Hello NXP community,
I use imx8mp evk with yocto bsp version LF6.6.3_1.0.0 bsp version.
i have one ov5640 camera which i connect to mipi csi.
From dts file i came to know that this is ported via isi, since when i disable isi node in dts then it's not working. [correct me if my assumption is wrong].
now i wanted to port it via isp, tried adding isp node by disabling isi node but output shows - no video capture device. Below are the changes i tried in imx8mp-evk.dts file.
&isi_0 {
status = "disabled";
cap_device {
m2m_device {
&isp_0 {
status = "okay"
also tried
&isp_0 {
status = "okay"
cap_device {
status = "okay";
m2m_device {
status = "okay";
Both changes didn't work.
So, Can you please let me know what changes to do for porting ov5640 via isp.
Thanks in Advance
