produce imx6 nand flash image for mass production
1,113 次查看
allonli
customer would like to use flash programmer to burn nand flash image off-line, for the imx6ull platform.
how to produce such image for nand flash usage?
we dump out the image from a nand flash which work fine, but occur ecc and other erros.
1,081 次查看
igorpadykov
Hi Allon
nxp provides only uuu and mfg tool for nand programming :
GitHub - NXPmicro/mfgtools: Freescale/NXP I.MX Chip image deploy tools.
In general you can program one nand, then read image in programmer and
use it for programming other nands. However this may not work if other nands
have different bad blocks locations.
