porting WEC7_v3.1.1.16(windows embedded compact) to iMX6Q SDB
1,506 次查看
bharathts
Hi ,
   i was porting WEC7 _v3.1.1.16 to imx6q SDB & have downloaded the images from https://witekio.com/cpu/i-mx-6/ (Adeneo Embedded) & i was loading binaries using MFGTool from freescale through USB boot & i was getting the below response with my formatedSD card(FAT) inserted to the board...
Inline image
as per the manual i was suppose to get these logs...
Inline image
 Once loading these binaries i changed the Boot mode switch to SD card Boot & i was NOT ABLE TO SEE ANY LOGS ON Serial monitor...
kindly help by giving full procedure to boot iMX6Q_SDB with WEC7...
标签 (3)
1,276 次查看
Bio_TICFSL
Hi t s,
Looks like you are working with the nda image from Adeneo, Please try to contact AdeneoEmbedded for Wince support.
regards
