p2p_find is not working
1,228 次查看
harekrishnaroy
Hi All,
I am using yocto setup on SABRE AUTO board. With this board i have connected SX-SDCAN SD card which works with atheros driver and firmware. I am using same driver and firmware provided in yocto release with kernel version 3.14.28-1.0.0_ga+g91cf351. I have enabled P2P functionality in wpa_supplicant and i am loading driver with ath6kl_p2p=1.
All P2P related functionality are working fine except P2P_find.
With p2p_find command ideally i should be able to discover all nearby P2P devices but i am not able to see any,except those which are acting as group owner.
What could be the possible reason ? Am i making any mistake ?
Hare
标签 (3)
1,093 次查看
jimmychan
hope this information can help you.
Atheros wireless driver private commands.
