parsing matroska file with gstreame on imx6
3,072件の閲覧回数
ieio
Hi.
I need to play  matroska files and it seems that there is a seeking issue with freescale gstreamer for imx6.
Command used is:gst-launch  playbin2 uri=file:///test.mkv
As far as I understood Freescale gstreamer uses  lib_mkv_parser_arm11_elinux.so.3.1, instead of the one coming with gstreamer.
Here is the output I get:
Core: MKVPARSER_01.04.02  build on Mar  1 2013 14:38:20
  mime: video/x-matroska ; video/webm
  file: /usr/lib/imx-mm/parser/lib_mkv_parser_arm11_elinux.so.3.1
Content Info:
        URI:
              file:///test.mkv
        Idx File:
              /root/.aiur/.test.aidx
        Seekable  : Yes
        Size(byte): 1351578
Movie Info:
        Seekable  : Yes
        Live      : No
        Duration  : 0:01:03.563000000
        ReadMode  : Track
        Track     : 1
Track 00 [video_000000] Enabled
        Duration: 0:00:27.956000000
        Language: eng
        Mime:
              video/mpeg, mpegversion=(int)4, parsed=(boolean)true, width=(int)640, height=(in
              t)480, framerate=(fraction)30/1, codec_data=(buffer)000001b003000001b2464d5f5047
              204d6f6465000001b509000001000000012000c48881f4514043c1463f
The problem is that it takes around 40 second before displaying the content.
The same command on my Ubuntu machine works correctly displaying immediately the content.
I suspect the problem could be that the Movie Duration  is more than Track 00 Duration, and the parser is not able to jump to the content as the one that runs on Ubuntu.
How can I fix it?
ラベル(3)
6 返答(返信)
2,218件の閲覧回数
LeonardoSandova
Specialist I
What do you mean by movie > track_0 durations? You mean track 1? Movie duration should be always >= first track, right?
Leo
2,218件の閲覧回数
ieio
If I well understand the logs, the movie is made of 1 track that is track 00.
Now the movie is 1:03 sec while track 00, the only track in the movie, is 27.95 second; anyway if I try to play this clip in Totem, or playbin2 on my ubuntu machine it jump immediately to the 27.95 second content.
Moreover if I use  AVI container I have no problems.
i.
2,218件の閲覧回数
LeonardoSandova
Specialist I
Strange. So the AVI container works fine on the target? Does the matroska playback produce any errors/warnigns? (--gst-debug=*:2).
Leo
2,218件の閲覧回数
ieio
Yes AVI works fine on the target.
here is the log of matroska playback with --gst-debug=*:2
<h --gst-debug=*:2  playbin2 uri=file:///root/2013-10-03-17-06-22.mkv
0:00:00.687421001  25650x17050 WARN        GST_REGISTRY gstregistry.c:1178:gst_registry_scan_path_level:<registry0> ignoring old plugin /usr/lib/gstreamer-0.10/libgstvalve.so which has been merged into the corelements plugin
0:00:00.711314001  25650x17050 WARN        GST_REGISTRY gstregistry.c:1178:gst_registry_scan_path_level:<registry0> ignoring old plugin /usr/lib/gstreamer-0.10/libgstselector.so which has been merged into the corelements plugin
(gst-launch-0.10:2565): GStreamer-CRITICAL **: gst_debug_log_valist: assertion `category != NULL' failed
Pipeline is PREROLLING ...
Aiur: 3.0.7
Content Info:
        URI:
        Idx File:
              /root/.aiur/.root.2013-10-03-17-06-22.mkv.aidx
        Seekable  : Yes
        Size(byte): 1351578
0:00:03.286612001  2565   0x120358 WARN               aiurdemux aiurdemux.c:3676:aiurdemux_loop_state_header: Warning: API[getNumPrograms] not implement!
Movie Info:
        Seekable  : Yes
        Live      : No
        ReadMode  : Track
        Track     : 1
        Language: eng
        Mime:
[INFO]  Product Info: i.MX6Q/D/S
vpudec versions :smileyhappy:
        plugin: 3.0.7
        wrapper: 1.0.35(VPUWRAPPER_ARM_LINUX Build on May 17 2013 12:39:55)
        vpulib: 5.4.12
        firmware: 2.1.9.36350
0:00:03.544840667  2565   0x120358 WARN               aiurdemux aiurdemux.c:1276:aiurdemux_send_stream_newsegment: Timestamp unexpect, maybe a core parser bug!
0:00:03.544936001  2565   0x120358 WARN               aiurdemux aiurdemux.c:1287:aiurdemux_send_stream_newsegment: Pad video: Send newseg 0:00:00.000000000 first buffer 0:00:35.607000000
ERROR: v4l2 capture: slave not found!
