PREEMPT Fri Apr 4 01:20:23 EDT 2014
NR_IRQS:624
MXC GPIO hardware
arm_max_freq=800MHz
Brought up 1 CPUs
TCP reno registered
Serial: IMX driver
loop: module loaded
FEC Ethernet Driver
VPU initialized
mxc_asrc registered
ALSA device list:
mxc_dvfs_core_probe
Starting UTP
mmcblk0: p1
cpu_id is 0
UTP: received command 'send'
UTP: sending Success to kernel for command send.
UTP: received command '$ tar xf $FILE '
UTP: executing "tar xf $FILE "
UTP: sending Success to kernel for command $ tar xf $FILE .
UTP: received command '$ sh mksdcard.sh /dev/mmcblk0'
UTP: executing "sh mksdcard.sh /dev/mmcblk0"
1+0 records in
1+0 records out
1024 bytes (1.0KB) copied, 0.031571 seconds, 31.7KB/s
Checking that no-one is using this disk right now ...
mmcblk0: unknown partition table
OK
Disk /dev/mmcblk0: 240128 cylinders, 4 heads, 16 sectors/track
sfdisk: ERROR: sector 0 does not have an msdos signature
/dev/mmcblk0: unrecognized partition table type
Old situation:
No partitions found
New situation:
Units = mebibytes of 1048576 bytes, blocks of 1024 bytes, counting from 0
   Device Boot Start   End    MiB    #blocks   Id  System
/dev/mmcblk0p1        10   7503   7494    7673856   83  Linux
/dev/mmcblk0p2         0      -      0          0    0  Empty
/dev/mmcblk0p3         0      -      0          0    0  Empty
/dev/mmcblk0p4         0      -      0          0    0  Empty
Warning: no primary partition is marked bootable (active)
This does not matter for LILO, but the DOS MBR will not boot this disk.
Successfully wrote the new partition table
Re-reading the partition table ...
mmcblk0: p1
If you created or changed a DOS partition, /dev/foo7, say, then use dd(1)
to zero the first 512 bytes:  dd if=/dev/zero of=/dev/foo7 bs=512 count=1
(See fdisk(8).)
UTP: sending Success to kernel for command $ sh mksdcard.sh /dev/mmcblk0.
UTP: received command '$ dd if=$FILE of=/dev/mmcblk0 bs=1k seek=1 skip=1 conv=fsync'
UTP: executing "dd if=$FILE of=/dev/mmcblk0 bs=1k seek=1 skip=1 conv=fsync"
420+1 records in
420+1 records out
430248 bytes (420.2KB) copied, 1.197707 seconds, 350.8KB/s
UTP: sending Success to kernel for command $ dd if=$FILE of=/dev/mmcblk0 bs=1k seek=1 skip=1 conv=fsync.
UTP: received command '$ dd if=$FILE of=/dev/mmcblk0 bs=1M seek=1 conv=fsync'
UTP: executing "dd if=$FILE of=/dev/mmcblk0 bs=1M seek=1 conv=fsync"
3+1 records in
3+1 records out
3860944 bytes (3.7MB) copied, 1.452290 seconds, 2.5MB/s
UTP: sending Success to kernel for command $ dd if=$FILE of=/dev/mmcblk0 bs=1M seek=1 conv=fsync.
UTP: received command '$ mkfs.ext3 -j /dev/mmcblk0p1'
UTP: executing "mkfs.ext3 -j /dev/mmcblk0p1"
mke2fs 1.41.4 (27-Jan-2009)
Filesystem label=
OS type: Linux
Block size=4096 (log=2)
Fragment size=4096 (log=2)
480496 inodes, 1918464 blocks
95923 blocks (5.00%) reserved for the super user
First data block=0
Maximum filesystem blocks=1967128576
59 block groups
32768 blocks per group, 32768 fragments per group
8144 inodes per group
Superblock backups stored on blocks:
  32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632
Writing inode tables:  0/59      1/59      2/59      3/59      4/59      5/59      6/59      7/59      8/59      9/59     10/59     11/59     12/59     13/59     14/59     15/59     16/59     17/59     18/59     19/59     20/59     21/59     22/59     23/59     24/59     25/59     26/59     27/59     28/59     29/59     30/59     31/59     32/59     33/59     34/59     35/59     36/59     37/59     38/59     39/59     40/59     41/59     42/59     43/59     44/59     45/59     46/59     47/59     48/59     49/59     50/59     51/59     52/59     53/59     54/59     55/59     56/59     57/59     58/59     done
Creating journal (32768 blocks): done
Writing superblocks and filesystem accounting information: done
This filesystem will be automatically checked every 39 mounts or
180 days, whichever comes first.  Use tune2fs -c or -i to override.
UTP: sending Success to kernel for command $ mkfs.ext3 -j /dev/mmcblk0p1.
UTP: received command '$ mkdir -p /mnt/mmcblk0p1'
UTP: executing "mkdir -p /mnt/mmcblk0p1"
UTP: sending Success to kernel for command $ mkdir -p /mnt/mmcblk0p1.
UTP: received command '$ mount -t ext3 /dev/mmcblk0p1 /mnt/mmcblk0p1'
UTP: executing "mount -t ext3 /dev/mmcblk0p1 /mnt/mmcblk0p1"
EXT3-fs: barriers not enabled
kjournald starting.  Commit interval 5 seconds
EXT3-fs (mmcblk0p1): using internal journal
EXT3-fs (mmcblk0p1): mounted filesystem with writeback data mode
UTP: sending Success to kernel for command $ mount -t ext3 /dev/mmcblk0p1 /mnt/mmcblk0p1.
UTP: received command 'pipe tar -jxv -C /mnt/mmcblk0p1'
pid is 3106, UTP: executing "tar -jxv -C /mnt/mmcblk0p1"
UTP: sending Success to kernel for command pipe tar -jxv -C /mnt/mmcblk0p1.
bin/
bin/realpath
bin/mount
bin/dmesg
bin/rev
bin/traceroute
bin/login
bin/iprule
bin/lspci
bin/mesg
bin/iptunnel
bin/dumpleases
bin/delgroup
bin/ping
bin/fgrep
bin/vlock
bin/head
bin/diff
bin/catv
bin/whoami
bin/md5sum
bin/install
bin/zcat
bin/fgconsole
bin/smemcap
bin/uptime
bin/passwd
bin/taskset
bin/gzip
bin/mpstat
bin/more
bin/unix2dos
bin/env
bin/cut
bin/cp
bin/bzcat
bin/egrep
bin/top
bin/test
bin/sort
bin/find
bin/yes
bin/date
bin/tee
bin/unxz
bin/busybox
bin/chgrp
bin/bunzip2
bin/dnsdomainname
bin/rx
bin/stty
bin/iplink
bin/nc
bin/grep
bin/kill
bin/powertop
bin/true
bin/sha1sum
bin/false
bin/uname
bin/rmdir
bin/seq
bin/mktemp
bin/pmap
bin/clear
bin/resize
bin/dumpkmap
bin/deluser
bin/time
bin/getopt
bin/[
bin/dc
bin/which
bin/cksum
bin/su
bin/killall
bin/wget
bin/dirname
bin/xzcat
bin/tail
bin/tar
bin/nice
bin/gunzip
bin/ipaddr
bin/who
bin/expr
bin/unzip
bin/logger
bin/chmod
bin/tr
bin/df
bin/ftpput
bin/mkdir
bin/renice
bin/dd
bin/cat
bin/hostname
bin/adduser
bin/mknod
bin/sh
bin/length
bin/dos2unix
bin/patch
bin/iproute
bin/cmp
bin/openvt
bin/sleep
bin/hexdump
bin/uniq
bin/flock
bin/telnet
bin/ls
bin/rm
bin/ftpget
bin/od
bin/ps
bin/ln
bin/addgroup
bin/cal
bin/iostat
bin/bashbug
bin/base64
bin/chown
bin/run-parts
bin/hostid
bin/id
bin/[[
bin/usleep
bin/sync
bin/free
bin/reset
bin/pwd
bin/tftp
bin/lsusb
bin/netstat
bin/wc
bin/wall
bin/touch
bin/bash
bin/logname
bin/printf
bin/ash
bin/tty
bin/vi
bin/awk
bin/nslookup
bin/xargs
bin/umount
bin/basename
bin/mkfifo
bin/xz
bin/deallocvt
bin/readlink
bin/echo
bin/mv
bin/less
bin/sed
bin/chvt
bin/du
dev/
dev/null
dev/console
dev/mtab
dev/tty
etc/
etc/hosts.deny
etc/inputrc
etc/issue.net
etc/shadow
etc/profile
etc/passwd
etc/rc.d/
etc/rc.d/rc.serial
etc/rc.d/rc.modules
etc/rc.d/rcS
etc/rc.d/rc_mxc.S
etc/rc.d/init.d/
etc/rc.d/init.d/filesystems
etc/rc.d/init.d/udev
etc/rc.d/init.d/smb
etc/rc.d/init.d/mdev
etc/rc.d/init.d/modules
etc/rc.d/init.d/inetd
etc/rc.d/init.d/mount-proc-sys
etc/rc.d/init.d/portmap
etc/rc.d/init.d/dhcp
