problem with record video & audio by gstreamer on IMX53
sergeybulgakov
Hello all !
I have board based on IMX53. If I record only video (from composite input) - all is right. I use next command
gst-launch mfw_v4lsrc capture-width=720 capture-height=576 \
           sensor-width=720 sensor-height=288 \
           preview=1 \
           typefind=1 do-timestamp=1 ! \
queue ! mfw_vpuencoder codec-type=2 ! queue ! mux. \
avimux name=mux ! \
filesink location=1.avi sync=false
If I try to mix audio from microphone input result is invalid. Audio part is ok but video is faster then must be in 2-3 times. I use next command
amixer sset Mic Capture cap
gst-launch \
           preview=1 \
alsasrc ! queue ! audioconvert ! queue ! mfw_mp3encoder ! queue ! mux. \
avimux name=mux ! \
Could you explain me that is wrong?
Sergey
ChucoChe
Which mx53 FSL board was your custom board based on?
Michel