0:00:04.295030334  2565   0x14f638 WARN             mfw_v4lsink mfw_gst_v4lsink.c:303:mfw_gst_v4l2sink_query_support_formats: unrecognized format:[Y444]YUV444
MFW_GST_V4LSINK_PLUGIN 3.0.7 build on Sep 19 2013 14:35:30.
[INFO]  bitstreamMode 1, chromaInterleave 1, mapType 0, tiled2LinearEnable 0
[WARN]  VPU iram is less than needed, some parts don't use iram
>>V4L_SINK: Actually buffer status:
        hardware buffer : 10
        software buffer : 0
0:00:04.333431001  2565   0x14f638 WARN                  vpudec vpudec.c:1599:gst_vpudec_chain: Got EOS message with buffer not NULL!!
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
0:00:04.415223667  2565    0x17050 WARN                     bin gstbin.c:2380:gst_bin_do_latency_func:<playbin20> did not really configure latency of 0:00:00.000000000
full screen size:800x480
0:00:04.415551001  2565    0x17050 WARN             mfw_v4lsink mfw_gst_v4l.c:1422:mfw_gst_v4l2_display_init: Wrong display width information
0:00:04.415633001  2565    0x17050 WARN             mfw_v4lsink mfw_gst_v4l.c:1426:mfw_gst_v4l2_display_init: Wrong display height information
[V4L Update Display]: left=0, top=0, width=800, height=480
New clock: GstSystemClock
usb 2-1.1: USB disconnect, device number 4
usb 2-1.1: new low speed USB device number 5 using fsl-ehci
input: PIXART USB OPTICAL MOUSE as /devices/platform/fsl-ehci.1/usb2/2-1/2-1.1/2-1.1:1.0/input/input3
generic-usb 0003:093A:2510.0003: input,hidraw0: USB HID v1.11 Mouse [PIXART USB OPTICAL MOUSE] on usb-fsl-ehci.1-1.1/input0
0:01:06.079403674  2565   0x120358 WARN               aiurdemux aiurdemux.c:1325:aiurdemux_send_stream_eos: Pad video: Send eos.
0:01:06.079575341  2565   0x120358 WARN               aiurdemux aiurdemux.c:4312:aiurdemux_pull_task: pausing task, reason unexpected
Got EOS from element "playbin20".
Execution ended after 63527063341 ns.
Running time 0:01:03.530693008 render fps 10.420
Setting pipeline to READY ...
Total rendered:662
0:01:07.980685009  2565    0x17050 WARN             mfw_v4lsink mfw_gst_v4l_buffer.c:764:mfw_gst_v4l2_free_buffers: try to free buffer 0 at state 2
0:01:07.980784342  2565    0x17050 WARN             mfw_v4lsink mfw_gst_v4l_buffer.c:764:mfw_gst_v4l2_free_buffers: try to free buffer 1 at state 2
0:01:07.980829009  2565    0x17050 WARN             mfw_v4lsink mfw_gst_v4l_buffer.c:764:mfw_gst_v4l2_free_buffers: try to free buffer 2 at state 2
0:01:07.980870009  2565    0x17050 WARN             mfw_v4lsink mfw_gst_v4l_buffer.c:764:mfw_gst_v4l2_free_buffers: try to free buffer 3 at state 2
0:01:07.980910009  2565    0x17050 WARN             mfw_v4lsink mfw_gst_v4l_buffer.c:764:mfw_gst_v4l2_free_buffers: try to free buffer 4 at state 3
0:01:07.980950675  2565    0x17050 WARN             mfw_v4lsink mfw_gst_v4l_buffer.c:764:mfw_gst_v4l2_free_buffers: try to free buffer 5 at state 2
0:01:07.980989342  2565    0x17050 WARN             mfw_v4lsink mfw_gst_v4l_buffer.c:764:mfw_gst_v4l2_free_buffers: try to free buffer 6 at state 2
0:01:07.981028009  2565    0x17050 WARN             mfw_v4lsink mfw_gst_v4l_buffer.c:764:mfw_gst_v4l2_free_buffers: try to free buffer 7 at state 2
0:01:07.981066342  2565    0x17050 WARN             mfw_v4lsink mfw_gst_v4l_buffer.c:764:mfw_gst_v4l2_free_buffers: try to free buffer 8 at state 2
0:01:07.981104009  2565    0x17050 WARN             mfw_v4lsink mfw_gst_v4l_buffer.c:764:mfw_gst_v4l2_free_buffers: try to free buffer 9 at state 2
Setting pipeline to NULL ...
