panel-lvds driver does not work anymore after upgrade to kernel 6.6
3,677 次查看
MicMoba
Contributor V
I upgrade my Linux kernel from 5.15.52 to 6.6. After upgrading my panel only shows a small stripe. I made no changes at the device tree. When I use the panel-simple driver instead of panel-lvds I got a working display. Does someone know about changes in the driver.
I use a iMX8MP and my panel is connected to LVDS1 interface.
dmesg shows a message but I can't identify the failure
dmesg | grep lvds
[ 0.077630] platform panel-lvds1: Fixed dependency cycle(s) with /ldb-display-controller/lvds-channel@1
[ 2.511277] imx8mp-ldb ldb-display-controller: Failed to create device link (0x180) with phy-lvds
[ 2.552129] imx8mp-ldb ldb-display-controller: Failed to create device link (0x180) with panel-lvds1
标记 (5)
6 回复数
3,655 次查看
Bio_TICFSL
Have you checked the dtb? are they changed? which lvds device are you working on?
3,643 次查看
MicMoba
Contributor V
yes I checkd the dtb. I convert the dtb back to dts. The new one as the old one. I can't see any differences.
I use a DataModul 10,1“ TFT – WXGA – LVDS panel (TX26D207VM0AAA)
2,743 次查看
tw22
Failure occurs early during boot. This might indicate clocks problem. Check e. g. clock-names in node ldb read by drivers. What are you using? drm display-subsystem or frame buffers (mxc) ?
3,634 次查看
MicMoba
Contributor V
Here are my settings. Maybe you find a mistake
    backlight1: backlight1 {
        compatible = "pwm-backlight";
        pinctrl-names = "default";
        pinctrl-0 = <&pinctrl_lvds1>;
        default-brightness-level = <6>;
        pwms = <&pwm3 0 50000 0>;
        power-supply = <&reg_lvds1_reg_en>;
        enable-gpios = <&gpio2 20 GPIO_ACTIVE_LOW>;
        brightness-levels= <0 4 8 16 32 64 128 255>;
        status = "okay";
    panel_lvds: panel-lvds1 {
        compatible  = "panel-lvds";
        backlight   = <&backlight1>;
        width-mm = <218>;
        height-mm = <137>;
        data-mapping = "vesa-24";
        status = "okay";
        panel-timing {
            clock-frequency = <71000000>;
            hactive = <1280>;
            hfront-porch = <30>;
            hsync-len = <48>;
            hback-porch = <80>;
            vactive = <800>;
            vfront-porch = <3>;
            vsync-len = <6>;
            vback-porch = <14>;
        port {
            panel1_in: endpoint {
                remote-endpoint = <&lvds1_out>;
&lcdif2 {
  status = "okay";
/* LVDS1 */
&ldb {
    status = "okay";
    lvds-channel@1 {
        #address-cells = <1>;
	#size-cells = <0>;
        status = "okay";
        primary;
        port@1 {
            reg = <1>;
            lvds1_out: endpoint {
                remote-endpoint = <&panel1_in>;
&ldb_phy {
    status = "okay";
2,510 次查看
festevam
@MicMoba
This is an old thread, but I faced the same problem.
In my case, I had to pass the de-active = <1>; property to fix it.