etc/rc.d/init.d/hostname
etc/rc.d/init.d/dropbear
etc/rc.d/init.d/syslog
etc/rc.d/init.d/settime
etc/rc.d/init.d/devfsd
etc/rc.d/init.d/network
etc/rc.d/init.d/hotplug
etc/rc.d/init.d/sshd
etc/rc.d/init.d/dhcpd
etc/rc.d/init.d/depmod
etc/rc.d/init.d/boa
etc/rc.d/rc.local
etc/rc.d/rc.conf
etc/printcap
etc/inittab
etc/udev/
etc/udev/udev.conf
etc/udev/rules.d/
etc/udev/rules.d/10-imx.rules
etc/udev/rules.d/60-persistent-storage.rules
etc/udev/rules.d/80-drivers.rules
etc/udev/rules.d/95-udev-late.rules
etc/udev/rules.d/60-persistent-input.rules
etc/udev/rules.d/60-persistent-storage-tape.rules
etc/udev/rules.d/05-udev-early.rules
etc/udev/rules.d/40-alsa.rules
etc/udev/rules.d/50-udev-default.rules
etc/hosts.allow
etc/resolv.conf
etc/protocols
etc/host.conf
etc/modprobe.conf
etc/devfsd.conf
etc/mime.types
etc/securetty.orig
etc/issue
etc/mdev.conf
etc/inetd.conf
etc/busybox.conf
etc/securetty
etc/fstab
etc/udhcpd.conf
etc/services
etc/hotplug/
etc/hotplug/pci/
etc/hotplug/hotplug.functions
etc/hotplug/dasd.agent
etc/hotplug/usb.handmap
etc/hotplug/tape.agent
etc/hotplug/usb/
etc/hotplug/input.rc
etc/hotplug/input.agent
etc/hotplug/usb.usermap
etc/hotplug/usb.rc
etc/hotplug/usb.agent
etc/hotplug/scsi.agent
etc/hotplug/ieee1394.agent
etc/hotplug/net.agent
etc/hotplug/pci.rc
etc/hotplug/firmware.agent
etc/hotplug/pci.agent
etc/hotplug/blacklist
etc/hotplug/usb.distmap
etc/exports
etc/group
etc/sysctl.conf
etc/ltib-release
etc/nsswitch.conf
etc/hosts
etc/profile.orig
etc/shells
etc/hotplug.d/
etc/hotplug.d/default/
etc/hotplug.d/default/default.hotplug
home/
home/user/
home/user/.rhosts
lib/
lib/libnss_dns.so.2
lib/libanl-2.11.1.so
lib/libutil.so.1
lib/libnss_nis.so.2
lib/libvolume_id.so.0
lib/libtermcap.so.2
lib/libutil-2.11.1.so
lib/ld-2.11.1.so
lib/libstdc++.so.6
lib/udev/
lib/udev/vol_id
lib/udev/path_id
lib/udev/firmware.sh
lib/udev/usb_id
lib/libnss_nisplus.so.2
lib/libBrokenLocale-2.11.1.so
lib/libdl-2.11.1.so
lib/libnss_hesiod-2.11.1.so
lib/libc-2.11.1.so
lib/libnss_hesiod.so.2
lib/libcrypt-2.11.1.so
lib/librt-2.11.1.so
lib/libc.so.6
lib/libgcc_s.so
lib/libtermcap.so.2.0.8
lib/modules/
lib/modules/2.6.38-1096-gc49343d/
lib/modules/2.6.38-1096-gc49343d/modules.order
lib/modules/2.6.38-1096-gc49343d/build
lib/modules/2.6.38-1096-gc49343d/modules.builtin
lib/modules/2.6.38-1096-gc49343d/source
lib/modules/2.6.38-1096-gc49343d/test/
lib/modules/2.6.38-1096-gc49343d/modules.dep
lib/modules/2.6.38-1096-gc49343d/kernel/
lib/modules/2.6.38-1096-gc49343d/kernel/crypto/
lib/modules/2.6.38-1096-gc49343d/kernel/crypto/tcrypt.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/scsi/
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/scsi/scsi_wait_scan.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/usb/
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/usb/gadget/
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/usb/gadget/g_serial.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/usb/gadget/g_ether.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/usb/gadget/g_file_storage.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/usb/gadget/g_audio.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/misc/
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/misc/mxs-perfmon.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-cypress.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-a4tech.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-sunplus.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-petalynx.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-pl.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-sony.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-ezkey.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-monterey.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-belkin.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-samsung.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-gyration.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-microsoft.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-apple.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-cherry.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-chicony.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/hid/hid-logitech.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/mxc/
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/mxc/gpu-viv/
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/mxc/gpu-viv/galcore.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/mxc/mlb/
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/mxc/mlb/mxc_mlb150.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/gspca/
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/gspca/gspca_main.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/uvc/
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/uvc/uvcvideo.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/mxc/
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/mxc/capture/
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/mxc/capture/ov5642_camera.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/mxc/capture/adv7180_tvin.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/mxc/capture/ipu_prp_enc.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/mxc/capture/ov5640_camera_mipi.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/mxc/capture/ipu_csi_enc.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/mxc/capture/mxc_v4l2_capture.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/mxc/capture/ipu_still.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/mxc/capture/ov3640_camera.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/mxc/capture/ov8820_camera_mipi.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/mxc/capture/ipu_prp_vf_sdc.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/mxc/capture/ipu_prp_vf_sdc_bg.ko
lib/modules/2.6.38-1096-gc49343d/kernel/drivers/media/video/mxc/capture/ov5640_camera.ko
lib/modules/2.6.38-1096-gc49343d/kernel/lib/
lib/modules/2.6.38-1096-gc49343d/kernel/lib/crc-ccitt.ko
lib/modules/2.6.38-1096-gc49343d/kernel/fs/
lib/modules/2.6.38-1096-gc49343d/kernel/fs/autofs4/
lib/modules/2.6.38-1096-gc49343d/kernel/fs/autofs4/autofs4.ko
lib/modules/2.6.38-1096-gc49343d/kernel/fs/nls/
lib/modules/2.6.38-1096-gc49343d/kernel/fs/nls/nls_ascii.ko
lib/modules/2.6.38-1096-gc49343d/kernel/fs/nls/nls_utf8.ko
lib/libssp.so.0
lib/ld-linux.so.3
lib/libanl.so.1
lib/libvolume_id.so.0.81.0
lib/libnss_compat.so.2
lib/libSegFault.so
lib/libthread_db-1.0.so
lib/libnss_files-2.11.1.so
lib/libnss_files.so.2
lib/libthread_db.so.1
lib/libresolv.so.2
lib/libnss_dns-2.11.1.so
lib/librt.so.1
lib/libnss_compat-2.11.1.so
lib/libnsl-2.11.1.so
lib/libpcprofile.so
lib/libtermcap.so
lib/libnss_nisplus-2.11.1.so
