I noticed that one can build piglit in imx-3.10.53-1.1.0_ga yocto build.
The sanity test is failing on iMX6.
According to README, these tests should pass to be able to rely on the testsuite results.
however, unfortunately "readPixSanity" test is failing on iMX6.
Can someone help me to fix it?
I have attached the log.
Thanks & Regards,
Parag
Original Attachment has been moved to: main.zip