1,129 次查看
brood
I have also been struggling with the same issue for over a week now, and adding this property ('de-active = <1>;') to the panel-timing definition in my device tree finally resolved the issue. My display works now, thanks for this! If I could give you more than 1 Kudo I would
%3CLINGO-SUB%20id%3D%22lingo-sub-1922948%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%8D%87%E7%BA%A7%E5%88%B0%E5%86%85%E6%A0%B8%206.6%20%E5%90%8E%EF%BC%8Cpanel-lvds%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%B8%8D%E5%86%8D%E5%B7%A5%E4%BD%9C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1922948%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%86%20Linux%20%E5%86%85%E6%A0%B8%E4%BB%8E%205.15.52%20%E5%8D%87%E7%BA%A7%E5%88%B0%206.6%E3%80%82%E5%8D%87%E7%BA%A7%E5%90%8E%EF%BC%8C%E6%88%91%E7%9A%84%E9%9D%A2%E6%9D%BF%E5%8F%AA%E6%98%BE%E7%A4%BA%E4%BA%86%E4%B8%80%E6%9D%A1%E5%B0%8F%E6%9D%A1%E7%BA%B9%E3%80%82%E6%88%91%E6%B2%A1%E6%9C%89%E5%AF%B9%E8%AE%BE%E5%A4%87%E6%A0%91%E8%BF%9B%E8%A1%8C%E4%BB%BB%E4%BD%95%E6%9B%B4%E6%94%B9%E3%80%82%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8%20panel-simple%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E8%80%8C%E4%B8%8D%E6%98%AF%20panel-lvds%20%E6%97%B6%EF%BC%8C%E6%98%BE%E7%A4%BA%E5%B1%8F%E5%B0%B1%E8%83%BD%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E4%BA%86%E3%80%82%E6%9C%89%E4%BA%BA%E7%9F%A5%E9%81%93%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E5%8F%98%E5%8C%96%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%20iMX8MP%EF%BC%8C%E9%9D%A2%E6%9D%BF%E8%BF%9E%E6%8E%A5%E5%88%B0%20LVDS1%20%E6%8E%A5%E5%8F%A3%E3%80%82%3C%2FP%3E%3CP%3Edmesg%20%E6%98%BE%E7%A4%BA%E4%BA%86%E4%B8%80%E6%9D%A1%E4%BF%A1%E6%81%AF%EF%BC%8C%E4%BD%86%E6%88%91%E6%97%A0%E6%B3%95%E7%A1%AE%E5%AE%9A%E6%95%85%E9%9A%9C%E5%8E%9F%E5%9B%A0%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Edmesg%20%7C%20grep%20lvds%0A%5B%200.077630%5D%20platform%20panel-lvds1%3A%20Fixed%20dependency%20cycle(s)%20with%20%2Fldb-display-controller%2Flvds-channel%401%0A%5B%202.511277%5D%20imx8mp-ldb%20ldb-display-controller%3A%20Failed%20to%20create%20device%20link%20(0x180)%20with%20phy-lvds%0A%5B%202.552129%5D%20imx8mp-ldb%20ldb-display-controller%3A%20Failed%20to%20create%20device%20link%20(0x180)%20with%20panel-lvds1%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1922948%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%208M%20%7C%20i.MX%208M%20Mini%20%7C%20i.MX%208M%20Nano%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ELinux%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EYocto%20Project%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2146984%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20panel-lvds%20driver%20does%20not%20work%20anymore%20after%20upgrade%20to%20kernel%206.6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2146984%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%88%91%E4%B9%9F%E4%B8%80%E7%9B%B4%E5%9C%A8%E4%B8%BA%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E8%8B%A6%E8%8B%A6%E6%8C%A3%E6%89%8E%E4%BA%86%E4%B8%80%E4%B8%AA%E5%A4%9A%E6%98%9F%E6%9C%9F%EF%BC%8C%E5%B0%86%E8%BF%99%E4%B8%AA%E5%B1%9E%E6%80%A7%EF%BC%88'de-active%20%3D%20%26lt%3B1%26gt%3B%3B%20'%EF%BC%89%E6%B7%BB%E5%8A%A0%E5%88%B0%E6%88%91%E7%9A%84%E8%AE%BE%E5%A4%87%E6%A0%91%E4%B8%AD%E7%9A%84%E9%9D%A2%E6%9D%BF%E5%AE%9A%E6%97%B6%E5%AE%9A%E4%B9%89%E4%B8%AD%E7%BB%88%E4%BA%8E%E8%A7%A3%E5%86%B3%E4%BA%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%E6%88%91%E7%9A%84%E6%98%BE%E7%A4%BA%E5%B1%8F%E7%8E%B0%E5%9C%A8%E8%83%BD%E7%94%A8%E4%BA%86%EF%BC%8C%