lib/libnsl.so.1
lib/libgcc_s.so.1
lib/libresolv-2.11.1.so
lib/libstdc++.so.6.0.13
lib/libmemusage.so
lib/libm.so.6
lib/libm-2.11.1.so
lib/libpthread.so.0
lib/libcrypt.so.1
lib/libnss_nis-2.11.1.so
lib/firmware/
lib/firmware/LICENCE.atheros_firmware
lib/firmware/sdma/
lib/firmware/sdma/sdma-imx35-to1.bin
lib/firmware/sdma/sdma-imx31-to2.bin
lib/firmware/sdma/sdma-imx51-to3.bin
lib/firmware/sdma/sdma-imx31-to1.bin
lib/firmware/sdma/sdma-imx35-to2.bin
lib/firmware/sdma/sdma-imx53-to1.bin
lib/firmware/sdma/sdma-imx25-to1.bin
lib/firmware/vpu/
lib/firmware/vpu/vpu_fw_imx6d.bin
lib/firmware/vpu/vpu_fw_imx51.bin
lib/firmware/vpu/vpu_fw_imx6q.bin
lib/firmware/vpu/vpu_fw_imx27_TO2.bin
lib/firmware/vpu/Android.mk
lib/firmware/vpu/vpu_fw_imx53.bin
lib/firmware/vpu/vpu_fw_imx27_TO1.bin
lib/firmware/ar3k/
lib/firmware/ar3k/Android.mk
lib/firmware/ar3k/30101/
lib/firmware/ar3k/30101/PS_ASIC.pst
lib/firmware/ar3k/30101/ar3kbdaddr.pst
lib/firmware/ar3k/30101/RamPatch.txt
lib/firmware/ar3k/30101/Readme.txt
lib/firmware/Android.mk
lib/firmware/README
lib/firmware/ath6k/
lib/firmware/ath6k/Android.mk
lib/firmware/ath6k/AR6102/
lib/firmware/ath6k/AR6102/eeprom.bin
lib/firmware/ath6k/AR6102/data.patch.hw2_0.bin
lib/firmware/ath6k/AR6102/calData_ar6102_15dBm.bin
lib/firmware/ath6k/AR6102/eeprom.data
lib/firmware/ath6k/AR6102/athwlan.bin.z77
lib/firmware/ath6k/AR6102/README.txt
lib/firmware/ath6k/AR6003/
lib/firmware/ath6k/AR6003/hw1.0/
lib/firmware/ath6k/AR6003/hw1.0/otp.bin.z77
lib/firmware/ath6k/AR6003/hw1.0/bdata.SD32.bin
lib/firmware/ath6k/AR6003/hw1.0/athwlan.bin.z77
lib/firmware/ath6k/AR6003/hw1.0/bdata.WB31.bin
lib/firmware/ath6k/AR6003/hw1.0/data.patch.bin
lib/firmware/ath6k/AR6003/hw1.0/bdata.SD31.bin
lib/firmware/ath6k/AR6003/PS_ASIC.pst
lib/firmware/ath6k/AR6003/PS_ASIC_aclLowPri.pst
lib/firmware/ath6k/AR6003/hw2.0/
lib/firmware/ath6k/AR6003/hw2.0/otp.bin.z77
lib/firmware/ath6k/AR6003/hw2.0/data.rom.bin
lib/firmware/ath6k/AR6003/hw2.0/regTest.bin
lib/firmware/ath6k/AR6003/hw2.0/perfcnt.bin
lib/firmware/ath6k/AR6003/hw2.0/bdata.SD32.bin
lib/firmware/ath6k/AR6003/hw2.0/memtest.bin
lib/firmware/ath6k/AR6003/hw2.0/data.patch.hw2_0.bin
lib/firmware/ath6k/AR6003/hw2.0/athwlan.bin
lib/firmware/ath6k/AR6003/hw2.0/otp_test.bin
lib/firmware/ath6k/AR6003/hw2.0/utf.bin
lib/firmware/ath6k/AR6003/hw2.0/fakeBoardData_AR6003_v2_0.bin
lib/firmware/ath6k/AR6003/hw2.0/apidemo.bin
lib/firmware/ath6k/AR6003/hw2.0/regulatoryData_AG.bin
lib/firmware/ath6k/AR6003/hw2.0/endpointping.bin
lib/firmware/ath6k/AR6003/hw2.0/athwlan.bin.z77
lib/firmware/ath6k/AR6003/hw2.0/serialport.bin
lib/firmware/ath6k/AR6003/hw2.0/device.bin
lib/firmware/ath6k/AR6003/hw2.0/whaltest.bin
lib/firmware/ath6k/AR6003/hw2.0/bdata.WB31.bin
lib/firmware/ath6k/AR6003/hw2.0/athtcmd_ram.bin
lib/firmware/ath6k/AR6003/hw2.0/data.patch.bin
lib/firmware/ath6k/AR6003/hw2.0/bdata.SD31.bin
lib/firmware/ath6k/AR6003/RamPatch.txt
lib/firmware/ath6k/AR6003/hw2.1.1/
lib/firmware/ath6k/AR6003/hw2.1.1/athwlan.bin
lib/firmware/ath6k/AR6003/hw2.1.1/otp.bin
lib/firmware/ath6k/AR6003/hw2.1.1/data.patch.bin
lib/firmware/ath6k/AR6003/hw2.1.1/bdata.SD31.bin
lib/libBrokenLocale.so.1
lib/libssp.so.0.0.0
lib/libdl.so.2
lib/libpthread-2.11.1.so
lost+found/
mnt/
mnt/floppy/
mnt/rwfs/
mnt/src/
mnt/cdrom/
mnt/nfs/
opt/
proc/
root/
root/.kobs
rootfs.tar.bz2
sbin/
sbin/udevcontrol
sbin/halt
sbin/insmod
sbin/ifdown
sbin/telnetd
sbin/syslogd
sbin/chroot
sbin/dhcprelay
sbin/lsmod
sbin/udevsettle
sbin/udevadm
sbin/klogd
sbin/blockdev
sbin/ubidetach
sbin/ubiattach
sbin/rmmod
sbin/modinfo
sbin/modprobe
sbin/nbd-client
sbin/rdate
sbin/inetd
sbin/ifconfig
sbin/udevtrigger
sbin/hwclock
sbin/udevd
sbin/loadkmap
sbin/ip
sbin/fdisk
sbin/losetup
sbin/fsck.minix
sbin/adjtimex
sbin/logread
sbin/setlogcons
sbin/mkfs.minix
sbin/loadfont
sbin/fbset
sbin/swapoff
sbin/init
sbin/pivot_root
sbin/udhcpd
sbin/mke2fs
sbin/mkfs.ext2
sbin/httpd
sbin/sysctl
sbin/hotplug
sbin/watchdog
sbin/udhcpc
sbin/bootchartd
sbin/ntpd
sbin/mkswap
sbin/poweroff
sbin/reboot
sbin/ifup
sbin/arp
sbin/route
sbin/swapon
sbin/getty
sys/
tmp/
tmp/ltib/
unit_tests/
unit_tests/mxc_iim_test.out
unit_tests/autorun-mxc_uart.sh
unit_tests/scc_test
unit_tests/autorun-wdog.sh
unit_tests/config_encdec
unit_tests/mxc_v4l2_overlay.out
unit_tests/rtctest.out
unit_tests/mxc_keyb_test.sh
unit_tests/autorun-usb-gadget.sh
unit_tests/check_ioctls.out
unit_tests/autorun-scc2.sh
unit_tests/audio8k16S.wav
unit_tests/check_2w1r.out
unit_tests/ar3k-bt-start.sh
unit_tests/autorun-vpu.sh
unit_tests/check_recording.out
unit_tests/mxc_vpu_test.out
unit_tests/autorun-suite.txt
unit_tests/mxc_spi_test1.out
unit_tests/memtool
unit_tests/autorun-mmc.sh
unit_tests/autorun-owire.sh
unit_tests/mxc_v4l2_capture.out
unit_tests/autorun-rtc.sh
unit_tests/mxc_i2c_test_samsung_cam.out
unit_tests/mxc_uart_test.out
unit_tests/autorun-usb-host.sh
unit_tests/mxc_pf_test.out
unit_tests/encrypt_decrypt_tests.sh
unit_tests/autorun-v4l2.sh
unit_tests/fail_mode_tests.sh
unit_tests/mxc_l2switch_test.out
unit_tests/wdt_driver_test.out
unit_tests/autorun-pf.sh
unit_tests/autorun-asrc.sh
unit_tests/check_mixer.out
unit_tests/mxc_tve_test.sh
unit_tests/mxc_sdma_test.out
unit_tests/key_slot_tests.sh
unit_tests/autorun-ata.sh
unit_tests/config_net
unit_tests/mxc_isl29023.out
unit_tests/check_synchronization.out
unit_tests/config_dec
unit_tests/autorun.sh
unit_tests/mxc_asrc_test.out
unit_tests/autorun-oprofile.sh
unit_tests/mxc_i2c_test.out
unit_tests/autorun-firi.sh
unit_tests/autorun-fb.sh
unit_tests/rtc_timesetnotification_test.out
unit_tests/autorun-scc.sh
unit_tests/ipudev_config_file
unit_tests/mxc_v4l2_tvin.out
unit_tests/hciattach-ar3k.bin
unit_tests/autorun-keypad.sh
unit_tests/mxc_irlan_test.sh
unit_tests/mxc_v4l2_still.out
unit_tests/rtcwakeup.out
unit_tests/check_volume2.out
unit_tests/dryice.sh
unit_tests/partition_tests.sh
unit_tests/mxc_v4l2_output.out
unit_tests/autorun-sound.sh
unit_tests/stefan_interlaced_320x240_5frames.yv12
unit_tests/check_audio.out
unit_tests/mxc_i2c_test_usb.out
unit_tests/test-utils.sh
unit_tests/mxc_fb_test.out
unit_tests/test_subs.sh
unit_tests/mxc_i2c_test_magna_cam.out
unit_tests/mxc_uart_xmit_test.out
unit_tests/scc2_test.out
unit_tests/check_minor_open.out
unit_tests/scc_setup.sh
unit_tests/mxc_ipudev_test.out
unit_tests/akiyo.mp4
unit_tests/scc2_setup.sh
unit_tests/mxc_i2c_slave_test.out
unit_tests/mxc_mlb_test.out
unit_tests/autorun-ipu.sh
usr/
usr/include/
usr/include/ipu.h
usr/include/termcap.h
usr/include/libvolume_id.h
usr/include/pxp_lib.h
usr/include/mxc_ipu_hl_lib.h
usr/include/vpu_io.h
usr/include/vpu_lib.h
usr/share/
usr/share/doc/
usr/share/doc/linux-firmware/
usr/share/doc/linux-firmware/licenses/
usr/share/doc/linux-firmware/licenses/vpu/
usr/share/doc/linux-firmware/licenses/vpu/EULA
