opencv vpudec appsink
955 次查看
coindu
           I want to use python-opecv to displayer video frame with vpudec.  but only use vpudec as appsink input,the color will be black and white;When add videoconvert after vpudec the displayer will
 be very slow.
          environment BSP 5.4.3 opencv version 4.2.0
          Anyone who can help me fix it?
#!/usr/bin/env python3
import cv2
if __name__ == '__main__':
mode = r'filesrc location=/home/root/qq.mp4 typefind=true ! video/quicktime ! aiurdemux ! queue ! h264parse ! vpudec ! appsink'
#mode = r'filesrc location=/home/root/qq.mp4 typefind=true ! video/quicktime ! aiurdemux ! queue ! h264parse ! vpudec ! videoconvert ! queue ! appsink'
cap = cv2.VideoCapture(mode,cv2.CAP_GSTREAMER)
while True:
ret,frame = cap.read()
a=len(frame.shape)
print(a)
if ret is False:
break
cv2.imshow('appFrame',frame)
key = cv2.waitKey(20)
if key == 49:
cv2.destroyAllWindows()
cap.release()
944 次查看
joanxie
what board do you use? did you install phyton2 opencv successfully on yocto, right?
941 次查看
coindu
     IMX8MM and IMX8MQ board to test.
     Of cause ,the python opecv installed sucuess. Because I have run the python script on the platform.
     I'm just confused about the situation now.
924 次查看
joanxie