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%B8%AE%E5%8A%A9%EF%BC%81%E5%A6%82%E6%9E%9C%E6%88%91%E8%83%BD%E7%BB%99%E4%BD%A0%E4%B8%8D%E6%AD%A2%201%20%E4%B8%AA%E8%B5%9E%EF%BC%8C%E6%88%91%E4%BC%9A%E7%9A%84%20%3CLI-EMOJI%20id%3D%22lia_slightly-smiling-face%22%20title%3D%22%3Aslightly_smiling_face%3A%22%3E%3C%2FLI-EMOJI%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2039961%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20panel-lvds%20driver%20does%20not%20work%20anymore%20after%20upgrade%20to%20kernel%206.6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2039961%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F24576%22%20target%3D%22_blank%22%3E%40MicMoba%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E8%80%81%E8%AF%9D%E9%A2%98%EF%BC%8C%E4%BD%86%E6%88%91%E4%B9%9F%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%9C%A8%E6%88%91%E7%9A%84%E6%A1%88%E4%BE%8B%E4%B8%AD%EF%BC%8C%E6%88%91%E4%B8%8D%E5%BE%97%E4%B8%8D%E9%80%9A%E8%BF%87%20de-active%20%3D%26lt%3B1%26gt%3B%3B%20%E5%B1%9E%E6%80%A7%E6%9D%A5%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2020199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20panel-lvds%20driver%20does%20not%20work%20anymore%20after%20upgrade%20to%20kernel%206.6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2020199%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%9C%A8%E5%90%AF%E5%8A%A8%E5%88%9D%E6%9C%9F%E5%87%BA%E7%8E%B0%E6%95%85%E9%9A%9C%E3%80%82%E8%BF%99%E5%8F%AF%E8%83%BD%E8%A1%A8%E6%98%8E%E6%97%B6%E9%92%9F%E5%87%BA%E4%BA%86%E9%97%AE%E9%A2%98%E3%80%82%E4%BE%8B%E5%A6%82%EF%BC%8C%E6%A3%80%E6%9F%A5%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E8%AF%BB%E5%8F%96%E7%9A%84%E8%8A%82%E7%82%B9%20ldb%20%E4%B8%AD%E7%9A%84%E6%97%B6%E9%92%9F%E5%90%8D%E7%A7%B0%E3%80%82%E4%BD%A0%E7%94%A8%E7%9A%84%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9Fdrm%20%E6%98%BE%E7%A4%BA%E5%AD%90%E7%B3%BB%E7%BB%9F%E8%BF%98%E6%98%AF%E5%B8%A7%E7%BC%93%E5%86%B2%E5%8C%BA%20(mxc)%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1923349%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20panel-lvds%20driver%20does%20not%20work%20anymore%20after%20upgrade%20to%20kernel%206.6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1923349%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%88%91%E7%9A%84%E8%AE%BE%E7%BD%AE%E3%80%82%E4%B9%9F%E8%AE%B8%E4%BD%A0%E5%8F%91%E7%8E%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E9%94%99%E8%AF%AF%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%2F%20%7B%0A%20%20%20%20backlight1%3A%20backlight1%20%7B%0A%20%20%20%20%20%20%20%20compatible%20%3D%20%22pwm-backlight%22%3B%0A%20%20%20%20%20%20%20%20pinctrl-names%20%3D%20%22default%22%3B%0A%20%20%20%20%20%20%20%20pinctrl-0%20%3D%20%26lt%3B%26amp%3Bpinctrl_lvds1%26gt%3B%3B%0A%20%20%20%20%20%20%20%20default-brightness-level%20%3D%20%26lt%3B6%26gt%3B%3B%0A%20%20%20%20%20%20%20%20pwms%20%3D%20%26lt%3B%26amp%3Bpwm3%200%2050000%200%26gt%3B%3B%0A%20%20%20%20%20%20%20%20power-supply%20%3D%20%26lt%3B%26amp%3Breg_lvds1_reg_en%26gt%3B%3B%0A%20%20%20%20%20%20%20%20enable-gpios%20%3D%20%26lt%3B%26amp%3Bgpio2%2020%20GPIO_ACTIVE_LOW%26gt%3B%3B%0A%20%20%20%20%20%20%20%20brightness-levels%3D%20%26lt%3B0%204%208%2016%2032%2064%20128%20255%26gt%3B%3B%0A%20%20%20%20%20%20%20%20status%20%3D%20%22okay%22%3B%0A%20%20%20%20%7D%3B%0A%0A%20%20%20%20panel_lvds%3A%20panel-lvds1%20%7B%0A%20%20%20%20%20%20%20%20compatible%20%20%3D%20%22panel-lvds%22%3B%0A%20%20%20%20%20%20%20%20backlight%20%20%20%3D%20%26lt%3B%26amp%3Bbacklight1%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20width-mm%20%