usr/share/doc/linux-firmware/licenses/ar3k/
usr/share/doc/linux-firmware/licenses/ar3k/30101/
usr/share/doc/linux-firmware/licenses/ar3k/30101/LICENSE_Apache.txt
usr/share/doc/linux-firmware/licenses/COPYING
usr/share/doc/linux-firmware/licenses/ath6k/
usr/share/doc/linux-firmware/licenses/ath6k/AR6102/
usr/share/doc/linux-firmware/licenses/ath6k/AR6102/License.txt
usr/share/doc/linux-firmware/licenses/ath6k/AR6003/
usr/share/doc/linux-firmware/licenses/ath6k/AR6003/README.chromium
usr/share/doc/linux-firmware/licenses/ath6k/AR6003/License.txt
usr/share/udhcpc/
usr/share/udhcpc/default.script
usr/bin/
usr/bin/startx
usr/bin/kobs-ng
usr/bin/udevtest
usr/bin/udevinfo
usr/src/
usr/src/linux/
usr/src/linux/include/
usr/src/linux/include/scsi/
usr/src/linux/include/scsi/scsi_bsg_fc.h
usr/src/linux/include/scsi/.install
usr/src/linux/include/scsi/scsi_netlink.h
usr/src/linux/include/scsi/fc/
usr/src/linux/include/scsi/fc/fc_gs.h
usr/src/linux/include/scsi/fc/.install
usr/src/linux/include/scsi/fc/fc_fs.h
usr/src/linux/include/scsi/fc/fc_ns.h
usr/src/linux/include/scsi/fc/fc_els.h
usr/src/linux/include/scsi/fc/..install.cmd
usr/src/linux/include/scsi/..install.cmd
usr/src/linux/include/scsi/scsi_netlink_fc.h
usr/src/linux/include/video/
usr/src/linux/include/video/.install
usr/src/linux/include/video/edid.h
usr/src/linux/include/video/sisfb.h
usr/src/linux/include/video/..install.cmd
usr/src/linux/include/video/uvesafb.h
usr/src/linux/include/.install
usr/src/linux/include/xen/
usr/src/linux/include/xen/privcmd.h
usr/src/linux/include/xen/.install
usr/src/linux/include/xen/..install.cmd
usr/src/linux/include/xen/evtchn.h
usr/src/linux/include/asm-generic/
usr/src/linux/include/asm-generic/stat.h
usr/src/linux/include/asm-generic/posix_types.h
usr/src/linux/include/asm-generic/errno.h
usr/src/linux/include/asm-generic/fcntl.h
usr/src/linux/include/asm-generic/bitsperlong.h
usr/src/linux/include/asm-generic/auxvec.h
usr/src/linux/include/asm-generic/siginfo.h
usr/src/linux/include/asm-generic/setup.h
usr/src/linux/include/asm-generic/sockios.h
usr/src/linux/include/asm-generic/ipcbuf.h
usr/src/linux/include/asm-generic/.install
usr/src/linux/include/asm-generic/shmparam.h
usr/src/linux/include/asm-generic/ucontext.h
usr/src/linux/include/asm-generic/unistd.h
usr/src/linux/include/asm-generic/ioctls.h
usr/src/linux/include/asm-generic/swab.h
usr/src/linux/include/asm-generic/poll.h
usr/src/linux/include/asm-generic/resource.h
usr/src/linux/include/asm-generic/socket.h
usr/src/linux/include/asm-generic/mman.h
usr/src/linux/include/asm-generic/int-l64.h
usr/src/linux/include/asm-generic/types.h
usr/src/linux/include/asm-generic/ioctl.h
usr/src/linux/include/asm-generic/termbits.h
usr/src/linux/include/asm-generic/signal.h
usr/src/linux/include/asm-generic/msgbuf.h
usr/src/linux/include/asm-generic/errno-base.h
usr/src/linux/include/asm-generic/mman-common.h
usr/src/linux/include/asm-generic/param.h
usr/src/linux/include/asm-generic/statfs.h
usr/src/linux/include/asm-generic/termios.h
usr/src/linux/include/asm-generic/..install.cmd
usr/src/linux/include/asm-generic/shmbuf.h
usr/src/linux/include/asm-generic/sembuf.h
usr/src/linux/include/asm-generic/int-ll64.h
usr/src/linux/include/asm-generic/signal-defs.h
usr/src/linux/include/sound/
usr/src/linux/include/sound/hdspm.h
usr/src/linux/include/sound/asequencer.h
usr/src/linux/include/sound/hdsp.h
usr/src/linux/include/sound/asound_fm.h
usr/src/linux/include/sound/.install
usr/src/linux/include/sound/asound.h
usr/src/linux/include/sound/sfnt_info.h
usr/src/linux/include/sound/..install.cmd
usr/src/linux/include/sound/emu10k1.h
usr/src/linux/include/sound/sb16_csp.h
usr/src/linux/include/..install.cmd
usr/src/linux/include/mtd/
usr/src/linux/include/mtd/mtd-abi.h
usr/src/linux/include/mtd/.install
usr/src/linux/include/mtd/nftl-user.h
usr/src/linux/include/mtd/mtd-user.h
usr/src/linux/include/mtd/ubi-user.h
usr/src/linux/include/mtd/inftl-user.h
usr/src/linux/include/mtd/..install.cmd
usr/src/linux/include/linux/
usr/src/linux/include/linux/hid.h
usr/src/linux/include/linux/pps.h
usr/src/linux/include/linux/i2c.h
usr/src/linux/include/linux/connector.h
usr/src/linux/include/linux/ipu.h
usr/src/linux/include/linux/auto_fs4.h
usr/src/linux/include/linux/romfs_fs.h
usr/src/linux/include/linux/nubus.h
usr/src/linux/include/linux/cyclades.h
usr/src/linux/include/linux/ext2_fs.h
usr/src/linux/include/linux/can/
usr/src/linux/include/linux/can/.install
usr/src/linux/include/linux/can/netlink.h
usr/src/linux/include/linux/can/error.h
usr/src/linux/include/linux/can/raw.h
usr/src/linux/include/linux/can/bcm.h
usr/src/linux/include/linux/can/..install.cmd
usr/src/linux/include/linux/in6.h
usr/src/linux/include/linux/ip.h
usr/src/linux/include/linux/virtio_rng.h
usr/src/linux/include/linux/wait.h
usr/src/linux/include/linux/wimax.h
usr/src/linux/include/linux/stat.h
usr/src/linux/include/linux/rtc.h
usr/src/linux/include/linux/ipc.h
usr/src/linux/include/linux/pg.h
usr/src/linux/include/linux/quota.h
usr/src/linux/include/linux/dn.h
usr/src/linux/include/linux/posix_types.h
usr/src/linux/include/linux/dlm_device.h
usr/src/linux/include/linux/fib_rules.h
usr/src/linux/include/linux/keyboard.h
usr/src/linux/include/linux/tipc.h
usr/src/linux/include/linux/utsname.h
usr/src/linux/include/linux/atm_he.h
usr/src/linux/include/linux/virtio_net.h
usr/src/linux/include/linux/errno.h
usr/src/linux/include/linux/falloc.h
usr/src/linux/include/linux/arcfb.h
usr/src/linux/include/linux/dcbnl.h
usr/src/linux/include/linux/dlm.h
usr/src/linux/include/linux/fcntl.h
usr/src/linux/include/linux/tipc_config.h
usr/src/linux/include/linux/rose.h
usr/src/linux/include/linux/mempolicy.h
usr/src/linux/include/linux/efs_fs_sb.h
usr/src/linux/include/linux/major.h
usr/src/linux/include/linux/dvb/
usr/src/linux/include/linux/dvb/video.h
usr/src/linux/include/linux/dvb/version.h
usr/src/linux/include/linux/dvb/.install
usr/src/linux/include/linux/dvb/net.h
usr/src/linux/include/linux/dvb/frontend.h
usr/src/linux/include/linux/dvb/dmx.h
usr/src/linux/include/linux/dvb/osd.h
usr/src/linux/include/linux/dvb/ca.h
usr/src/linux/include/linux/dvb/..install.cmd
usr/src/linux/include/linux/dvb/audio.h
usr/src/linux/include/linux/nfs.h
usr/src/linux/include/linux/coda_psdev.h
usr/src/linux/include/linux/fiemap.h
usr/src/linux/include/linux/videodev2.h
usr/src/linux/include/linux/map_to_7segment.h
usr/src/linux/include/linux/errqueue.h
usr/src/linux/include/linux/virtio_blk.h
usr/src/linux/include/linux/xattr.h
usr/src/linux/include/linux/pktcdvd.h
usr/src/linux/include/linux/netfilter_ipv4.h
usr/src/linux/include/linux/chio.h
usr/src/linux/include/linux/bpqether.h
usr/src/linux/include/linux/auxvec.h