[--->FINALIZE v4l_sink
[--->FINALIZE aiurdemux
Freeing pipeline ...
i.
2,218件の閲覧回数
mingzhou
Could you please provide the version of mkv parser in Ubuntu and share the file?
2,218件の閲覧回数
ieio
Here is the output of UBUNTU:
user@ubuntu:~$ gst-launch -v playbin2 uri=file:///home/user/2013-10-03-17-06-22.mkv
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0: connection-speed = 0
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0: download = FALSE
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0: uri = "file:///home/user/2013-10-03-17-06-22.mkv"
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0: use-buffering = FALSE
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0: buffer-duration = -1
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0: buffer-size = -1
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0: source = (GstFileSrc) source
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstTypeFindElement:typefind.GstPad:src: caps = video/x-matroska
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstMatroskaDemux:matroskademux0.GstPad:sink: caps = video/x-matroska
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstMultiQueue:multiqueue0: max-size-buffers = 5
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstMultiQueue:multiqueue0: max-size-time = 0
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstMultiQueue:multiqueue0: max-size-bytes = 2097152
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstMultiQueue:multiqueue0.GstPad:sink0: caps = video/mpeg, mpegversion=(int)4, systemstream=(boolean)false, codec_data=(buffer)000001b003000001b2464d5f5047204d6f6465000001b509000001000000012000c48881f4514043c1463f, width=(int)640, height=(int)480, framerate=(fraction)1699999997/56666666
/GstPlayBin2:playbin20/GstPlaybin2InputSelector:playbin2inputselector0.GstPlaybin2SelectorPad:sink0: always-ok = FALSE
/GstPlayBin2:playbin20/GstPlaybin2InputSelector:playbin2inputselector0: active-pad = (GstPlaybin2SelectorPad) sink0
/GstPlayBin2:playbin20/GstPlaybin2InputSelector:playbin2inputselector0.GstPlaybin2SelectorPad:sink0: tags = ((GstTagList*) 0x8e0dea8)
/GstPlayBin2:playbin20/GstPlaybin2InputSelector:playbin2inputselector0.GstPlaybin2SelectorPad:sink0: tags = ((GstTagList*) 0x8e16f38)
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstMultiQueue:multiqueue0.GstPad:src0: caps = video/mpeg, mpegversion=(int)4, systemstream=(boolean)false, codec_data=(buffer)000001b003000001b2464d5f5047204d6f6465000001b509000001000000012000c48881f4514043c1463f, width=(int)640, height=(int)480, framerate=(fraction)1699999997/56666666
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/ffdec_mpeg4:ffdec_mpeg40.GstPad:sink: caps = video/mpeg, mpegversion=(int)4, systemstream=(boolean)false, codec_data=(buffer)000001b003000001b2464d5f5047204d6f6465000001b509000001000000012000c48881f4514043c1463f, width=(int)640, height=(int)480, framerate=(fraction)1699999997/56666666
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0.GstGhostPad:src0: caps = video/x-raw-yuv, width=(int)640, height=(int)480, framerate=(fraction)1699999997/56666666, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20.GstDecodePad:src0: caps = video/x-raw-yuv, width=(int)640, height=(int)480, framerate=(fraction)1699999997/56666666, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/ffdec_mpeg4:ffdec_mpeg40.GstPad:src: caps = video/x-raw-yuv, width=(int)640, height=(int)480, framerate=(fraction)1699999997/56666666, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaybin2InputSelector:playbin2inputselector0.GstPlaybin2SelectorPad:sink0: caps = video/x-raw-yuv, width=(int)640, height=(int)480, framerate=(fraction)1699999997/56666666, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0.GstGhostPad:src0.GstProxyPad:proxypad4: caps = video/x-raw-yuv, width=(int)640, height=(int)480, framerate=(fraction)1699999997/56666666, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20.GstDecodePad:src0.GstProxyPad:proxypad3: caps = video/x-raw-yuv, width=(int)640, height=(int)480, framerate=(fraction)1699999997/56666666, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaybin2InputSelector:playbin2inputselector0.GstPad:src: caps = video/x-raw-yuv, width=(int)640, height=(int)480, framerate=(fraction)1699999997/56666666, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstQueue:vqueue.GstPad:sink: caps = video/x-raw-yuv, width=(int)640, height=(int)480, framerate=(fraction)1699999997/56666666, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin.GstGhostPad:sink: caps = video/x-raw-yuv, width=(int)640, height=(int)480, framerate=(fraction)1699999997/56666666, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0.GstGhostPad:video_raw_sink: caps = video/x-raw-yuv, width=(int)640, height=(int)480, framerate=(fraction)1699999997/56666666, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0.GstGhostPad:video_raw_sink.GstProxyPad:proxypad5: caps = video/x-raw-yuv, width=(int)640, height=(int)480, framerate=(fraction)1699999997/56666666, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin.GstGhostPad:sink.GstProxyPad:proxypad7: caps = video/x-raw-yuv, width=(int)640, height=(int)480, framerate=(fraction)1699999997/56666666, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstQueue:vqueue.GstPad:src: caps = video/x-raw-yuv, width=(int)640, height=(int)480, framerate=(fraction)1699999997/56666666, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstFFMpegCsp:vconv.GstPad:src: caps = video/x-raw-yuv, format=(fourcc)YUY2, width=(int)640, height=(int)480, framerate=(fraction)1699999997/56666666, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstFFMpegCsp:vconv.GstPad:sink: caps = video/x-raw-yuv, width=(int)640, height=(int)480, framerate=(fraction)1699999997/56666666, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstVideoScale:vscale.GstPad:src: caps = video/x-raw-yuv, format=(fourcc)YUY2, width=(int)640, height=(int)480, framerate=(fraction)1699999997/56666666, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstVideoScale:vscale.GstPad:sink: caps = video/x-raw-yuv, format=(fourcc)YUY2, width=(int)640, height=(int)480, framerate=(fraction)1699999997/56666666, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstAutoVideoSink:videosink/GstXvImageSink:videosink-actual-sink-xvimage.GstPad:sink: caps = video/x-raw-yuv, format=(fourcc)YUY2, width=(int)640, height=(int)480, framerate=(fraction)1699999997/56666666, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstAutoVideoSink:videosink.GstGhostPad:sink: caps = video/x-raw-yuv, format=(fourcc)YUY2, width=(int)640, height=(int)480, framerate=(fraction)1699999997/56666666, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstAutoVideoSink:videosink.GstGhostPad:sink.GstProxyPad:proxypad6: caps = video/x-raw-yuv, format=(fourcc)YUY2, width=(int)640, height=(int)480, framerate=(fraction)1699999997/56666666, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
Execution ended after 27956465856 ns.
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstAutoVideoSink:videosink/GstXvImageSink:videosink-actual-sink-xvimage.GstPad:sink: caps = NULL
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstAutoVideoSink:videosink.GstGhostPad:sink: caps = NULL
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstVideoScale:vscale.GstPad:src: caps = NULL
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstVideoScale:vscale.GstPad:sink: caps = NULL
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstFFMpegCsp:vconv.GstPad:src: caps = NULL
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstFFMpegCsp:vconv.GstPad:sink: caps = NULL
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstQueue:vqueue.GstPad:src: caps = NULL
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstQueue:vqueue.GstPad:sink: caps = NULL
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin.GstGhostPad:sink: caps = NULL
/GstPlayBin2:playbin20/GstPlaySink:playsink0.GstGhostPad:video_raw_sink: caps = NULL
/GstPlayBin2:playbin20/GstPlaybin2InputSelector:playbin2inputselector0.GstPlaybin2SelectorPad:sink0: caps = NULL
/GstPlayBin2:playbin20/GstPlaybin2InputSelector:playbin2inputselector0.GstPad:src: caps = NULL
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0.GstGhostPad:src0: caps = NULL
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20.GstDecodePad:src0: caps = NULL
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/ffdec_mpeg4:ffdec_mpeg40.GstPad:src: caps = NULL
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/ffdec_mpeg4:ffdec_mpeg40.GstPad:sink: caps = NULL
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstMultiQueue:multiqueue0.GstPad:sink0: caps = NULL
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstMultiQueue:multiqueue0.GstPad:src0: caps = NULL
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstMatroskaDemux:matroskademux0.GstPad:video_00: caps = NULL
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstMatroskaDemux:matroskademux0.GstPad:sink: caps = NULL
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstTypeFindElement:typefind.GstPad:src: caps = NULL
As you can see it uses matroskademux:
user@ubuntu:~$ gst-inspect matroskademux
Factory Details:
  Long name:    Matroska demuxer
  Class:    Codec/Demuxer
  Description:    Demuxes a Matroska Stream into video/audio/subtitles
  Author(s):    GStreamer maintainers <gstreamer-devel@lists.sourceforge.net>
  Rank:        primary (256)
Plugin Details:
  Description:        Matroska stream handling
  Filename:        /usr/lib/gstreamer-0.10/libgstmatroska.so
  Version:        0.10.21
  License:        LGPL
  Source module:    gst-plugins-good
  Binary package:    GStreamer Good Plugins (Ubuntu)
  Origin URL:        https://launchpad.net/distros/ubuntu/+source/gst-plugins-good0.10
Here is the output of IMX6:
root@freescale ~$
< playbin2 uri=file:///root/2013-10-03-17-06-22.mkv