3D%20%26lt%3B218%26gt%3B%3B%0A%20%20%20%20%20%20%20%20height-mm%20%3D%20%26lt%3B137%26gt%3B%3B%0A%0A%20%20%20%20%20%20%20%20data-mapping%20%3D%20%22vesa-24%22%3B%0A%20%20%20%20%20%20%20%20status%20%3D%20%22okay%22%3B%0A%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20panel-timing%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20clock-frequency%20%3D%20%26lt%3B71000000%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20hactive%20%3D%20%26lt%3B1280%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20hfront-porch%20%3D%20%26lt%3B30%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20hsync-len%20%3D%20%26lt%3B48%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20hback-porch%20%3D%20%26lt%3B80%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20vactive%20%3D%20%26lt%3B800%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20vfront-porch%20%3D%20%26lt%3B3%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20vsync-len%20%3D%20%26lt%3B6%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20vback-porch%20%3D%20%26lt%3B14%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20port%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20panel1_in%3A%20endpoint%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20remote-endpoint%20%3D%20%26lt%3B%26amp%3Blvds1_out%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%7D%3B%0A%7D%3B%0A%26amp%3Blcdif2%20%7B%0A%20%20status%20%3D%20%22okay%22%3B%0A%7D%3B%0A%2F*%20LVDS1%20*%2F%0A%26amp%3Bldb%20%7B%0A%20%20%20%20status%20%3D%20%22okay%22%3B%0A%0A%20%20%20%20lvds-channel%401%20%7B%0A%20%20%20%20%20%20%20%20%23address-cells%20%3D%20%26lt%3B1%26gt%3B%3B%0A%09%23size-cells%20%3D%20%26lt%3B0%26gt%3B%3B%20%20%20%20%20%20%20%20%0A%20%20%20%20%20%20%20%20status%20%3D%20%22okay%22%3B%0A%20%20%20%20%20%20%20%20primary%3B%0A%20%20%20%20%20%20%20%20port%401%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20reg%20%3D%20%26lt%3B1%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20lvds1_out%3A%20endpoint%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20remote-endpoint%20%3D%20%26lt%3B%26amp%3Bpanel1_in%26gt%3B%3B%0A%20%20%20%20%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%20%20%20%20%7D%3B%0A%20%20%20%20%7D%3B%0A%7D%3B%0A%0A%26amp%3Bldb_phy%20%7B%0A%20%20%20%20status%20%3D%20%22okay%22%3B%0A%7D%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1923328%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20panel-lvds%20driver%20does%20not%20work%20anymore%20after%20upgrade%20to%20kernel%206.6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1923328%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E6%A3%80%E6%9F%A5%E4%BA%86%20DTB%E3%80%82%E6%88%91%E5%B0%86%20dtb%20%E8%BD%AC%E5%9B%9E%20dts%E3%80%82%E6%96%B0%E7%9A%84%E5%92%8C%E6%97%A7%E7%9A%84%E4%B8%80%E6%A0%B7%E3%80%82%E6%88%91%E7%9C%8B%E4%B8%8D%E5%87%BA%E6%9C%89%E4%BB%80%E4%B9%88%E4%B8%8D%E5%90%8C%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20DataModul%2010.1%20%E8%8B%B1%E5%AF%B8%20TFT%20-%20WXGA%20-%20LVDS%20%E9%9D%A2%E6%9D%BF%20(TX26D207VM0AAA)%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1923082%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20panel-lvds%20driver%20does%20not%20work%20anymore%20after%20upgrade%20to%20kernel%206.6%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1923082%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E4%BD%A0%E6%A3%80%E6%9F%A5%E8%BF%87%20dtb%20%E5%90%97%EF%BC%9F%E4%BD%A0%E5%9C%A8%E5%BC%80%E5%8F%91%E5%93%AA%E4%B8%AA%20lvds%20%E8%AE%BE%E5%A4%87%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E