usr/src/linux/include/linux/nvram.h
usr/src/linux/include/linux/utime.h
usr/src/linux/include/linux/nfs2.h
usr/src/linux/include/linux/atmppp.h
usr/src/linux/include/linux/atm_tcp.h
usr/src/linux/include/linux/fd.h
usr/src/linux/include/linux/hiddev.h
usr/src/linux/include/linux/const.h
usr/src/linux/include/linux/omapfb.h
usr/src/linux/include/linux/rfkill.h
usr/src/linux/include/linux/fanotify.h
usr/src/linux/include/linux/ivtvfb.h
usr/src/linux/include/linux/icmp.h
usr/src/linux/include/linux/atmclip.h
usr/src/linux/include/linux/cn_proc.h
usr/src/linux/include/linux/coff.h
usr/src/linux/include/linux/hdlcdrv.h
usr/src/linux/include/linux/if_fc.h
usr/src/linux/include/linux/atmioc.h
usr/src/linux/include/linux/selinux_netlink.h
usr/src/linux/include/linux/cdrom.h
usr/src/linux/include/linux/veth.h
usr/src/linux/include/linux/udp.h
usr/src/linux/include/linux/gameport.h
usr/src/linux/include/linux/securebits.h
usr/src/linux/include/linux/times.h
usr/src/linux/include/linux/atmdev.h
usr/src/linux/include/linux/patchkey.h
usr/src/linux/include/linux/if_strip.h
usr/src/linux/include/linux/acct.h
usr/src/linux/include/linux/timex.h
usr/src/linux/include/linux/if_vlan.h
usr/src/linux/include/linux/random.h
usr/src/linux/include/linux/serial_core.h
usr/src/linux/include/linux/if_tr.h
usr/src/linux/include/linux/if_cablemodem.h
usr/src/linux/include/linux/stddef.h
usr/src/linux/include/linux/if_eql.h
usr/src/linux/include/linux/ncp_fs.h
usr/src/linux/include/linux/isdn_ppp.h
usr/src/linux/include/linux/elf-em.h
usr/src/linux/include/linux/sockios.h
usr/src/linux/include/linux/netfilter_decnet.h
usr/src/linux/include/linux/nfs_idmap.h
usr/src/linux/include/linux/jffs2.h
usr/src/linux/include/linux/ppp-comp.h
usr/src/linux/include/linux/blktrace_api.h
usr/src/linux/include/linux/telephony.h
usr/src/linux/include/linux/pkt_cls.h
usr/src/linux/include/linux/perf_event.h
usr/src/linux/include/linux/version.h
usr/src/linux/include/linux/usbdevice_fs.h
usr/src/linux/include/linux/pci.h
usr/src/linux/include/linux/if_frad.h
usr/src/linux/include/linux/if_fddi.h
usr/src/linux/include/linux/atalk.h
usr/src/linux/include/linux/hpet.h
usr/src/linux/include/linux/netfilter_bridge/
usr/src/linux/include/linux/netfilter_bridge/ebt_arp.h
usr/src/linux/include/linux/netfilter_bridge/ebt_limit.h
usr/src/linux/include/linux/netfilter_bridge/ebt_ulog.h
usr/src/linux/include/linux/netfilter_bridge/.install
usr/src/linux/include/linux/netfilter_bridge/ebt_802_3.h
usr/src/linux/include/linux/netfilter_bridge/ebt_vlan.h
usr/src/linux/include/linux/netfilter_bridge/ebt_pkttype.h
usr/src/linux/include/linux/netfilter_bridge/ebt_nflog.h
usr/src/linux/include/linux/netfilter_bridge/ebt_log.h
usr/src/linux/include/linux/netfilter_bridge/ebt_mark_m.h
usr/src/linux/include/linux/netfilter_bridge/ebt_among.h
usr/src/linux/include/linux/netfilter_bridge/ebtables.h
usr/src/linux/include/linux/netfilter_bridge/ebt_arpreply.h
usr/src/linux/include/linux/netfilter_bridge/ebt_mark_t.h
usr/src/linux/include/linux/netfilter_bridge/ebt_stp.h
usr/src/linux/include/linux/netfilter_bridge/ebt_ip6.h
usr/src/linux/include/linux/netfilter_bridge/..install.cmd
usr/src/linux/include/linux/netfilter_bridge/ebt_nat.h
usr/src/linux/include/linux/netfilter_bridge/ebt_ip.h
usr/src/linux/include/linux/netfilter_bridge/ebt_redirect.h
usr/src/linux/include/linux/mxc_sahara.h
usr/src/linux/include/linux/usb/
usr/src/linux/include/linux/usb/g_printer.h
usr/src/linux/include/linux/usb/.install
usr/src/linux/include/linux/usb/gadgetfs.h
usr/src/linux/include/linux/usb/ch9.h
usr/src/linux/include/linux/usb/midi.h
usr/src/linux/include/linux/usb/cdc.h
usr/src/linux/include/linux/usb/tmc.h
usr/src/linux/include/linux/usb/..install.cmd
usr/src/linux/include/linux/usb/audio.h
usr/src/linux/include/linux/usb/ch11.h
usr/src/linux/include/linux/tty.h
usr/src/linux/include/linux/synclink.h
usr/src/linux/include/linux/uio.h
usr/src/linux/include/linux/.install
usr/src/linux/include/linux/can.h
usr/src/linux/include/linux/ivtv.h
usr/src/linux/include/linux/mii.h
usr/src/linux/include/linux/prctl.h
usr/src/linux/include/linux/ipx.h
usr/src/linux/include/linux/nfs4.h
usr/src/linux/include/linux/virtio_pci.h
usr/src/linux/include/linux/atmsvc.h
usr/src/linux/include/linux/a.out.h
usr/src/linux/include/linux/kd.h
usr/src/linux/include/linux/personality.h
usr/src/linux/include/linux/fb.h
usr/src/linux/include/linux/serio.h
usr/src/linux/include/linux/tc_act/
usr/src/linux/include/linux/tc_act/tc_csum.h
usr/src/linux/include/linux/tc_act/tc_ipt.h
usr/src/linux/include/linux/tc_act/.install
usr/src/linux/include/linux/tc_act/tc_pedit.h
usr/src/linux/include/linux/tc_act/tc_skbedit.h
usr/src/linux/include/linux/tc_act/tc_nat.h
usr/src/linux/include/linux/tc_act/tc_mirred.h
usr/src/linux/include/linux/tc_act/..install.cmd
usr/src/linux/include/linux/tc_act/tc_gact.h
usr/src/linux/include/linux/nfs3.h
usr/src/linux/include/linux/keyctl.h
usr/src/linux/include/linux/tiocl.h
usr/src/linux/include/linux/scc.h
usr/src/linux/include/linux/isl29023.h
usr/src/linux/include/linux/sonet.h
usr/src/linux/include/linux/agpgart.h
usr/src/linux/include/linux/mxc_pf.h
usr/src/linux/include/linux/time.h
usr/src/linux/include/linux/sched.h
usr/src/linux/include/linux/if_alg.h
usr/src/linux/include/linux/wimax/
usr/src/linux/include/linux/wimax/i2400m.h
usr/src/linux/include/linux/wimax/.install
usr/src/linux/include/linux/wimax/..install.cmd
usr/src/linux/include/linux/aio_abi.h
usr/src/linux/include/linux/ultrasound.h
usr/src/linux/include/linux/netlink.h
usr/src/linux/include/linux/tcp.h
usr/src/linux/include/linux/un.h
usr/src/linux/include/linux/elf-fdpic.h
usr/src/linux/include/linux/parport.h
usr/src/linux/include/linux/ncp_no.h
usr/src/linux/include/linux/bsg.h
usr/src/linux/include/linux/in_route.h
usr/src/linux/include/linux/qnx4_fs.h
usr/src/linux/include/linux/sound.h
usr/src/linux/include/linux/pci_regs.h
usr/src/linux/include/linux/atm_nicstar.h
usr/src/linux/include/linux/blk_types.h
usr/src/linux/include/linux/mroute6.h
usr/src/linux/include/linux/i2o-dev.h
usr/src/linux/include/linux/unistd.h
usr/src/linux/include/linux/binfmts.h
usr/src/linux/include/linux/affs_hardblocks.h
usr/src/linux/include/linux/lp.h
usr/src/linux/include/linux/fs.h
usr/src/linux/include/linux/pmic_external.h
usr/src/linux/include/linux/pxp_dma.h
usr/src/linux/include/linux/net_dropmon.h
usr/src/linux/include/linux/genetlink.h
usr/src/linux/include/linux/elf.h
usr/src/linux/include/linux/qnxtypes.h
usr/src/linux/include/linux/meye.h
usr/src/linux/include/linux/hdreg.h
usr/src/linux/include/linux/mxc_scc_driver.h
usr/src/linux/include/linux/pmic_adc.h
usr/src/linux/include/linux/neighbour.h
usr/src/linux/include/linux/sysctl.h
usr/src/linux/include/linux/swab.h
