problem of IMAX6Q when power on
968件の閲覧回数
dengboping
MMPF0100+IMAX6Q  solution, produce 50pcs, 5 have power on problem,it can't start-up ,can't boot. Then  give a reset signal on PMIC_STBY_REQ pin manually,  it start-up and work well.
if power off and power on quickly within 1s, it also can boot and work well.
what's the problem??
ラベル(2)
タグ(1)
897件の閲覧回数
Rita_Wang
Here recommand you to check your hardware power and PCB Welding problem.