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0: ring-buffer-max-size = 0
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0: uri = "file:///root/2013-10-03-17-06-22.mkv"
Aiur: 3.0.7
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstAiurDemux:aiurdemux0.GstPad:sink: caps = video/x-matroska
Content Info:
        URI:
        Idx File:
        Seekable  : Yes
        Size(byte): 1351578
Movie Info:
        Seekable  : Yes
        Live      : No
        ReadMode  : Track
        Track     : 1
        Language: eng
        Mime:
        plugin: 3.0.7
        vpulib: 5.4.12
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstMultiQueue:multiqueue0.GstPad:sink0: caps = video/mpeg, mpegversion=(int)4, parsed=(boolean)true, width=(int)640, height=(int)480, framerate=(fraction)30/1f
/GstPlayBin2:playbin20/GstInputSelector:inputselector0.GstSelectorPad:sink0: always-ok = FALSE
/GstPlayBin2:playbin20/GstInputSelector:inputselector0: active-pad = (GstSelectorPad) sink0
/GstPlayBin2:playbin20/GstInputSelector:inputselector0.GstSelectorPad:sink0: tags = ((GstTagList*) 0x2e3b90)
/GstPlayBin2:playbin20/GstInputSelector:inputselector0.GstSelectorPad:sink0: tags = ((GstTagList*) 0xf1b48)
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstMultiQueue:multiqueue0.GstPad:src0: caps = video/mpeg, mpegversion=(int)4, parsed=(boolean)true, width=(int)640, height=(int)480, framerate=(fraction)30/1,f
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstVpuDec:vpudec0.GstPad:sink: caps = video/mpeg, mpegversion=(int)4, parsed=(boolean)true, width=(int)640, height=(int)480, framerate=(fraction)30/1, codec_df
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0.GstGhostPad:src0: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, crop-top=(int)0, crop-left=(int)0, crop-right=(int)0, 1
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20.GstDecodePad:src0: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, crop-top=(int)0, crop-left=1
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstVpuDec:vpudec0.GstPad:src: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, crop-top=(int)0,1
        software buffer : 0
/GstPlayBin2:playbin20/GstInputSelector:inputselector0.GstSelectorPad:sink0: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, crop-top=(int)0, crop-left=(int)0, crop-right=(i1
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0.GstGhostPad:src0.GstProxyPad:proxypad4: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, crop-top=(int)0, crop-left=(int)1
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20.GstDecodePad:src0.GstProxyPad:proxypad3: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, crop-1
/GstPlayBin2:playbin20/GstInputSelector:inputselector0.GstPad:src: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, crop-top=(int)0, crop-left=(int)0, crop-right=(int)0, crop1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstStreamSynchronizer:streamsynchronizer0.GstPad:sink_0: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, crop-top=(int)0, crop-l1
/GstPlayBin2:playbin20/GstPlaySink:playsink0.GstGhostPad:video_raw_sink: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, crop-top=(int)0, crop-left=(int)0, crop-right=(int)01
/GstPlayBin2:playbin20/GstPlaySink:playsink0.GstGhostPad:video_raw_sink.GstProxyPad:proxypad5: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, crop-top=(int)0, crop-left=(in1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstStreamSynchronizer:streamsynchronizer0.GstPad:src_0: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, crop-top=(int)0, crop-le1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstQueue:vqueue.GstPad:sink: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, crop-top=(int)0, crop-left=(int)0, crop1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin.GstGhostPad:sink: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, crop-top=(int)0, crop-left=(int)0, crop-right=(int1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin.GstGhostPad:sink.GstProxyPad:proxypad7: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, crop-top=(int)0, crop-left=(1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstQueue:vqueue.GstPad:src: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, crop-top=(int)0, crop-left=(int)0, crop-1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstAutoVideoSink:videosink/MFW_GST_V4LSINK_INFO_T:videosink-actual-sink-mfw_v4l.GstPad:sink: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)640, height=(int)480, pixel-asp1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstAutoVideoSink:videosink.GstGhostPad:sink: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, crop-top=(int)0, crop-l1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstAutoVideoSink:videosink.GstGhostPad:sink.GstProxyPad:proxypad6: caps = video/x-raw-yuv, format=(fourcc)NV12, width=(int)640, height=(int)480, pixel-aspect-ratio=(fraction)1/1, c1
i.