usr/src/linux/include/linux/poll.h
usr/src/linux/include/linux/netfilter_arp.h
usr/src/linux/include/linux/x25.h
usr/src/linux/include/linux/loop.h
usr/src/linux/include/linux/sem.h
usr/src/linux/include/linux/if_plip.h
usr/src/linux/include/linux/uinput.h
usr/src/linux/include/linux/ethtool.h
usr/src/linux/include/linux/resource.h
usr/src/linux/include/linux/net.h
usr/src/linux/include/linux/hidraw.h
usr/src/linux/include/linux/atmarp.h
usr/src/linux/include/linux/i8k.h
usr/src/linux/include/linux/mqueue.h
usr/src/linux/include/linux/gigaset_dev.h
usr/src/linux/include/linux/pmic_battery.h
usr/src/linux/include/linux/phantom.h
usr/src/linux/include/linux/virtio_console.h
usr/src/linux/include/linux/mroute.h
usr/src/linux/include/linux/ncp.h
usr/src/linux/include/linux/virtio_9p.h
usr/src/linux/include/linux/signalfd.h
usr/src/linux/include/linux/mxc_v4l2.h
usr/src/linux/include/linux/in.h
usr/src/linux/include/linux/nfsacl.h
usr/src/linux/include/linux/socket.h
usr/src/linux/include/linux/taskstats.h
usr/src/linux/include/linux/igmp.h
usr/src/linux/include/linux/netfilter_bridge.h
usr/src/linux/include/linux/icmpv6.h
usr/src/linux/include/linux/atm_idt77105.h
usr/src/linux/include/linux/sunrpc/
usr/src/linux/include/linux/sunrpc/.install
usr/src/linux/include/linux/sunrpc/debug.h
usr/src/linux/include/linux/sunrpc/..install.cmd
usr/src/linux/include/linux/cdk.h
usr/src/linux/include/linux/mman.h
usr/src/linux/include/linux/eventpoll.h
usr/src/linux/include/linux/pfkeyv2.h
usr/src/linux/include/linux/nfs_fs.h
usr/src/linux/include/linux/netfilter_ipv6.h
usr/src/linux/include/linux/atmsap.h
usr/src/linux/include/linux/dlm_netlink.h
usr/src/linux/include/linux/phonet.h
usr/src/linux/include/linux/raid/
usr/src/linux/include/linux/raid/.install
usr/src/linux/include/linux/raid/md_p.h
usr/src/linux/include/linux/raid/md_u.h
usr/src/linux/include/linux/raid/..install.cmd
usr/src/linux/include/linux/msg.h
usr/src/linux/include/linux/vhost.h
usr/src/linux/include/linux/reiserfs_xattr.h
usr/src/linux/include/linux/dccp.h
usr/src/linux/include/linux/vt.h
usr/src/linux/include/linux/nbd.h
usr/src/linux/include/linux/reiserfs_fs.h
usr/src/linux/include/linux/if.h
usr/src/linux/include/linux/ncp_mount.h
usr/src/linux/include/linux/serial.h
usr/src/linux/include/linux/if_infiniband.h
usr/src/linux/include/linux/toshiba.h
usr/src/linux/include/linux/if_ltalk.h
usr/src/linux/include/linux/netfilter_ipv4/
usr/src/linux/include/linux/netfilter_ipv4/ipt_REJECT.h
usr/src/linux/include/linux/netfilter_ipv4/ip_tables.h
usr/src/linux/include/linux/netfilter_ipv4/ipt_realm.h
usr/src/linux/include/linux/netfilter_ipv4/.install
usr/src/linux/include/linux/netfilter_ipv4/ipt_ECN.h
usr/src/linux/include/linux/netfilter_ipv4/ipt_ttl.h
usr/src/linux/include/linux/netfilter_ipv4/ipt_CLUSTERIP.h
usr/src/linux/include/linux/netfilter_ipv4/ipt_addrtype.h
usr/src/linux/include/linux/netfilter_ipv4/ipt_ULOG.h
usr/src/linux/include/linux/netfilter_ipv4/ipt_TTL.h
usr/src/linux/include/linux/netfilter_ipv4/ipt_SAME.h
usr/src/linux/include/linux/netfilter_ipv4/ipt_LOG.h
usr/src/linux/include/linux/netfilter_ipv4/ipt_ah.h
usr/src/linux/include/linux/netfilter_ipv4/..install.cmd
usr/src/linux/include/linux/netfilter_ipv4/ip_queue.h
usr/src/linux/include/linux/netfilter_ipv4/ipt_ecn.h
usr/src/linux/include/linux/mxcfb.h
usr/src/linux/include/linux/flat.h
usr/src/linux/include/linux/joystick.h
usr/src/linux/include/linux/byteorder/
usr/src/linux/include/linux/byteorder/little_endian.h
usr/src/linux/include/linux/byteorder/.install
usr/src/linux/include/linux/byteorder/big_endian.h
usr/src/linux/include/linux/byteorder/..install.cmd
usr/src/linux/include/linux/firewire-cdev.h
usr/src/linux/include/linux/apm_bios.h
usr/src/linux/include/linux/kernel.h
usr/src/linux/include/linux/futex.h
usr/src/linux/include/linux/if_tun.h
usr/src/linux/include/linux/if_tunnel.h
usr/src/linux/include/linux/limits.h
usr/src/linux/include/linux/raw.h
usr/src/linux/include/linux/generic_serial.h
usr/src/linux/include/linux/filter.h
usr/src/linux/include/linux/som.h
usr/src/linux/include/linux/capi.h
usr/src/linux/include/linux/cramfs_fs.h
usr/src/linux/include/linux/tc_ematch/
usr/src/linux/include/linux/tc_ematch/tc_em_cmp.h
usr/src/linux/include/linux/tc_ematch/tc_em_nbyte.h
usr/src/linux/include/linux/tc_ematch/.install
usr/src/linux/include/linux/tc_ematch/tc_em_meta.h
usr/src/linux/include/linux/tc_ematch/..install.cmd
usr/src/linux/include/linux/tc_ematch/tc_em_text.h
usr/src/linux/include/linux/dm-ioctl.h
usr/src/linux/include/linux/bfs_fs.h
usr/src/linux/include/linux/blkpg.h
usr/src/linux/include/linux/types.h
usr/src/linux/include/linux/i2c-dev.h
usr/src/linux/include/linux/ixjuser.h
usr/src/linux/include/linux/if_addrlabel.h
usr/src/linux/include/linux/l2tp.h
usr/src/linux/include/linux/nfs_mount.h
usr/src/linux/include/linux/if_arcnet.h
usr/src/linux/include/linux/atmbr2684.h
usr/src/linux/include/linux/ipv6_route.h
usr/src/linux/include/linux/virtio_ring.h
usr/src/linux/include/linux/if_addr.h
usr/src/linux/include/linux/if_bridge.h
usr/src/linux/include/linux/fdreg.h
usr/src/linux/include/linux/ioctl.h
usr/src/linux/include/linux/ipmi_msgdefs.h
usr/src/linux/include/linux/adb.h
usr/src/linux/include/linux/if_slip.h
usr/src/linux/include/linux/mxc_asrc.h
usr/src/linux/include/linux/suspend_ioctls.h
usr/src/linux/include/linux/if_pppol2tp.h
usr/src/linux/include/linux/net_tstamp.h
usr/src/linux/include/linux/shm.h
usr/src/linux/include/linux/cciss_ioctl.h
usr/src/linux/include/linux/atm_eni.h
usr/src/linux/include/linux/rds.h
usr/src/linux/include/linux/hdlc/
usr/src/linux/include/linux/hdlc/.install
usr/src/linux/include/linux/hdlc/ioctl.h
usr/src/linux/include/linux/hdlc/..install.cmd
usr/src/linux/include/linux/pmic_rtc.h
usr/src/linux/include/linux/mtio.h
usr/src/linux/include/linux/ip_vs.h
usr/src/linux/include/linux/signal.h
usr/src/linux/include/linux/nl80211.h
usr/src/linux/include/linux/minix_fs.h
usr/src/linux/include/linux/netfilter.h
usr/src/linux/include/linux/elfcore.h
usr/src/linux/include/linux/if_pppox.h
usr/src/linux/include/linux/ip6_tunnel.h
usr/src/linux/include/linux/gen_stats.h
usr/src/linux/include/linux/nfsd/
usr/src/linux/include/linux/nfsd/syscall.h
usr/src/linux/include/linux/nfsd/stats.h
usr/src/linux/include/linux/nfsd/const.h
usr/src/linux/include/linux/nfsd/.install
usr/src/linux/include/linux/nfsd/debug.h
usr/src/linux/include/linux/nfsd/..install.cmd
usr/src/linux/include/linux/nfsd/nfsfh.h
usr/src/linux/include/linux/nfsd/export.h
usr/src/linux/include/linux/isdn_divertif.h
usr/src/linux/include/linux/ipv6.h
usr/src/linux/include/linux/magic.h
usr/src/linux/include/linux/netrom.h
usr/src/linux/include/linux/oom.h
