Does anyone know where stdc-predef.h is supposed to come from?
make all-recursive
make[1]: Entering directory `/home/jstashluk/software/seemore/os/ltib_1209/rpm/BUILD/fontconfig-2.4.2'
Making all in fontconfig
make[2]: Entering directory `/home/jstashluk/software/seemore/os/ltib_1209/rpm/BUILD/fontconfig-2.4.2/fontconfig'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/home/jstashluk/software/seemore/os/ltib_1209/rpm/BUILD/fontconfig-2.4.2/fontconfig'
Making all in fc-case
make[2]: Entering directory `/home/jstashluk/software/seemore/os/ltib_1209/rpm/BUILD/fontconfig-2.4.2/fc-case'
make all-am
make[3]: Entering directory `/home/jstashluk/software/seemore/os/ltib_1209/rpm/BUILD/fontconfig-2.4.2/fc-case'
if ccache /usr/bin/gcc -B/usr/bin/ -DHAVE_CONFIG_H -I. -I. -I.. -I../src -I.. -I/home/jstashluk/software/seemore/os/ltib_1209/rootfs/usr/include/freetype2 -I/home/jstashluk/software/seemore/os/ltib_1209/rootfs/usr/include -Wall -Wpointer-arith -Wstrict-prototypes -Wmissing-prototypes -Wmissing-declarations -Wnested-externs -fno-strict-aliasing -g -O2 -MT fc-case.o -MD -MP -MF ".deps/fc-case.Tpo" -c -o fc-case.o fc-case.c; \
then mv -f ".deps/fc-case.Tpo" ".deps/fc-case.Po"; else rm -f ".deps/fc-case.Tpo"; exit 1; fi
In file included from /usr/include/stdlib.h:25:0,
from ../src/fcint.h:32,
from fc-case.c:25:
/home/jstashluk/software/seemore/os/ltib_1209/rootfs/usr/include/features.h:345:25: fatal error: stdc-predef.h: No such file or directory
compilation terminated.
make[3]: *** [fc-case.o] Error 1
make[3]: Leaving directory `/home/jstashluk/software/seemore/os/ltib_1209/rpm/BUILD/fontconfig-2.4.2/fc-case'
make[2]: *** [all] Error 2
make[2]: Leaving directory `/home/jstashluk/software/seemore/os/ltib_1209/rpm/BUILD/fontconfig-2.4.2/fc-case'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/jstashluk/software/seemore/os/ltib_1209/rpm/BUILD/fontconfig-2.4.2'
make: *** [all] Error 2
error: Bad exit status from /home/jstashluk/software/seemore/os/ltib_1209/tmp/rpm-tmp.1961 (%build)
RPM build errors:
Build time for fontconfig: 11 seconds
Failed building fontconfig
f_buildrpms() returned an error, exiting
traceback:
main:572
Started: Tue Dec 11 09:59:40 2012
Ended: Tue Dec 11 09:59:52 2012
Elapsed: 12 seconds
These packages failed to build:
fontconfig
Build Failed
Exiting on error or interrupt
Solved! Go to Solution.
Jeremy,
Why don't you try that in Yocto? We've fontconfig working there and should be easier for you to use a more up to date software stack.
Jeremy,
