qt5 with wayland on i.Mx6 sabrelite failed
1,923件の閲覧回数
chengyong_xie
My platform is i_MX6QSABRELite, my rootfs comes from timesys and my libEGL-wl.so come from ltib.
I haven't build weston because I want use qtcompositor.
when I use qtwayland(wayland-egl) to run qt5 application, it will crash with an error "failed to create display no such file or directory".
could someone give me some suggestions?
How can I fix this problem? thanks.
2 返答(返信)
1,438件の閲覧回数
857849964
how set the environment variable XDG_RUNTIME_DIR
1,438件の閲覧回数
yenchinlee
Please set the environment variable XDG_RUNTIME_DIR before you start the compositor.