usr/src/linux/include/linux/fsl_devices.h
usr/src/linux/include/linux/pmu.h
usr/src/linux/include/linux/udf_fs_i.h
usr/src/linux/include/linux/n_r3964.h
usr/src/linux/include/linux/param.h
usr/src/linux/include/linux/mxc_si4702.h
usr/src/linux/include/linux/if_arp.h
usr/src/linux/include/linux/ptrace.h
usr/src/linux/include/linux/if_hippi.h
usr/src/linux/include/linux/iso_fs.h
usr/src/linux/include/linux/reboot.h
usr/src/linux/include/linux/if_packet.h
usr/src/linux/include/linux/if_bonding.h
usr/src/linux/include/linux/cgroupstats.h
usr/src/linux/include/linux/termios.h
usr/src/linux/include/linux/imx_adc.h
usr/src/linux/include/linux/cciss_defs.h
usr/src/linux/include/linux/kdev_t.h
usr/src/linux/include/linux/gfs2_ondisk.h
usr/src/linux/include/linux/ppp_defs.h
usr/src/linux/include/linux/netfilter_ipv6/
usr/src/linux/include/linux/netfilter_ipv6/ip6t_mh.h
usr/src/linux/include/linux/netfilter_ipv6/ip6t_LOG.h
usr/src/linux/include/linux/netfilter_ipv6/ip6t_hl.h
usr/src/linux/include/linux/netfilter_ipv6/ip6_tables.h
usr/src/linux/include/linux/netfilter_ipv6/ip6t_HL.h
usr/src/linux/include/linux/netfilter_ipv6/ip6t_ipv6header.h
usr/src/linux/include/linux/netfilter_ipv6/.install
usr/src/linux/include/linux/netfilter_ipv6/ip6t_rt.h
usr/src/linux/include/linux/netfilter_ipv6/ip6t_opts.h
usr/src/linux/include/linux/netfilter_ipv6/ip6t_REJECT.h
usr/src/linux/include/linux/netfilter_ipv6/ip6t_ah.h
usr/src/linux/include/linux/netfilter_ipv6/ip6t_frag.h
usr/src/linux/include/linux/netfilter_ipv6/..install.cmd
usr/src/linux/include/linux/..install.cmd
usr/src/linux/include/linux/irqnr.h
usr/src/linux/include/linux/snmp.h
usr/src/linux/include/linux/sonypi.h
usr/src/linux/include/linux/cm4000_cs.h
usr/src/linux/include/linux/mxc_srtc.h
usr/src/linux/include/linux/ppdev.h
usr/src/linux/include/linux/virtio_ids.h
usr/src/linux/include/linux/wanrouter.h
usr/src/linux/include/linux/if_ec.h
usr/src/linux/include/linux/inet_diag.h
usr/src/linux/include/linux/isdn/
usr/src/linux/include/linux/isdn/capicmd.h
usr/src/linux/include/linux/isdn/.install
usr/src/linux/include/linux/isdn/..install.cmd
usr/src/linux/include/linux/virtio_balloon.h
usr/src/linux/include/linux/mmtimer.h
usr/src/linux/include/linux/wireless.h
usr/src/linux/include/linux/capability.h
usr/src/linux/include/linux/atm.h
usr/src/linux/include/linux/msdos_fs.h
usr/src/linux/include/linux/fadvise.h
usr/src/linux/include/linux/mxc_mlb.h
usr/src/linux/include/linux/pmic_status.h
usr/src/linux/include/linux/cryptodev.h
usr/src/linux/include/linux/ipsec.h
usr/src/linux/include/linux/rtnetlink.h
usr/src/linux/include/linux/netfilter_arp/
usr/src/linux/include/linux/netfilter_arp/arp_tables.h
usr/src/linux/include/linux/netfilter_arp/.install
usr/src/linux/include/linux/netfilter_arp/..install.cmd
usr/src/linux/include/linux/netfilter_arp/arpt_mangle.h
usr/src/linux/include/linux/watchdog.h
usr/src/linux/include/linux/sdla.h
usr/src/linux/include/linux/radeonfb.h
usr/src/linux/include/linux/isdnif.h
usr/src/linux/include/linux/baycom.h
usr/src/linux/include/linux/dlm_plock.h
usr/src/linux/include/linux/coda.h
usr/src/linux/include/linux/hysdn_if.h
usr/src/linux/include/linux/screen_info.h
usr/src/linux/include/linux/xfrm.h
usr/src/linux/include/linux/soundcard.h
usr/src/linux/include/linux/auto_fs.h
usr/src/linux/include/linux/virtio_config.h
usr/src/linux/include/linux/kernelcapi.h
usr/src/linux/include/linux/mxc_scc2_driver.h
usr/src/linux/include/linux/irda.h
usr/src/linux/include/linux/if_ppp.h
usr/src/linux/include/linux/if_phonet.h
usr/src/linux/include/linux/pmic_light.h
usr/src/linux/include/linux/matroxfb.h
usr/src/linux/include/linux/if_x25.h
usr/src/linux/include/linux/b1lli.h
usr/src/linux/include/linux/ax25.h
usr/src/linux/include/linux/isdn.h
usr/src/linux/include/linux/string.h
usr/src/linux/include/linux/comstats.h
usr/src/linux/include/linux/atmlec.h
usr/src/linux/include/linux/dlmconstants.h
usr/src/linux/include/linux/input.h
usr/src/linux/include/linux/atmapi.h
usr/src/linux/include/linux/spi/
usr/src/linux/include/linux/spi/spidev.h
usr/src/linux/include/linux/spi/.install
usr/src/linux/include/linux/spi/..install.cmd
usr/src/linux/include/linux/adfs_fs.h
usr/src/linux/include/linux/dm-log-userspace.h
usr/src/linux/include/linux/cycx_cfm.h
usr/src/linux/include/linux/route.h
usr/src/linux/include/linux/fuse.h
usr/src/linux/include/linux/llc.h
usr/src/linux/include/linux/caif/
usr/src/linux/include/linux/caif/.install
usr/src/linux/include/linux/caif/caif_socket.h
usr/src/linux/include/linux/caif/if_caif.h
usr/src/linux/include/linux/caif/..install.cmd
usr/src/linux/include/linux/inotify.h
usr/src/linux/include/linux/if_ether.h
usr/src/linux/include/linux/serial_reg.h
usr/src/linux/include/linux/atm_zatm.h
usr/src/linux/include/linux/audit.h
usr/src/linux/include/linux/nfs4_mount.h
usr/src/linux/include/linux/cuda.h
usr/src/linux/include/linux/dqblk_xfs.h
usr/src/linux/include/linux/mxc_sim_interface.h
usr/src/linux/include/linux/hdlc.h
usr/src/linux/include/linux/ipmi.h
usr/src/linux/include/linux/netfilter/
usr/src/linux/include/linux/netfilter/nf_conntrack_tuple_common.h
usr/src/linux/include/linux/netfilter/xt_dscp.h
usr/src/linux/include/linux/netfilter/xt_esp.h
usr/src/linux/include/linux/netfilter/xt_physdev.h
usr/src/linux/include/linux/netfilter/xt_pkttype.h
usr/src/linux/include/linux/netfilter/nfnetlink_compat.h
usr/src/linux/include/linux/netfilter/xt_CT.h
usr/src/linux/include/linux/netfilter/xt_LED.h
usr/src/linux/include/linux/netfilter/xt_u32.h
usr/src/linux/include/linux/netfilter/xt_quota.h
usr/src/linux/include/linux/netfilter/x_tables.h
usr/src/linux/include/linux/netfilter/xt_string.h
usr/src/linux/include/linux/netfilter/xt_realm.h
usr/src/linux/include/linux/netfilter/xt_connmark.h
usr/src/linux/include/linux/netfilter/xt_limit.h
usr/src/linux/include/linux/netfilter/xt_tcpudp.h
usr/src/linux/include/linux/netfilter/xt_NFLOG.h
usr/src/linux/include/linux/netfilter/xt_DSCP.h
usr/src/linux/include/linux/netfilter/xt_CONNMARK.h
usr/src/linux/include/linux/netfilter/.install
usr/src/linux/include/linux/netfilter/nfnetlink_log.h
usr/src/linux/include/linux/netfilter/xt_cpu.h
usr/src/linux/include/linux/netfilter/nfnetlink.h
usr/src/linux/include/linux/netfilter/xt_tcpmss.h
usr/src/linux/include/linux/netfilter/xt_state.h
usr/src/linux/include/linux/netfilter/xt_mac.h
usr/src/linux/include/linux/netfilter/xt_NFQUEUE.h
usr/src/linux/include/linux/netfilter/xt_sctp.h
usr/src/linux/include/linux/netfilter/xt_IDLETIMER.h
usr/src/linux/include/linux/netfilter/xt_conntrack.h
usr/src/linux/include/linux/netfilter/xt_recent.h
usr/src/linux/include/linux/netfilter/xt_rateest.h
usr/src/linux/include/linux/netfilter/xt_TCPOPTSTRIP.h
usr/src/linux/include/linux/netfilter/nf_conntrack_sctp.h
usr/src/linux/include/linux/netfilter/xt_connlimit.h
usr/src/linux/include/linux/netfilter/xt_ipvs.h
usr/src/linux/include/linux/netfilter/xt_connbytes.h
usr/src/linux/include/linux/netfilter/xt_RATEEST.h
usr/src/linux/include/linux/netfilter/xt_comment.h
usr/src/linux/include/linux/netfilter/nf_conntrack_tcp.h
usr/src/linux/include/linux/netfilter/nfnetlink_conntrack.h
usr/src/linux/include/linux/netfilter/xt_mark.h
usr/src/linux/include/linux/netfilter/xt_multiport.h
usr/src/linux/include/linux/netfilter/xt_policy.h
usr/src/linux/include/linux/netfilter/xt_CHECKSUM.h
usr/src/linux/include/linux/netfilter/xt_TEE.h
usr/src/linux/include/linux/netfilter/xt_helper.h
usr/src/linux/include/linux/netfilter/xt_owner.h
usr/src/linux/include/linux/netfilter/xt_TCPMSS.h
usr/src/linux/include/linux/netfilter/xt_iprange.h
usr/src/linux/include/linux/netfilter/xt_statistic.h
usr/src/linux/include/linux/netfilter/xt_hashlimit.h
usr/src/linux/include/linux/netfilter/..install.cmd
usr/src/linux/include/linux/netfilter/xt_osf.h
usr/src/linux/include/linux/netfilter/xt_SECMARK.h
UTP: received command 'frf'
usr/src/linux/include/linux/netfilter/xt_cluster.h
usr/src/linux/include/linux/netfilter/xt_time.h
usr/src/linux/include/linux/netfilter/xt_TPROXY.h
usr/src/linux/include/linux/netfilter/nfnetlink_queue.h
usr/src/linux/include/linux/netfilter/xt_dccp.h
usr/src/linux/include/linux/netfilter/xt_CONNSECMARK.h
usr/src/linux/include/linux/netfilter/nf_conntrack_ftp.h
usr/src/linux/include/linux/netfilter/xt_MARK.h
usr/src/linux/include/linux/netfilter/xt_length.h
usr/src/linux/include/linux/netfilter/xt_CLASSIFY.h
usr/src/linux/include/linux/netfilter/nf_conntrack_common.h
usr/src/linux/include/linux/pkt_sched.h
usr/src/linux/include/linux/firewire-constants.h
usr/src/linux/include/linux/netdevice.h
usr/src/linux/include/linux/if_link.h
usr/src/linux/include/linux/edd.h
usr/src/linux/include/linux/atmmpc.h
usr/src/linux/include/drm/
usr/src/linux/include/drm/sis_drm.h
usr/src/linux/include/drm/radeon_drm.h
usr/src/linux/include/drm/r128_drm.h
usr/src/linux/include/drm/drm_sarea.h
usr/src/linux/include/drm/i830_drm.h
usr/src/linux/include/drm/.install
usr/src/linux/include/drm/nouveau_drm.h
usr/src/linux/include/drm/via_drm.h
usr/src/linux/include/drm/mga_drm.h
usr/src/linux/include/drm/i915_drm.h
usr/src/linux/include/drm/..install.cmd
usr/src/linux/include/drm/drm_mode.h
usr/src/linux/include/drm/i810_drm.h
usr/src/linux/include/drm/vmwgfx_drm.h
usr/src/linux/include/drm/drm.h
usr/src/linux/include/drm/savage_drm.h
usr/src/linux/include/asm/
usr/src/linux/include/asm/stat.h
usr/src/linux/include/asm/posix_types.h
usr/src/linux/include/asm/errno.h
usr/src/linux/include/asm/fcntl.h
usr/src/linux/include/asm/sigcontext.h
usr/src/linux/include/asm/bitsperlong.h
usr/src/linux/include/asm/auxvec.h
usr/src/linux/include/asm/siginfo.h
usr/src/linux/include/asm/setup.h
usr/src/linux/include/asm/sockios.h
usr/src/linux/include/asm/ipcbuf.h
usr/src/linux/include/asm/hwcap.h
usr/src/linux/include/asm/.install
usr/src/linux/include/asm/a.out.h
usr/src/linux/include/asm/unistd.h
usr/src/linux/include/asm/ioctls.h
usr/src/linux/include/asm/swab.h
usr/src/linux/include/asm/poll.h
usr/src/linux/include/asm/resource.h
usr/src/linux/include/asm/socket.h
usr/src/linux/include/asm/mman.h
usr/src/linux/include/asm/types.h
usr/src/linux/include/asm/ioctl.h
usr/src/linux/include/asm/termbits.h
usr/src/linux/include/asm/signal.h
usr/src/linux/include/asm/msgbuf.h
usr/src/linux/include/asm/param.h
usr/src/linux/include/asm/ptrace.h
usr/src/linux/include/asm/statfs.h
usr/src/linux/include/asm/termios.h
usr/src/linux/include/asm/..install.cmd
usr/src/linux/include/asm/shmbuf.h
usr/src/linux/include/asm/sembuf.h
usr/src/linux/include/asm/byteorder.h
usr/src/linux/include/rdma/
usr/src/linux/include/rdma/ib_user_mad.h
usr/src/linux/include/rdma/.install
usr/src/linux/include/rdma/..install.cmd
usr/sbin/
usr/sbin/udevmonitor
usr/local/
usr/lib/
usr/lib/libfsl_shw.so.0
usr/lib/libthread_db.so
usr/lib/libpthread.so.bak
usr/lib/libnss_compat.so
usr/lib/libnss_nis.so
usr/lib/libcrypt.so
usr/lib/libpxp.so.0
usr/lib/libc.so.bak
usr/lib/libBrokenLocale.so
usr/lib/libvpu.so.4
usr/lib/libutil.so
usr/lib/libipu.so.0
usr/lib/libnsl.so
usr/lib/libm.so
usr/lib/libnss_hesiod.so
usr/lib/libpxp.so
usr/lib/libipu.so
usr/lib/libstdc++.so
usr/lib/libc.so
usr/lib/libtermcap.so
usr/lib/librt.so
usr/lib/libssp.so
usr/lib/libvolume_id.so
usr/lib/libnss_nisplus.so
usr/lib/pkgconfig/
usr/lib/pkgconfig/libvolume_id.pc
usr/lib/libvpu.so
usr/lib/libnss_files.so
usr/lib/libresolv.so
usr/lib/libanl.so
usr/lib/libdl.so
usr/lib/libnss_dns.so
var/
var/lock/
var/spool/
var/spool/lpd/
var/spool/mail/
var/tmp/
var/log/
var/log/wtmp
var/log/hotplug/
var/log/lastlog
var/www/
var/www/icons/
var/www/cgi-bin/
var/www/cgi-bin/test_cgi
var/www/html/
var/www/html/index.html
var/lib/
var/ftp/
var/ftp/etc/
var/ftp/pub/
var/ftp/bin/
var/ftp/lib/
var/run/
var/run/utmputp_poll: pass returned.
var/run/usb/
var/mail/
UTP: closing the file
UTP: sending Success to kernel for command frf.
UTP: received command '$ umount /mnt/mmcblk0p1'
UTP: executing "umount /mnt/mmcblk0p1"
UTP: sending Success to kernel for command $ umount /mnt/mmcblk0p1.
UTP: received command '$ echo Update Complete!'
UTP: executing "echo Update Complete!"
Update Complete!
UTP: sending Success to kernel for command $ echo Update Complete!.
But after hardware board reset, uboot can not load linux kernel correctly:
Header 1
U-Boot 2009.08 (Aug 16 2013 - 12:53:32)
CPU: Freescale i.MX6 family TO1.1 at 792 MHz
Thermal sensor with ratio = 188
Temperature:   42 C, calibration data 0x5a34e87d
mx6q pll1: 792MHz
mx6q pll2: 528MHz
mx6q pll3: 480MHz
mx6q pll8: 50MHz
ipg clock     : 66000000Hz
ipg per clock : 66000000Hz
uart clock    : 80000000Hz
cspi clock    : 60000000Hz
ahb clock     : 132000000Hz
axi clock   : 198000000Hz
emi_slow clock: 99000000Hz
ddr clock     : 396000000Hz
usdhc1 clock  : 198000000Hz
usdhc2 clock  : 198000000Hz
usdhc3 clock  : 198000000Hz
usdhc4 clock  : 198000000Hz
nfc clock     : 24000000Hz
Board: i.MX6DL/Solo-SABRESD: unknown-board Board: 0x61011 [POR ]
Boot Device: MMC
I2C:   ready
DRAM:  512 MB
MMC:   FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3
*** Warning - bad CRC or MMC, using default environment
In:    serial
Out:   serial
Err:   serial
Net:   got MAC address from IIM: 00:00:00:00:00:00
FEC0 [PRIME]
Hit any key to stop autoboot:  0
FEC: Link is down 0
*** ERROR: `ethaddr' not set
FEC: Link is down 0
Wrong Image Format for bootm command
ERROR: can't get kernel image!
MX6Solo SABRESD U-Boot >
uboot can not load uImage. I guess I need to modify uboot code as linux code, but where should I begin to deal with ?
